Page 1 of 2 1 2 LastLast
Results 1 to 25 of 43
    Dec 2005
    Looking to upgrade hydraulic brakes - have questions
    I'm looking to change out my Teaktro Hydraulic Brakes on my 2014 Rockhopper Comp 29. The Teaktro's are extremely noisy. I was looking at the Shimano XT's. What parts or Shimano part numbers will I need to get the upgrade done.
    Thanks,
    Kevin
    Dec 2005
    +1 any insight anybody?
    Reputation: Nubster's Avatar
    You need the brakes. They come as a whole. Levers, hose, calipers, pads. You may also want to look at upgrading rotors while you're at it.
    Quote Originally Posted by Psycle151 View Post
    Friggin' coward. Give me a red chiclet instead of debating like a man. You don't deserve your green blocks.
    Now, THAT'S gonna hurt!
    Reputation: Oh My Sack!'s Avatar
    Definitely XT's!
    Apr 2014
    I just upgraded to deore M615's. The price was right and the performance is outstanding! Hard to beat the shimano brakes.
    Certifiably Crazy
    Reputation: Carloswithac's Avatar
    Feb 2012
    Quote Originally Posted by Nubster View Post
    Do rotors make that much of a difference? I'm running Tektros as well.
    2011 Felt Z5
    2013 Felt Edict Nine
    29er
    Used rotors have the old pad material embedded, and will make break in difficult. Get new rotors cheap off ebay
    Dianetics Junior
    Reputation: CBizzie's Avatar
    Mar 2011
    M785s for sure are what you want as Nubster linked. Check Blue Sky cycling or Nashbar as they often have good prices on these items. Don't forget you'll need Shimano adapters specific to your rotor size (sometimes other brands work, sometimes not in my experience)...great upgrade choice the brakes are stellar...
    Dec 2005
    What's the difference between the M785 and the M785-B ?
    I might be wrong but I think the B is the newer ones with finned pads. Those are the ones you want if possible. The other ones are fine and work great. The finned pads are just supposed to dissipate heat better. If nothing else, you can get the older ones and get finned pads next time you need to replace pads.
    And yes, a good rotor makes a difference.
    Dec 2005
    Thanks for the info everybody.
    Jun 2014
    The "B" stands for I-Spec B, which is essentially like Avid's Match Maker where the shifter and brake lever run off of the same clamp. I just put a new set of B spec XT's on my rig and they've been the best brakes I've ever used. My old Elixir 5's can't compare.
    Reputation: davesupra's Avatar
    Sep 2013
    I replaced the tektros with XT's on my Camber also, and it was a HUGE difference. I got the package deal where you get caliper/line/master as an assembly. I kept the tektro rotors, they work fine with the shimano pads.
    DaveH
    '13 Specialized Camber
    '13 9:ZERO:7
    '11 Specialized Hardrock
    Jan 2013
    Here is a very thorough write-up of what I did to upgrade my Tektro Auriga Comp brakes:
    The Frugal Mountain Biker: Part 6 - Brake Service & Upgrade
    Mar 2013
    Quote Originally Posted by Carloswithac View Post
    ice techs are quieter. also call cambria before you order from chain reaction. cambria often will match them and they pack items a LOT better. with chain reaction you get unboxed oem gear and it can be dinged up. blue sky is another oem take off outfit. if possible i try and only use jenson or cambria, service is stellar, packing is stellar and you don't have to wonder if parts will be missing. i've had blue sky send me headsets with the wrong race rings, chain reaction send cranks with dings in them. just annoying crap like that. with shimano brakes buy a retail box that comes with the right hose, right olives and isn't potentially missing parts.
    i think...and you should really ask to verify this. some of the brakes are made for i spec shifters and some aren't. could be what the B stands for. ipsec-b which is 2nd gen ispec
    Jan 2013
    The Tektro pads were downright pretty lousy. Almost any good quality set of resin/organic pads will be much better. Even Shimano resin pads are better. That is why I looked at EBC & Nukeproof because they are rated as some of the top brands. I am sure that there are other brands out there that are just as good or maybe even better. My swap to Nukeproof pads ended up solving all my noise problems, and I also ended up with more stopping power.
    Reputation: Bigb2000's Avatar
    May 2013
    There is also two different levers for shimano brakes. The one finger shorter levers and the longer touring levers. Not a big deal as long as both sides match. Can't beat shimano brakes. Chain Reaction has Deores for $56.99. If you can swing $200, cannot beat the x/t's period.
    Aug 2014
    I just swapped out the tektro's on my rockhopper for XT's. World of difference! Just walk into your LBS and as for a set of XT's for the front and back. They will give you what you need. When I got mine, the shop highly recommended using the SLX rotors so that's what I went with. Best upgrade ever!
    May 2013
    XT brakes are the best value in mountain biking.
    Jul 2014
    Piggybacking on the thread here. I just got a used 29er and I was bleeding the rear brake (Hayes Dyno Comp) I think I broke the piston seal so the brake doesn't work anymore. Instead of replacing with the same thing (eBay only at about $90 for one brake) I might as well use the opportunity to upgrade.
    Are the XT the best value here and I assume it is a good upgrade over the existing ones, which is very noisy.
    Also when ordering parts and choosing L/R brake levers, do you choose it from the perspective in front of the handlebar or behind the handle bar?
    Thanks in advance.
    29er
    Deore are better value, as for left right. The hand you use
    I thought everyone knew of the superior damping effects of the kitteh? I've been trying to find a wild kitten that would fit in my Fox DH series shock. Still searching.
    Mar 2013
    value depends on what you want and where you order from. merlin has the best prices i've seen. deore for 96 shipped, or slx for 125 shipped. xt is 187 if i remember right.
    i just ordered xt's last week to replace my elixir 1s which will be going to my winter bike build
    Feb 2013
    I have SLX front XT rear. Only difference is color and letters and some adjustment bolt on XT master that does nothing. So if anybody want to save money, go SLX. Deore also almost as good but does not come with finned pads, but you can buy them later.
    Jul 2014
    Thanks! I just ordered from merlin, great prices.
  1. Hydraulic brakes
    By Bradley Ellis in forum General Discussion
    Last Post: 09-18-2013, 09:18 AM
  2. Hydraulic Brakes?
    By mountainmatt in forum Brake Time
    Last Post: 12-18-2012, 10:27 AM
  3. Hydraulic Brakes
    By rickcin in forum Brake Time
    Last Post: 11-19-2012, 03:09 PM
  4. Need Some Hydraulic Brakes
    By KEITH21 in forum Brake Time
    Last Post: 03-08-2012, 08:15 PM
  5. Replies: 7
    Last Post: 04-11-2011, 10:19 AM
