Results 1 to 28 of 28
    Kris Holm Freeride Rim
    Does anyone here have any experience with the new 29" 47mm wide Kris Holm rims?
    Missouri sucks...
    Can you convert them to tubeless? lol
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    i really wanted these rims when building my latest wheels but they were only avail. in 36h at the time.
    Try this: HTFU
    Quote Originally Posted by rockcrusher
    I was hoping for 36h
    These would be perfect for my next build!
    Reputation: dh_swing's Avatar
    Quote Originally Posted by DFYFZX
    Great rim, and extremely easy to go tubeless -- either traditional ghetto or tape.
    Reputation: njbiker66's Avatar
    Where?
    Where can you get or find this rims at??
    Quote Originally Posted by dh_swing
    Have you run this rim?
    How do you get around the lack of a weld when running tubeless with only tape?
    Quote Originally Posted by njbiker66
    UNICYCLE.COM
    Full Tilt Boogie
    May 2005
    I'd be interested in reports as well. I've wanted a set of these for no really good reason for a while. They certainly look like they would be cool rims with big fat tires at low pressure. I was thinking they would be nice for a 29er fat bike light for hard snow conditions.
    I sell bikes here. Check out the Blog here. Facebook.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Unless they've been changed recently, that rim has been available for ~2 years. Haven't ridden them though I've built a few. Not a fan, actually. Structurally they're indestructo, but they have a fatal flaw in that the concavity of the rim plus the offset drilling of the spoke holes means that *unless you're lacing to something with massive flange width* you end up with all spokes taking a harsh bend just before entering the rim. Sub optimal for long term durability.
    But if you're going with wiiiiide flanges, carry on and use the lightest spokes you can find. These rims are massive overkill for all but superclydes.
    MC
    Quote Originally Posted by mikesee
    MC
    How wide is wiiiiide? I was thinking a 150mm rear (Hadley or I9) & 135 front (likely Phil Wood) for hubs...
    Do you have a different ~50mm 29er rim to recommend?
    Quote Originally Posted by jncarpenter
    How do you get around the lack of a weld when running tubeless with only trae?
    Yup. I run both the 26" and 29" versions on my mountain unis. Uni hub spacing is typically 100mm with no discs (recently, discs have come in vogue), so I appreciate Mike's comments on offset spokes as it would apply to disc hubs. But for what I use them for, wonderful quality, wonderful feel. Also per Mike, 14G doubled-butted spokes do seem to give the rim a nice lively feel.
    I run mine ghetto with a 20" and 24" split tubes respectively. They just plain never leak. Concerning tape, here is a fellow muni'er who has had great success with this method:
    http://unplannedismounts.com/2009/09...ess-kh24-guni/
    Overkill for mountain bikes -- yeah, probably. But what a great rim!
    I have a set of the 38mm KH rims that I have been meaning to build up, but since I could save nearly 1.5 lbs of rim weight AND gain nearly another 10mm of rim width, I was considering the freeride rims.
    I do see the issue with the offset spokes tho, and would prefer a rim without a machined braking surface as well.
    Decisions, decisions...
    Aug 2003
    Dunno how wide you'd need exactly. Guess you're the guinea pig!
    The only 50mm 29" rim I've used is the Speedway Uma. Fine on snow, with big tires, at low speeds and low pressures. But for MTB use, on dirt, riding hard? No effing way would I use it. My 110# wife is the ideal customer for it--IMO anyone heavier than ~150# could probably wad 'em up in a weekend.
    MC
    MC
    Gotcha...thanks for the thoughts.
    When you laced up the wider KH rims...did you cross over the rim center, or did you lace the offset hole to the same flange side?
    I'm thinking of lacing up the 38mm set...it's not the ~9mm width I will miss as much as the ~300g per rim I will inherit
    Here are a few crappy shots of the 29 and 26 rims closeup. It would seem the spoke angle IS more severe on the 29" rims. This makes sense when if I think about it a bit.
    Flange-2-flange on these hubs is 73mm. First two photos are the 29er, third is the 26:
    Aug 2003
    If you look at the concavity of the rim (and the resulting angle of the eyelets) you'll see that crossing over would make it worse, not better.
    Regardless of which one you choose, be sure to build up the rim cavity with a few layers of something thick--like foam tape. The KH rims fit tires pretty loose these days. I used to love that rim before the current crop of fatties came out.
    MC
    Reputation: jollynut's Avatar
    I just dropped a pair off at the shop to be laced up to some hubs. Acquired in anticipation for a snowy riding season here in northern Japan.
