Results 1 to 9 of 9
    Lightweight fork upgrade need suggestions!
    This is a double post. I put this question in the Specialized thread and although got 1 good suggestion, did not get too much other info so I figured I would try here as well.
    I have a new 2013 Stumpy Comp Carbon 29er HT with the solo air front fork. Although it is decent for now, I am possibly looking for a new fork. Needs to be a minimum of 90mm travel, but would rather have 100mm, and would need to be lighter than the solo air if possible, I heard these forks are very light already so I am not too sure.
    Currently the bike weighs in at 21lbs. 3oz with pedals.
    Suggestions would be great, thanks!
    Attached Thumbnails Attached Thumbnails Lightweight fork upgrade need suggestions!-mothers-day-001.jpg
    2011 C-Dale Flash 1 650b
    2013 Scott Genius 930
    2015 Charge Cooker Maxi
    You may want to prioritize return on investment. The wheels use a heavy non star ratchet low end rear hub. The front doesn't matter as much. A light wheelset would give you more performance and lose more weight. Roval Control 29 Carbon with brass nipples would be good.
    Sorry I should have listed my current upgrades, but the bike already has a brand new set of carbon Rovals on it, XX1 front, S-works post, Haven carbon bar, Loaded Stem and Skewers, XTR pedals, ESI Chunky Foam grips and SLX brakes with Alligator Serration Rotors. I am just looking for a lightweight fork suggestion should I decide to go that route...
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by A-Ray View Post
    Your fork is pretty light as it is!!!
    Going rigid would yield the lightest fork, but ouch! Or a Lefty, but you'll need a new front wheel.
    Sid XX World Cup Solo Air Carbon is 1485g
    Six XX Solo Air is 1633g
    2013 Fox Float 29 weighs 1.56kg with Tapered 1.5" and QR15 axle
    2013 Fox Float 29 WITH REMOTE weighs 1.67kg with Tapered 1.5" and QR15 axle
    2013 Fox Fork weight?
    lightest 29er suspension fork - Weight Weenies
    A-Ray, what size chainring are you using upfront? Pete
    Yeah, carbon rigid or a Lefty are the only worthwhile options in my opinion. Anything else will be mostly a lateral move.
    Quote Originally Posted by peterk123 View Post
    I am using a 32 and it works great for everything I ride, not to mention this setup reduced the weight of my bike a full 1lb. 3oz....
    Dec 2008
    +1 on the lefty I have a carbon xlr on my Lynskey and love it.
    Reputation: duggus's Avatar
    A 21 pound 29er... and you want it lighter? I think you are just being OCD
  1. Suggestions on the right fork upgrade for my Marin
    By J Crew in forum 29er Components
    Last Post: 01-09-2013, 09:11 PM
  2. Lightweight 50mm stem suggestions?
    By rusty904 in forum All Mountain
    Last Post: 05-15-2012, 07:15 AM
  3. 2010 Response needs Fork Upgrade suggestions
    By colotl in forum Diamondback
    Last Post: 02-17-2012, 06:43 AM
  4. 2010 Response needs Fork Upgrade suggestions
    By colotl in forum Shocks and Suspension
    Last Post: 01-06-2012, 02:37 PM
  5. Lightweight Rigid mtb fork suggestions?
    By Hardtailforever in forum Weight Weenies
    Last Post: 06-16-2011, 08:54 AM
