Results 1 to 9 of 9
    Reputation: spyghost's Avatar
    Oct 2012
    New question here. Manitou tower pro 120mm straight crown/steerer assembly
    Does anyone know of an online seller that sells this part?
    The thing is, I got a tapered 120 and it didn't fit my 44mm headtube (butted). If it were a really straight 44mm, then it will fit...
    So I'll just replace it with a straight one until i get the chance to change my frame...
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    Y don't u just get an external bottom cup made to adapt. Ec44/40
    Oct 2012
    Quote Originally Posted by fishwrinkle View Post
    Yes I already have one... cc forty zs44/ec40... The fit of the headset is fine, but its the steerer that won't get in.
    For illustration purposes, see the image below. The top/bottom ends are 44mm
    From the bottom, as you insert the tapered steerer, as the larger portion of it gets deeper, it tends to bind with the narrow section of the head tube, hence unable to push the steerer completely.
    I'm left with about 10mm of space between the lower cup and the crown race and it won't get in. For illustration purposes, it binds somewhere between S and E above...
    ahhh i see, that is a conundrum. thats a bummer, but why cant you return the fork? i'm assuming that it's a used fork. manitou doesn't even list it in the service manual. i guess call hayes for a # and a dealer
    Oct 2012
    i can't return the fork because i don't live in US, plus its been in my stash for quite sometime already and I just got the chance to work on it yesterday.
    it's a PITA going through my LBS where I live, so I prefer getting from US directly; hence looking for an online seller.
    Reputation: moralleper's Avatar
    I do not think you can replace just the steer tubes on the towers.
    Oct 2012
    Quote Originally Posted by moralleper View Post
    yes, i'm aware of that... what i need is the whole upper... steerer, crown, etc.. but just the upper that's straight.
    reba's are scattered in the net, just having difficulty finding for manitou... might be just anyone encountered somewhere...
    Feb 2010
    Talk to Manitou direct. They are extremely helpful. Last time I needed a part for my Manitou Nixons that I couldn't find anywhere they just ended up posting it to me downunder for free. They will either help you out with the part or direct you to someone that can sell you one.
  1. manitou tower pro 120mm in black?
    By WVJon75 in forum 29er Components
    Last Post: 07-11-2013, 11:28 PM
  2. Alloy vs Carbon steerer/crown assembly for Rockshox SID
    By Bernard3rd in forum Weight Weenies
    Last Post: 10-08-2012, 07:15 PM
  3. 2012 Manitou Tower Pro with straight steerer?
    By Muffinhead in forum Shocks and Suspension
    Last Post: 08-25-2012, 03:39 PM
  4. Manitou Tower PRO 120mm FIRM spring
    By Crockpot2001 in forum 29er Components
    Last Post: 07-04-2012, 06:18 AM
  5. Jet 9 RDO+Manitou Tower Pro 120mm, 15mm?
    By Rich24 in forum Niner Bikes
    Last Post: 06-03-2012, 05:51 AM