    Underskilled
    Reputation: CaveGiant's Avatar
    I am a HUGE fan of these rims, I am a clyde who rides quite hard (broke 5 rear hubs and a few frames including one WFO).
    Wheels have always been perfect. They are not very heavy for what they offer; my way of looking at them is they are very light. My rational is that the rim is so wide you get a larger footprint with a smaller tyre, so you can drop a tyre size and get similar traction (this saves more weight than the rim weighs).
    Very VERY VERY laterally stiff, no deflection at all. However there is a bit of flex from direct impact which protects the rim.
    Kris is also a nice guy,
    I have heard Mikesee's complaint about the spoke angle, but just do not get what the issue is. Taking in to account I am an engineer who works in R&D you would think I should get it....
    Anyway been running these for a couple of years with 0 issues. I have had 5 rear hubs fail in that time. You do not even need to carefully take the spokes off as the rim is solid. one of the best pieces of kit on my bike.
    good quality, good value and made by (ok for) a nice guy!
    Why would I care about 150g of bike weight, I just ate 400g of cookies while reading this?
    Reputation: Tripower's Avatar
    Jan 2011
    I have one on the back of my Ti Jones.
    Underskilled
    Oh forgot to add, mine have been the easiest rims to tubeless. I only use split tube/glue method as it is SO fast and reliable.
    Nov 2008
    The apparent spoke angle issue has not been an actual problem for me either. I've run KH 47 29er freeride rims (very capably) laced with DT Swiss spokes on a dirt touring rig for two years. I've run them on several tours on rocky terrain under very heavy loads - the sort of stuff that destroys bikes and bike parts. I've had zero problems with the spokes or rims; they ride great, especially under load, and have been 100% bomber. I have had one rear hub fail -- a broken axle, snapped cleanly in half; that the hub failed first indicates that the spokes, despite the bend, were not the weak link in the wheel build. I know of no other 29er rim that compares in terms of strength and durability.
    These Kris Holm 47mm 29er rims have been absolutely brilliant for riding in the snow here in northern Japan. Last winter we had snow on the roads for around 4 months straight. Being able to drop the pressure in my Schwalbe Ice Spiker Pro 2.25 tyres really low for the soft road-edge snow was awesome. It was all about stability for me; the tyres end up having more of a 'square' profile which was great in the soft snow.
    It can usually be done by human power | www.14degrees.org
    Reputation: zipzit's Avatar
    Aug 2005
    oops. duplicate entry.
    Aug 2005
    I realize this is rather an old thread. The latest Surly Krampus offering and the Jeff Jones fat front thing got me thinking of getting a little more goosh in my tires, and jump over to all rigid. I'm considering these 29er Kris Holms rims for my Karate Monkey (KM) as well.. What other tires have you guys tried on these rims on the KM? Will a Continental 2.4mm Trail King fit in that frame on the 47mm Kris Holm? (or asked another way.. are there any tires that won't fit the rear of the KM with the 47mm Kris Holm rim because they are too wide for the chain stays??)
    many thanks in advance to all for your responses..
    zip.
    Quote Originally Posted by zipzit View Post
    I currently have Schwalbe Big Apple 2.35's on the Kris Holm rims, and they fit fine at the back, with somewhere between 7mm and 10mm of clearance on each side of the tire at the back....I guess it depends on how knobbly the Trail Kings are, as to if they'll fit or not perhaps?
    Aug 2005
    I just received my 29er rims. They appear to be drilled for Schrader Valve system. (Presta = 6mm, schrader = 8mm diameter, right?) Are all of you guys using the Kris Holm tubeless using the ghetto split tube system? There are also numerous small holes drilled very close to the edge of the 'valley' on the rim in a couple of places. I'm guessing the small holes are used for a fixture of some sort (drill fixture? Close the gap fixture?) See photos. Anybody doing the gorilla tape thing or do you have to do split tube to make these work? I'm thinking the extra holes in the edge of the rim, and the schraeder thru hole will force me into ghetto split tube. I was so hoping to use just tape, and some sort of presta tubeless replacement valve stem. (Heck, not even sure if my camelback pump works schrader valves...)
    thanks, zip.
    Attached Thumbnails Attached Thumbnails Kris Holm Freeride Rim-kh-rims-1.jpg
    Underskilled
    Just use a schrader split tube, it saves a lot of problems.
    Schrader is the better one for tubeless as they all have a removable stem for sealent injection.
    One nice trick is to glue the tyre to the strip.
    Use a good quality contact adhesive.
    This not only makes mounting much easier, reduces burping, but also means the rim strip stays with the tyre when you remove.
