Results 1 to 35 of 35
    www.bigrobracing.co.uk
    Reputation: robdeanhove's Avatar
    Dec 2005
    Just Got Some Reynolds Carbon XC 29er Wheels!
    I just had to share! I've just taken delivery of some Reynolds 29er Carbon wheels. I'm super excited.
    Not only are the rims lovely and wide, but they're light too :-) Should stiffen up the front end of the bike and give awesome steering accuracy. It'll be interested to see if I can feel the difference at the back too. Off to ride them now, but I just had to share! They come with a tubeless style rim internal shape and were supplied with adaptors for all possibilities of hub and tubeless valves and tape. Top work by the guys at Reynolds :-)
    There are a few more details and specs on my blog HERE
    For those of you (most of you?!) who just want to see the black hoops of speed; here they are:
    And now: RIDING! :-)
    I've had a pair since January. I've put about 100 miles on mine and they are awesome.
    Reputation: bholwell's Avatar
    Oct 2007
    What is the internal width?
    Can you get the decals off??
    Reputation: Noclutch's Avatar
    Jun 2010
    24 spokes? Interesting.
    Nice.
    I think you might need a longer valve stem though.
    Dec 2005
    Quote Originally Posted by bholwell View Post
    Officially they're 21mm internally, but I used 25mm tape as the 21mm tape didn't quite reach the sides, so they may even be a little wider in reality
    Dec 2005
    Quote Originally Posted by anthonylokrn View Post
    Nice.
    Cheers, I thought so too!
    Longer valve stem is sorted. In there at the moment are a couple of tubes I chucked in to get me rolling. The tubeless valves that were included as standard are a good chunk longer and protrude a sensible amount through the rim.
    Dec 2005
    Quote Originally Posted by Noclutch View Post
    With a super stiff rim, there will be less flexing and less fatigue of the spokes, this should give me better handling and lower weight and enables the spoke count to be low whilst keeping the strength up.
    The loads, which are taken on only a few of the spokes at any one time on a spoked wheel, are distributed to more of the spokes, and more evenly, with a stiffer rim. As the peak spoke tension on the most highly loaded spoke should be less with a stiffer rim, I am expecting better durability than my 32H Crest rims.
    Spoke tensions seem nice and high and extremely even out of the box.
    Dec 2005
    Quote Originally Posted by Jubas View Post
    Yes, it appears the decals could be peeled off to leave the bare rim, if you want to do that
    11 is one louder than 10
    Reputation: Green Giant's Avatar
    did you compare actual weights to the MFG stated weights?
    hows the rear hub engagement?
    "The thing is, Bob, it's not that I'm lazy, it's that I just don't care."
    Jun 2010
    I like them! And the price here ain't that bad!
    On sale for $1200 at Colorado Cyclist.
    Dec 2005
    Quote Originally Posted by Green Giant View Post
    They came fitted with rim tape, so I weighed them with this fitted, but they came to 1601g on my (un-calibrated) kitchen scales, 5g within the stated weight and way more accurate than I would dare to claim my kitchen scales measurement could possibly be, and this MUST be down to the rim tape, Notubes reckon 2-3g/wheel for tape so they're within 1g!!!!
    This has to be a first for a MTB part to weigh the same as the stated weigh, a MASSIVE thumbs up to Reynolds (who could have easily quoted 1515g +/- 5% for example).
    I am a very happy boy.
    Cassoulet forever !
    Reputation: 20.100 FR's Avatar
    To these have a UST rim bead like ENVE ?
    Frenchspeaking 29"ers community site http://VingtNeuf.org
    Dec 2005
    Quote Originally Posted by 20.100 FR View Post
    Yes, mine has a UST style rim profile with raised/locking sections at the outside for a secure tubless setup. Shown there with a tube in, but they're now running tubeless (non-UST tyres with sealant) just fine
    Mar 2005
    They're just close to cheap enough to consider over Mavic's or e*Thirteen's. Any idea if the front hubs work with 20mm ? Some places list the front as 15 or 9, other's say 20mm. My fork restricts me to 20mm.
