Results 1 to 3 of 3
    New Custom RockShox SID World Cup 29 fork is bottoming out
    I have this new fork on my S-Works Epic (solo air), and I think either I'm losing air out the top side, or somehow the the equilibrium is not being maintained and it all goes to the bottom, making the fork seem as if it has less than 2" of travel.
    I can reset it: You have to undo the bolt at the bottom, and let out the air from there (not easy), the fork goes right back up.
    Speiclized told my dealer to reset it as above, and thought it would not be an ongoing issues. But it's happened 3 times in a row now and unfortunately with limited time I won't be able to do anything about until next week. Meanwhile I have a 4 hour race Sunday.
    Does anyone have another idea of what I might try before Sunday? A rebuild or replacement is not in the works before then.
    I'm thinking I'll reset it, and then either ride it locked out or on it's heaviest brain compression setting. It will really sucks though as when the fork is working the bike is incredible. I don't think there is anything else I can do? I've only been riding the just over a week
    Same problem here. Have you got any solution to the problem.
    Had the same issue on both of my epic's with solo air. Had to send them back to SRAM in Chicago and had all new internals replaced and have been perfect since.
    2013 Specialized Epic Carbon 29
    2012 Specialized S-Works Tarmac SL4
    Hold it wide, and let it slide!
  1. Custom RockShox Revelation 29 fork
    By BluesDawg in forum Specialized
    Last Post: 12-12-2012, 10:42 AM
  2. Specialized Custom RockShox Revelation 29 fork
    By BluesDawg in forum Shocks and Suspension
    Last Post: 12-11-2012, 09:53 PM
  3. rockshox revelation bottoming out to easily
    By Charliewilson in forum Shocks and Suspension
    Last Post: 10-18-2012, 09:19 AM
  4. Heavy rider bottoming out the fork
    By druidjaidan in forum Shocks and Suspension
    Last Post: 09-06-2012, 12:41 AM
  5. Rockshox sid world cup
    By trousy in forum SRAM
    Last Post: 02-26-2012, 08:03 PM
