Results 1 to 5 of 5
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    Hydraulic Disk Brakes
    This weekend I will be bringing my new Cobia to a trail in Connecticut, which requires the removal of the front wheel for storage in the car (Audi S6 sedan). I have heard that the hydraulic brakes may brake if the rotor is not in the caliper. Is this true?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Yes. Insert the little red pad spreader in between the pads when the wheel is out for transport. If you do not have one the LBS can hook you up.
    ballbuster
    Reputation: pimpbot's Avatar
    Quote Originally Posted by CannondaleF9 View Post
    The worry is that if you squeeze the lever with the rotor out, the pads may get pushed together. Nothing's broken, you just have to push the pistons back in the caliper, gently, evenly and squarely. It ain't that hard.
    But yeah, put a pad spacer in there if you take the front wheel out. You can use any old hunk of flat clean metal, wood, paper or plastic around 2mm thick.
    29ers Forever
    Nov 2012
    Quote Originally Posted by pimpbot View Post
    Would a piece of cardboard work?
    Reputation: bikewerx's Avatar
    Dec 2012
    I have used cardboard or a folded business card in a pinch.
    B
  1. Hydraulic disk brake problem
    By Ali_ in forum General Discussion
    Last Post: 12-18-2012, 06:18 AM
  2. Replies: 51
    Last Post: 06-05-2012, 01:07 AM
  3. Replies: 9
    Last Post: 02-21-2012, 07:38 PM
  4. a deal on disk brakes- does anyone have a lead on a set of XC brakes?
    By grouan in forum Where are the Best Deals?
    Last Post: 02-08-2012, 01:16 PM
  5. shimano brakes disk brakes
    By hainesm in forum General Discussion
    Last Post: 05-20-2011, 04:04 PM
