Results 1 to 3 of 3
    Reputation: Dummyrunner's Avatar
    Issues setting up new Reba with Hayes Stroker and 180mm disc.
    Just put a new Reba on my Inbred and I'm having some issues around the setup with my existing parts. Hayes Stroker with 180mm disc is causing some issues with the caliper rubbing against the disc. I'm using a shimano adapter for the spacing but there isn't quite enough sideways movement in the caliper itself to centre it on the disc. Was thinking I may need to file out the lateral adjustment holes of the calipers unless someone can give me advice on something I else I may be doing wrong.
    Incidently, the reason for the shimano adapter is because the dude who supplies Hayes stuff here wanted $50 for one and couldn't guarantee it would actually be the right one. The shimano one is ok but had to use some washers for a bit of extra spacing.
    The actual caliper casting is rubbing on the disk? Or the pads are dragging?
    The adapter shouldn't make much difference - you sure it's facing the correct way?
    Sorry, I should have been more specific. With the washers giving me the extra spacing the caliper itself is ok, it is the actual pad dragging on the disc. It isn't alot but my pads are half worn and if I put a new set on it's going to be even worse. Was wondering if anyone alse had similar issues.
  1. Hayes Prime Pro vs Hayes Stroker Trail
    By feltbee in forum Brake Time
    Last Post: 01-22-2015, 12:26 PM
  2. Replies: 4
    Last Post: 06-05-2013, 08:37 AM
  3. Hayes stroker ace
    By schlockinz in forum Downhill - Freeride
    Last Post: 11-21-2011, 11:13 AM
  4. Hayes Stroker Trail
    By Doughnut Spaghetti in forum Brake Time
    Last Post: 11-01-2011, 03:36 PM
  5. Hayes Stroker Ace or Hayes Prine Pro
    By pumaking in forum Brake Time
    Last Post: 01-02-2011, 05:46 PM
