    Mavic Crossmax SLR 29Er Compatibility Axl
    Hi guys, i was looking at a Mavic Crossmax SLR 29Er Wheels 2013 Wheelset to buy. But my fork is a Fox 32 F29 100 CTD Fit Remote Fork 2013 White, 15mm, Tapered . And the custommer support from the store that i was pretending to buy the wheelset told me that this Wheelset is not compatible with 15mm Front Axl size. Is that correct ?
    If im using a Fox with 15mm i cant buy this SLR Wheelset ?
    Here is the link from the product. Thanks
    jensonusa.com/Mavic-Crossmax-SLR-29Er-Wheels-2013
    Reputation: ATX_fix's Avatar
    they are most definitely compatible. I have a Fox float 29 120 with 15mm axle and running the 2013 SLR's. you just have to pop out the caps on the hub, put in the thru-axle and you're ready to roll.
    maviczack
    Guest
    I just saw this. Sorry I was late.
    +1 on the above. They are 100% compatible. Your dealer maybe needs to brush up on the tech pages!
    Thanks !
    Thank you guys for the help here !
    Eimart
