Results 1 to 20 of 20
    Reputation: Johnny Chicken Bones's Avatar
    NEW 1 1/8th Forks? `
    I love my old(ish) frames.
    Don't want new ones and Ti don't wear out.
    Do any of you know of a source for 1 1/8th" suspension forks?
    15mm TA, 100mm
    Surely some shop somewhere is sitting on a few they need to get rid of.
    Thanks.
    -JCB
    --------- __o
    ------- _`\<,_
    Running is for prey.
    Reputation: huckleberry hound's Avatar
    Feb 2015
    X-Fusion Slide. I've been running this fork now for about two years and love it.
    https://recycledmountainracing.com/c...nt=17812895361
    It is a simple set and forget fork. I am a 260# Clydesdale and I add 15cc fork oil to the air spring. It is easy to change the travel from 80/100/120mm. I have mine set at 120.
    Reputation: flipnidaho's Avatar
    I think Fox still sells new 1 1/8" steerer forks.
    Fox sells em? Prove it!
    (I'll check, just assumed they didn't. Thanks )
    --------- __o
    ------- _`\<,_
    since 4/10/2009
    Reputation: Harold's Avatar
    Wren suspension sells straight 1 1/8" forks. boost, not boost, multiple fatbike widths, multiple travel options. they're kinda heavy, but nice enough.
    Edit: Didn't realize this was in the 29er forum. I only know of the previously mentioned X-Fusion. I've seen some older Magura TS8 here and there, but only on closeouts.https://www.universalcycles.com/shop...&category=3983
    Feb 2015
    I think that Chain Reaction has some Manitou forks available in 1 1/8 straight tube but they are only 9mm QR.
    All good options folks.
    Schanks.
    --------- __o
    ------- _`\<,_
    Short-Change-Hero
    Reputation: gregnash's Avatar
    Believe that Manitou still sells the Marvel/Minute in that configuration and I know that I have seen SR Suntour offer it on the Raidon if not the Epixon.
    This is a treasure trove of options.
    Thanks everyone.
    -JCBs
    --------- __o
    ------- _`\<,_
    Feb 2015
    Another option but then again it is only 9mm QR is Rock Shox Recon Gold. RockShox Recon Gold TK 29" Suspension Fork - Performance Exclusive
    WillWorkForTrail
    Jun 2012
    I'll third the Manitou options. I've been running a Marvel comp on my steel SS frame for several years now, and it's a great ride, including a bar mounted lock out. For the money, the Manitous are no-brainers.
    Reputation: Feldybikes's Avatar
    For a higher end option, check out MRP.
    WNC Native
    Reputation: nitrousjunky's Avatar
    Quote Originally Posted by Feldybikes View Post
    I was also going to say, MRP still does 1 1/8".
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Nitrous-
    That's perfect.
    I had forgotten that MRP was willing to mix/match some good stuff.
    --------- __o
    ------- _`\<,_
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by Johnny Chicken Bones View Post
    There is no "good stuff" when discussing 1 1/8" and vintage swingset frames. Now if only you'd start riding like a vintage rider so I could keep up...
    Reputation: rob1035's Avatar
    Thanks Rob.
    Still trying to find a 15mm TA but that's a good option too.
    -JCBs
    --------- __o
    ------- _`\<,_
    For those of you just tuning in and looking for 1 1/8th forks-
    Make sure to consider MRP.
    Good stuff.
    MRP
    --------- __o
    ------- _`\<,_
    Bit of a revive to this older thread.
    I ended up buying new MRP forks. They were happy to provide 1 1/8th Loop SL forks.
    Zero miles on them (snowing outside right now) but I anticipate they'll be great.
    So now I am selling a pair of Rock Shox SID forks.
    29er, Thru Axles, 100mm.
    For Sale: 1 1/8th Rock Shox SID RCT3 29er Thru Axle Fork
    Please let me know if you have any questions.
    -JCBs
    --------- __o
    ------- _`\<,_
  1. Replies: 0
    Last Post: 08-03-2016, 12:44 AM
  2. 100mm forks vs 120mm forks ?????
    By Slapaho in forum 29er Components
    Last Post: 12-04-2014, 10:12 AM
  3. Replies: 2
    Last Post: 08-30-2013, 09:46 PM
  4. Upgrading 150mm forks to 160-180mm forks
    By timng85 in forum Shocks and Suspension
    Last Post: 09-24-2012, 11:37 AM
  5. 29er forks more likely to snap than 26 inch forks?
    By Alastair78 in forum 29er Bikes
    Last Post: 06-05-2011, 06:15 AM
Members who have read this thread: 23
