    Maxxis tires actual vs. advertised width
    Do Maxxis tires tend to not measure up to their stated width? I ask because the stock 2.4" Ardent front and 2.2" Ikon rear on my Yeti SB-95 measure 2.18" and 2.02", respectively, with my digital calipers. Perhaps it's the narrow'ish rims (DT Swiss XR 400)? Tires are currently at 30 psi with tubes (as I understand it, Maxxis uses tubes and 60 psi for measuring width).
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by savechief View Post
    It is nominal size. Actual size is always different, with every brand and model, and varies with the rim and pressures used.
    http://mtbtires.com/site2/tech/38-ge...and-other-lies
    mtbtires.com
    I've had Ardent 2.4 EXO and Ikon 2.2 EXO tires on my Flows. Both measured to size after having some time to "mature". They were run tubeless and measured at the widest point. Now, my Purgatory 2.3's? Those will likely need a Large Marge rim to measure the suggested width.
    MTB B'dos
    Reputation: LyNx's Avatar
    Maxxis measures size @ 60 PSI as you stated on a 28mm wide rim, so yes, in general the size will not be what's stamped on the side - I asked about this when I first started testing for them and that's what I was told IIRC. That being said, my 2.4" Ardent, tubeless on a Flow rim measures 59mm at the casing - I've had it for a while and as Car-Nut said, they grow after a bit at high pressure. No matter how the size runs (normally close enough), I love the Maxxis casings and compounds, work fantastic for our trails and worked well in CO as well.
  1. Actual Width of BOR/FRM 309T rims?
    By Le Duke in forum Weight Weenies
    Last Post: 05-06-2013, 02:41 AM
  2. BA Insulated Q-core advertised size vs actual
    By verslowrdr in forum Bikepacking and Bike Expedition
    Last Post: 01-28-2013, 10:58 AM
  3. actual widest 29er width tire
    By elistan in forum 29er Bikes
    Last Post: 12-01-2012, 06:37 PM
  4. Ground Control 2.1 actual width...
    By singletrkmind in forum Wheels and Tires
    Last Post: 05-25-2012, 02:10 PM
  5. road BB30 on mountain bike with 73mm actual BB width
    By 2silent in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-18-2012, 08:30 PM
