Results 1 to 8 of 8
    Mulleticious
    Reputation: BigwheelsRbest's Avatar
    Which lightweight 100mm 29er fork?
    Running a Lynskey Ridgeline 29SL singlespeed rigid with a carbon fork at the moment, but it's beating me up. Thought I'd try a suspension fork but don't want to give up too much weight advantage - any suggestions?? (tapered steerer)
    Manitou TP, 2012 dual air Reba, 2014 SID---
    "New for 2014, the DIG Valve has independent low-speed and high-speed compression settings, as well as a aluminum rebound shaft for a bit of weight loss over the old system. It's retrofittable to previous models, and can make a huge difference in the performance of a fork."
    Maybe this would help a 2013 solo air Reba.
    Just Ride!
    Reputation: kustomz's Avatar
    I am considering the RockShox Sid RLT with PuchLoc, tapered and 9mm QR that I found for $585 shipped
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Lefty
    MSH
    MSH is offline
    Reputation: MSH's Avatar
    Jun 2005
    I have a brand new 2013 SID RCT3 15mm thruaxle tapered $599 if you are interested. I have a perfect eBay rating. PM me if you are interested
    Mulleticious
    Quote Originally Posted by eb1888 View Post
    What was wrong with the 2013 solo air Reba? (I see they are going cheap at CRC)
    Mulleticious
    Found a half price offer on a 2013 SID XX World Cup - very light at 1572g (including maxle). Thoughts?
    Quote Originally Posted by BigwheelsRbest View Post
    Light but only solo air, so like the Reba your tuning options have been dumbed down over the 2012 model.
    But 2014 parts are coming.
    The new DIG valve is backwards compatible for improved low and high speed compression tuning.
    The price also seems high.
  1. Element 29er with 120mm fork vs 100mm fork
    By field_c in forum Rocky Mountain
    Last Post: 11-10-2016, 04:42 PM
  2. Lightweight 29er 100mm forks
    By LJJ in forum 29er Bikes
    Last Post: 06-03-2011, 09:31 PM
  3. Lightweight XC fork (100mm) with V Brake?
    By hardwarz in forum Beginner's Corner
    Last Post: 05-07-2011, 08:07 PM
  4. Replies: 2
    Last Post: 05-06-2011, 12:51 PM
  5. Replies: 0
    Last Post: 05-04-2011, 06:37 AM
