Results 1 to 3 of 3
    new ss buld - rigid a-c newbie questions
    So im building an access 29er frame as an SS conversion and have been searching for a budget friendly rigid fork. I found a voodoo zombie fork but it says 500mm a-c. Im not exactly sure how axle to crown works but will this fork be ok to use with this frame? I typically see a-c in the 400's
    Reputation: mitzikatzi's Avatar
    The axle to crown on my Redline monocog is about 480mm
    480mm forks are used to "replace" 80mm suspension forks.
    A ac of 500mm would be the fork you would use to replace a 29er 100mm travel fork.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    ohhhhhhhhhhhhhhhhh! and I just read head tube angle increases per 20mm a-c increase.
    Thanks for the help!
  1. Newbie with some questions...
    By fstrchld in forum 29er Bikes
    Last Post: 03-02-2013, 08:54 PM
  2. Newbie with some questions...
    By fstrchld in forum Beginner's Corner
    Last Post: 02-26-2013, 10:26 PM
  3. newbie questions
    By Javier in forum Wheels and Tires
    Last Post: 10-09-2011, 08:32 PM
  4. 1x9 newbie questions
    By Tubbsy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-19-2011, 08:39 AM
  5. Newbie Questions(:
    By MaxYoungg in forum Beginner's Corner
    Last Post: 06-28-2011, 11:12 PM
