Results 1 to 3 of 3
    Need Help with a SRAM Cassette
    I bought a NOS group from a forum member elsewhere, everything was new in sealed box except for the cassette. While it still seems brand new, when I removed it from the bubble wrap, the 14t cog was missing. The cassette is a XG-1080, a very nice and expensive cassette that I would like to use with my XO group. However given that the top 7 cogs are one connected piece, and the bottom three (11, 12, 14) are loose with integral spacers, it seems that I am hard up until I can find a 14t cog with that machined in spacer on the backside. SRAM said if I had the original packaging (which I do not) I could take it to a dealer for warranty (which seems sketchy anyway).
    Thoughts or suggestions?
    Or if anyone is holding on to a used cassette with that cog I need, I would like to purchase it from you!
    Bicyclochondriac.
    Can I assume you asked the person you bought it from what they know about this?
    Sounds like they are the one that is responsible here. They owe you a cog. Find out how much a replacement is and insist that they refund you that amount.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Do you still need a cassette cog, sklontz? PM me...
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
  1. Replies: 0
    Last Post: 01-14-2013, 07:54 PM
  2. SRAM 990 9 SPD 11-34 Cassette for $52 w/ FS
    By estabro in forum Where are the Best Deals?
    Last Post: 08-23-2012, 08:57 AM
  3. SRAM Crank X7 GXP 3.3 - Triple 10-Speed with 9 Speed SRAM cassette
    By kragu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-07-2011, 08:42 PM
  4. SRAM XG 999 Cassette
    By 55rpmasher in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-06-2011, 07:08 PM
  5. Sram XX Cassette come apart?
    By rfxc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-11-2011, 06:06 AM
