Results 1 to 8 of 8
Thread: Low Stack Stems
    Feb 2013
    Low Stack Stems
    I did some searching but could not find any recent info on this topic so here is the question. What stems are out there with a low stack/insertion height? The steerer tube on my fork is too short and I think this might be my best option. I already have a zero stack headset. I need the stack height to be as close to 30mm as possible.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Syntace FlatForce has a 27mm stack height. 22mm minimum insertion.
    Death from Below.
    I had a similar issue and went with a Rotor stem, its 31mm I believe
    Jan 2009
    thomson X2 36mm
    Reputation: GTscoob's Avatar
    Spank spike has a really low stackheight. Might be worth looking into a lower stackheight headset as well, even ZS headsets can come down a little lower with topcap swaps.
    How long of a stem do you need?
    Re: Low Stack Stems
    The Funn Funnduro stem is 30mm and looks good too. Had the same problem when I purchased a fork from flea bay.
    less than complete insertion isn't a problem. You can go with a 35mm stack height.
    undercover brother
    Reputation: tangaroo's Avatar
    Ragley Stubbing stem has a really low stack height.
  1. stems with low stack heights
    By dbraxis in forum Bike and Frame discussion
    Last Post: 12-19-2012, 07:50 PM
  2. XL SB-66 stack, reach
    By georgeslo in forum Yeti
    Last Post: 10-17-2012, 04:51 AM
  3. Low stack headsets and stems?
    By Mountain Cycle Shawn in forum General Discussion
    Last Post: 09-06-2012, 03:20 PM
  4. Carbon Stems vs Alloy Stems & Carbon Seat Post vs Alloy Seat Posts
    By torque29er in forum General Discussion
    Last Post: 12-05-2011, 10:01 AM
  5. M9 with Zero Stack HS and Fox 40
    By stunzeed in forum Intense
    Last Post: 11-18-2011, 03:42 PM
