Results 1 to 6 of 6
    Looking for a rigid 29er fork, not finding one with the specs I need...
    I've been looking for a rigid fork, steel or carbon, with a 465/470 A to C and either 15mm or 20 mm TA.
    Here's why:
    I have a wheelset (Pewter Chris King hubs, Arches) which I'd like to use on my wife's bike (Soma Juice) so I can get my wheelset back from her.
    Problem is that the front hub is set up for 15mm TA, LBS says that this hub can be converted to 20mm TA, but not to 9mm QR. I've researched extensively, but had no joy on finding either a fork that will work, or any kind of 3rd party conversion kit for the hub to convert it to 9mm QR.
    I'm not too interested in using a suspension fork as the smooth trails she rides doesn't warrant it - no need to add the weight and complexity.
    I'm hoping I've just overlooked some option here... :-)
    EDIT: 1 1/8 steerer tube needed for the Juice frame
    Reputation: Stopbreakindown's Avatar
    Salsa Cycles | Components
    CroMoto Grande Maxle
    Crafted of Salsa Kung Fu CroMoly, the CroMoto Grande Maxle delivers ultimate steering precision and torsional stiffness in a rigid fork. Suspension corrected for 80mm travel forks. The fork features 20 x 110mm spaced Maxle-specific dropouts and includes a front 20mm Maxle axle. A perfect match for a rigid 29'er mountain bike.
    20 x 110mm Maxle-specific dropouts
    Maxle axle included
    1-1/8 threadless steerer (260mm)
    468mm axle to crown
    45mm rake
    51mm ISO disc tabs
    Tire clearance = 90mm
    Black ED Coating
    1196 grams with full length steerer tube and including Maxle axle
    I knew it! I did overlook an option - I'd looked and the QR CroMoto, but missed the Maxle item.
    Many thanks!
    nothing to see here
    Reputation: Stevob's Avatar
    I see hills.
    I want to climb them.
    Thanks StevoB, unfortunately the RDO only appears to be offered in a tapered version - the Juice requires 1 1/8. Sorry, thought I had put that in the OP.
    nothing to see here
    my mistake, didn't read it properly
    I see hills.
  1. Replies: 21
    Last Post: 03-18-2013, 11:44 AM
  2. Rigid 29er fork
    By shift96 in forum 29er Components
    Last Post: 05-21-2012, 01:01 PM
  3. Rigid fork on a TransAm 29er
    By lifeis11 in forum Transition Bikes
    Last Post: 05-12-2012, 11:47 AM
  4. 29er rigid fork
    By gregmazo in forum 29er Bikes
    Last Post: 12-28-2011, 07:25 AM
  5. Rigid Fork Ti Fly 29er
    By jpbova in forum Motobecane
    Last Post: 04-26-2011, 10:21 AM
