Results 1 to 16 of 16
    Reputation: ya29er's Avatar
    Aug 2013
    [FIXED] Misaligned headset, bended frame or fork?
    My bike headset has a side gap. Have tried to rebuild/ajust few times w/o success.
    When I turn handle bar at ~45 deg. it become a bit sticky. Specially turning left is noticably harder.
    Bearings are sealed an looks/works fine.
    Any idea what's wrong?
    Misaligned headset, bended frame or fork?-2.jpgMisaligned headset, bended frame or fork?-1.jpgMisaligned headset, bended frame or fork?-3.jpg
    UPDATE:
    A new top cup bearing fixed the problem. It still not perfectly aligned but it doesn't rub anymore and spins freely.
    Reputation: Captain_America1976's Avatar
    Mar 2005
    Is the steer tube bent? That doesn't look like a frame issue.
    RAKC
    Reputation: tigris99's Avatar
    Take the forks off use a good, true straight edge and check the steerer along its whole length for a bend. Would have taken a hellva hit to bend one.
    I would check everything including making sure the crown race is fully and properly seated too.
    Sent from my Nokia Stupid Phone using Tapatalk
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    OP - If you loosen the top cap and the stem bolts, can you push the headset cap down to where it's straight with your hand? It seems possible that the downward pressure on the stem/spacers from the top cap might not be even somehow.
    Is the star nut seated straight?
    Quote Originally Posted by tigris99 View Post
    That's a tapered fork, so the steerer is not straight by design.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Remote possibility but it could be a deformed upper bearing cover.
    bike tester
    Reputation: syl3's Avatar
    Nah that bearing cover is kinda brittle it would probably snap not bend.
    I would blame the bearing sitting wrong in the cup? Maybe some metal shavings caught underneath?
    Crown race improperly seated also a possibility as suggested
    No way it's a crown race problem.
    Bearing not seated right could make sense.
    Reputation: MartinS's Avatar
    Is this a new issue or has it been this way for a long time? If it has always been this way it is possible that the head tube is not faced properly from the factory. A good quality shop can easily reface the headtube of the frame, or it may be a manufacturing defect warranty issue.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Quote Originally Posted by MartinS View Post
    Ding ding ding, I believe we have a winner.
    It's highly unlikely your frame/fork/steerer tube is bent. Assuming the headset is assembled and adjusted correctly (first thing I would check), the next step is to knock the headset out and face the head tube (preferably top and bottom).
    That may be tough to do as not a lot of shops have the larger facing tools that tapered head tubes require (don't ask me how I know).
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    That looks like a semi-integrated headset. Does the bottom cup look like it is fully seated? Otherwise I'd agree, knock the cups out and see if you can see what is going on - if nothing then get it faced.
    Aug 2013
    Quote Originally Posted by Slash5 View Post
    Checked the bottom cup - everything looks exactly the same as in my other bike (Giant Trance X 26").
    The top cup/bearing's bed however definetely has problems. It's shape slightly oval.
    I've fixed it by putting 8-10 layers of folded kitchen foil.
    After a couple mins ride it didn't start rubbing the frame.
    Most likely the fix will be temporary because the foil is very soft material. Will put a can's top next time.
    This is the second problem w/ the frame. Previous time a suspension link just stapped. Bike is 1.5y old, 5k km.
    RAKC
    At 1.5yrs warranty is still very valid, get it to lbs and have them sort it since its seeming to be a manufacturing defect by this point
    Aug 2013
    Will do. Few months ago I got a replacement suspention link after it snapped. Hope Giant will replace the whole frame as well.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    Quote Originally Posted by ya29er View Post
    I just came back on after reading this a couple hours ago to say the same thing tigris99 said.
    I don't doubt that Giant will just warranty the frame for you.
    Good luck I hope they do.
    Would be a good time since they are going to tear it down anyway to clean and re grease bottom bracket and other bearings.
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Giants have lifetime warranties on the frames. Warranty work should be free if it's the LBS you bought the bike from, otherwise you'll have to pay to do the swapping (or do it yourself). New frames can take up to 5 business days to arrive if it's coming from the distribution center on the opposite side of the country (assuming you're in the US), but only a couple of days if it's the same coast.
    Aug 2013
    My LBS is not so 'L'. It's in Germany while I'm in Cyprus in a small town. I bought the bike online.
    I wish they will not ask me to ship the old frame back since it will be quite expensive for me.
    The frame is one of few things that are still original. I'm heavy (220lbs/100kg), the area is hilly and I ride fast enough to be in top (#2 last time) in island wide amateur races. Many parts have been snapped/broken and replaced already. If it was not yet replaced then it makes creaking sounds.
    The only handlebar and stem seems to be reliable.
  1. Replies: 0
    Last Post: 10-17-2013, 09:11 PM
  2. Replies: 8
    Last Post: 10-12-2012, 11:52 AM
  3. fork permanently flexed/misaligned??
    By bluebean in forum Shocks and Suspension
    Last Post: 06-08-2012, 03:13 PM
  4. Misaligned Aluminum Horst Link Frame… how to fix?
    By sealcove in forum Frame Building
    Last Post: 08-27-2011, 08:20 PM
  5. Replies: 6
    Last Post: 04-27-2011, 12:06 AM
Members who have read this thread: 4
