Results 1 to 26 of 26
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    Need New Skewers... And Suggestions
    My front skewer (qr) is bent and causes my rotor to scrape the pads... Result is my wheel, when spun, to go a maximum of 3 rotations. Such a Dagger, but it'll give me an excuse to get new skewers. Anyone have any good suggestions? I'm looking for something sturdy, not too pricey and hopefully with decent color selections. I don't want to spend a bunch of money, but i also don't want to have to buy a new set in a year (or less).
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Pricey, but it's the HIGHEST QUALITY QR skewer made. Consider it the last front skewer you'll ever buy:
    DT Swiss RWS MTB 100mm Steel Aluminum Lever | eBay
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Oct 2012
    I'd like to avoid spending ~$60 for a set, but I'd like to get a set of them. Does seem to have great reviews though.
    Jan 2013
    is there really a difference in performance in skewers? Not trying to be a smartass, serious question.
    Reputation: Ronnie's Avatar
    Any Shimano skewer. Pick the color you like
    I don't see how a bent skewer will affect the alignment of the disc, provided the 9mm. axle is properly seated into the dropout. The skewer clamps the hub onto the inside faces of the dropout. The disc is attached to the hub.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    I love Shimano Skewers.
    Also KCNC Ti or SS skewers are great as well. VERY lightweight (even the SS) and hold the wheel great. They do require a bit more hand force to close than some people are accustomed to, especially if you are used to a closed cam skewer like Shimano.
    The Mavic QR's are fantastic, pretty light but they also hold the wheels like crazy.
    Oct 2012
    Guess I could clarify... The nut portion of the skewer doesn't go on straight (I think it got cross threaded) and the other end of the skewer is uneven where it rests against the dropouts... SO when it tightens the wheel to the fork it cocks the skewer (and the wheel) in the setting. The causes the rotor to tighten into the brake at an odd angle and constantly rub. Sucks. Figured I'd take the opportunity to get new matching skewers... Something a little nicer? Will check out Shimanos for sure.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Shimano.
    SPP
    Rigid.
    Reputation: boomn's Avatar
    Another vote for Shimano
    Oct 2012
    Quote Originally Posted by Ronnie View Post
    Can only seem to find black or silver in any of the Shimano skewers. Am I missing something?
    Reputation: MudInMyEars's Avatar
    Apr 2005
    Nope, those are the colors. Enjoy them, they really are strong and reasonably priced.
    _____________________________________________
    Fat, drunk and stupid is no way to go through life, son.
    Oct 2012
    Any specific shimano recs? I don't want to buy the cheapest ones, but don't want to spend an arm and a leg.
    Reputation: azjonboy's Avatar
    Quote Originally Posted by patineto View Post
    I'll second the Mavic skewers. They are the only skewer I've used the last 7 years. I have them for every wheel set I own.
    If you're lucky enough to be in the mountains,
    you're lucky enough.
    Riding rigid
    Quote Originally Posted by GelatiCruiser View Post
    Third or fourth the recommendation for shimano. I don't recall much difference if any between most models. I know the XTR sometimes have the XTR cut out on the handle or a fancy X machined into them. The nut on the end of XTR is all metal (aluminum), I think XT might be steel insert in aluminum or plastic. The cheaper ones definitely use metal insert in plastic.
    But the internal cam design is stronger than most of the aftermarket external ones.
    If you want colors, Salsa skewers are nice.
    Sep 2012
    Hope or Shimano XT are the best I've used.
    Reputation: Joules's Avatar
    agree on both points: Shimano is the only company making skewers that aren't garbage, and I don't see how a bent skewer could cause your brake to rub other than not being able to actually clamp the wheel.
    Oct 2012
    Re: Need New Skewers... And Suggestions
    Guess I could clarify... The nut portion of the skewer doesn't go on straight (I think it got cross threaded) and the other end of the skewer is uneven where it rests against the dropouts... SO when it tightens the wheel to the fork it cocks the skewer (and the wheel) in the setting. The causes the rotor to tighten into the brake at an odd angle and constantly rub. Sucks. .
    It's not a bent skewer, it's the nut.
    Trail Ninja
    Reputation: Varaxis's Avatar
    Shimano. The only brand skewer I'd trust for MTB QR dropouts, especially with suspension and disc brakes considered. Others I'd trust on a per model basis, rather than a brand basis.
    We're all on the same ship, and it's sinking.
    Quote Originally Posted by Joules View Post
    Really? Shimano is the only company not making garbage for skewers ?
    Pretty braid statement. Possibly ignorant as well.
    Of the Nameless Rabble
    Another vote for Shimano.
    I like this place
    I've only only used XT skewers and have never had a slipping issue.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Shimano is great if you don't want to spend the money on the DT Swiss RWS, but the DT Swiss are truly the best.
    I like turtles
    Never trust a fart
    Reputation: frdfandc's Avatar
    Shimano if using standard QR's, or the DT Swiss RWS.
    Big Boy
    Reputation: texasnavy05's Avatar
    I like salsa. They come in pretty colors, and you can match your seatpost qr.
    -It's time to shred some mild to moderate gnar!!
    I have to agree that Shimano is far above the rest. I have a DT 9mm on the front of one bike, not all that impressed. Too bad I cant get an XT or XTR in 9mm
  1. Non QR Skewers / Bolt on Skewers for MTB
    By Angryhalfling in forum All Mountain
    Last Post: 06-25-2013, 02:07 PM
  2. Replies: 12
    Last Post: 02-11-2013, 05:48 PM
  3. Skewers
    By Frugaltravelguy in forum All Mountain
    Last Post: 02-05-2013, 08:36 PM
  4. 15 QR Skewers
    By cudarider in forum Wheels and Tires
    Last Post: 05-08-2011, 07:48 AM
  5. KCNC skewers Vs. J&L skewers
    By rc51kid in forum Weight Weenies
    Last Post: 03-17-2011, 12:30 AM