    How's the rear hub ? Do they make their own ? Seems like that was the weak point of the Haven's.
    Dec 2005
    Quote Originally Posted by ben2e View Post
    Axle compatibility: You don;t need to ask on internet forums, the answer is on their website HERE, the front hub is compatible with 9mm QR, 15mm thru-axle AND 20MM thru-axle
    Rear hub, I don't know and haven't taken mine apart, but I have heard they use the DT system, which I have had great experience with. The reason I've not taken mine apart is that it's been totally worry free, which might be part of the answer you were looking for.....
    Mar 2005
    I saw the mention on Reynolds site but it's different then the spec mentioned on CC which made me believe they might have some older version. Hope that the Reynolds site is the correct one !
    Mar 2005
    Just spoke to Reynolds. They just came out with a 2013 model which is the one on their site. CC has the 2012 model. Only the 2013 one will work with 20mm front. There are other minor differences. New one has straight pull spokes, different nipple threads but the same rims are on both. Old model is a great buy if you have a 15mm fork and can be converted to 142x12 rear.
    It ain't easy being Green
    Reputation: sdcadbiker's Avatar
    I purchased a pair from CC, put them on my new Superfly and couldn't be happier. I'm running them tubeless with Bonty 29.3 tires and they are super-light and stiff. I was concerned at first that 24 spokes wouldn't be enough but it simply hasn't been an issue, at least for the couple hundred miles I have ridden them. So far so good
    Hope this doesn't come out the wrong way, but my question is about the weight of the Reynolds. I know carbon wheels is more than just weight, the stiffness is insanely great, but from a weight weenie perspective did the near-1600 gram mass of the Reynolds kind of a little remorse into the purchase?
    Say the Reynolds are $1000. Often used Rovals can be found for around $1100 and they are anywhere from 1440 to 1520-ish.
    Chinese carbon wheels can be built up for about $1000 with highend hubs such as DT Swiss 240 and weigh about the same as the Reynolds with their presumably inferior hubs. Notice I didn't put "cheap" because the rims are indeed high quality and by the time everything is built the $800-$1000 wheels are a big chunk of $$$.
    Again, please do not read this in a negative tone. I'm still on the fence about buying new carbon wheels (165 pounds before gear, aggressive xc racer, using ZTR Crest and looking for more stiffness). I can get local Performance store to price match Colorado Cyclist and I'd get 10% back and their guarantee/return policy.
    No offense taken! Put it this way; After I stripped the tires off Bonty wheels that came with my bike and put them on the Reynolds, the Reynolds still weighed less than the Bonty's (I'm guessing and probably exaggerating but not by much), so I came out way ahead. You are correct that I could have purchased a used set of Rovals for ~$1200 (Ebay), but used by who, and for what? As I said, right now I couldn't be happier; maybe in a year I'll think differently.
    Quote Originally Posted by westin View Post
    But come with inherent risk since there is no warranty on second hand pair.
    OG Ripley v2
    Carver 420 TI
    One has to compare apples to apples on rim widths. The Reynolds rims are 29mm OD and should be compared to Enve AM wheels. If you do this the weights are spot on. I trust Reynolds years of carbon tech over Specialized and the Chinese rims for sure. J
    Dec 2005
    I picked up the 2013 reynolds wheels for $1500 bucks and the wheels are great. Look way better than the 2012's, and they are light, wide and stiff as heck. You can tell if they are 2013's as they have the new red graphics and red hubs with wider flanges for stiffness. Width and weight wise, they are between Enve XC's and AM's.
    Reynolds is a mainstay in the carbon road bike wheel industry. As a matter of fact, the ENVE founders used to work for Reynolds before founding their company. Both companies are based in Utah. I would probably choose the ENVE's price being equal as I don't generally like proprietary hubs, but the value of the Reynolds won me over hands down.
    Jan 2011
    OP- do you notice any tire flex with the Ikons on the Reynolds? I ask because I have Ikons on some Black Flags now and there is some serious flexing going on and I'm trying to trouble shoot between the tires and wheels. I have been considering the Reynolds if it is indeed the wheels.
