Results 1 to 3 of 3
    Dec 2012
    New question here. Need help finding the correct remote lever for SID SL fork
    I got a Rockshox SID SL fork from a member in the classifieds section and they didn't send the remote lever(s). Can someone point me in the right direction with a place to purchase or part number? I do not know what kind I need and when I did a search there seemed to be alot of different kinds. Thanks for any help.
    The Sram site has exploded views under RockShox with part numbers. LBS can order parts. You can also contact them for tech support.
    hi there, what year sid is it?
    if its pre 2013 you can use any RS pop lock or push lock.
    hope this helps.
