Results 1 to 10 of 10
    Jul 2013
    looking for brake swap
    Hello I have promax mechanical brakes and they are very poor in every way. I ve looked through the forum quite extensively and it looks like the BB7 mechanical brakes are the pick of the brakes.
    my question is would i need to buy the complete brake kit(ie. rotors, pads, calipers etc) to swap or can i use some of the components from the promax brakes. the rotor is 160mm btw
    any input is appreciated
    thanks
    I have no experience with the Promax brakes, so I can't answer your question. I can tell you that I recently got the following BB7 kit, it's cheap and works great.
    BlueSkyCycling.com - 2012 Avid BB7 Disc Brake Combo Kit
    Order the set from Ebay out of China. It comes with everything but cables and levers. You might be able to use the rotors you have now but why bother. You can try the levers you have now but a good set of Avids run around $20.
    Jun 2012
    bb7 set - $55
    Avid BB7 Mechanical Disc Brake Caliper set
    levers - $14 or $19
    You may be able to use your current levers, Im not really sure
    Avid FR-5 Brake Levers Set - AAWYEAH Bikes and Bicycle Parts
    Avid Speed Dial 7 Brake Levers Set - AAWYEAH Bikes and Bicycle Parts
    Cables set - $13
    You can probably use your current housing, just swap out the cable. you might even be able to re use the cable, but you probably want to at least change the cable.
    Jagwire Brake Shifter Cable Housing Kit Road Mountain Bike | eBay
    Jul 2013
    looks like i need to check with my LBS about rotors. thanks for the input people
    Jul 2013
    Quote Originally Posted by gdkeys View Post
    does this come with both front and back brakes? its really cheap if it does coz everywhere else i look its about $80 per brake (x2 for front back)
    It includes complete front and rear brakes. Levers, cables, housing, ferrules, rotors, etc. are also included.
    SLX front and rear-- $70 for the front, $90 for the rear.
    BlueSkyCycling.com - Shimano SLX M666 IceTech Disc Brake w/Adapter
    BlueSkyCycling.com - Shimano SLX M675 IceTech Disc Brake w/ Adapter
    Check the Brake section for reviews. Just buy once.
    Jul 2013
    If you shop around you can get the BB7s pretty cheap. Go ahead and get their levers while you are at it, you'll like the adjustability of them. I bought a set of BB7s and used my stock levers and they stopped the bike just fine. I decided to buy the Avid levers later, should have just bought them from the beginning. The adjustments allow you to fine tune them exactly as you like.
    ready to ride
    Reputation: mattnmtns's Avatar
    Quote Originally Posted by eb1888 View Post
    This!!!!!
    I got pretty much this same setup to replace some avids that I didn't like or trust. Way better than the avid 3,5, or 7s and won't even compare to the bb7s. You won't regret going with the slx.
    Sent via my heady vibes from the heart of Pisgahstan
  1. Replies: 7
    Last Post: 11-07-2012, 08:05 AM
  2. Brake swap on 2010 enduro
    By ihaveagibsonsg in forum Specialized
    Last Post: 08-21-2012, 09:48 PM
  3. Specialized Camber brake swap
    By crclark27 in forum Brake Time
    Last Post: 11-01-2011, 12:55 PM
  4. '11 Camber Elite 29er Brake swap
    By crclark27 in forum Specialized
    Last Post: 10-31-2011, 09:47 AM
  5. Fork swap now brake drag?
    By cbzdel in forum Beginner's Corner
    Last Post: 03-17-2011, 08:46 PM