    Dec 2005
    Quote Originally Posted by The Novice View Post
    I use 2.2" Ikons on my Reynolds and I find they don't roll around, but the Reynolds I am sure are a wider rim than the black flag rims. Having said that, tyre pressures are easy to change to firm up the tyre feel.
    I've not ridden the black Flags, but with the same tyre, my Reynolds feel noticeably stiffer, particularly at the front, compared to my NoTubes Crest rims, and that's with the same fork, hub and bar setup.
    I'd recommend experimenting with slightly higher tyre pressures first before splashing >$1000 on some wheels though
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Who else is running them & how are they going.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    I've got em and really like them. I'm running them on my Milkmoney SS. I've had them since Feb and probably have 300 miles of single-track on them. They replaced a set of Bonty Dusters rims with AC hubs. Compared to the Dusters, they are super stiff and will hold a line much, much better. I thought the American Classic hubs rolled forever, but the Reynolds seems to be just as good. I looked at Enve, Specialized Rovals, and these. I went with the Reynolds basically on price only because I came across a road wheel set with a powertap that I couldn't pass up...
    They are set up as 135mm right now but I have used the conversion kit for 142mm. It took 10 seconds to swap and they ran great on the 142 frame as well.
    Dec 2005
    Not the best pictures in the world, but here are my Reynolds on my Big Top. I just threw on a new Nobby Nic 2.35 on the rear.
    Great wheels so far!
    Attached Thumbnails Attached Thumbnails Just Got Some Reynolds Carbon XC 29er Wheels!-front-shot.jpg
    lamer
    Reputation: llamma's Avatar
    I'm thinking about picking up some new 2013 Reynolds Carbon XC 29er wheels for $1500. Anybody regret their purchase? How are the hubs holding up? How do they sound compared to Hope hubs?
    I've been looking at their site, but can someone confirm that the front can do 20mm and the rear can do 135x10 TA? I'm pretty sure the front does 20mm, but I'm more concerned about the rear as I'm using a DT Swiss RWS 10mm thru bolt skewer on my RDO.
    Carbon & Ti rule
    Quote Originally Posted by llamma View Post
    Hi, I'm running them on my 2012 Jet9 RDO with 135 X10 with RWS like you run.
    The wheels come with standard for the rear, QR & 135 x 10 & 142 x 12 & it is only the end caps that need replacing not the hub axle.
    The front wheel comes with Standard QR & 15mm & 20mm adaptors & once again end caps only.
    They are a little quieter than than the hope pro 2 hubs I have owned.
    They set up tubeless fine, I used 1 lap of the tape supplyed but will go to 2 laps just to make the tyres fit a bit tighter for the low pressures I like to run.
    I haven't had mine that long & like them alot, That said I do miss my I9 hubs & have ordered a set of I9 wheels with the Reynolds rims with XX1 free hub for my 2013 Jet9 RDO ( Reynolds are making a XX1 free hub but won't be here till Feb )
    I like wide rims ( Flows etc ) so they have been a good change for me.
    Dec 2011
    why did you choose those Reynolds wheels over the other leading carbon wheelsets
    Dec 2005
    Quote Originally Posted by Bradpreo View Post
    A few reasons:
    1. They're light enough to race on (but weight is not the most important factor)
    2. They come as a complete wheelset, i.e. they guy that designed the rim selected the spoke, hub and nipple
    3. They come with a tubeless profile in the rim
    4. The rim is wide and gives a stable tyre and the ability to really utilise a 2.2" or wider tyre at low pressures
    5. The hubs I believe use the lovely and well proven DT ratchet
    6. They're very, very stiff
    7. These are designed, from the ground up, by Reynolds, not out of a mould. The only other option for me was the Enve rims
    8. They're far better value that the Enve rims
    9. Even though they're a "factory" wheelset, they use commonly available DT revolution spokes and DT nipples, so if I damage them in a crash I can repair them easily and quickly without waiting for special parts
    Not in priority order, but that just about sums it up
