Results 1 to 5 of 5
    May 2013
    How to tell a stem and its intended use?
    So with stems, how do you tell if you can use it for Mountain biking.
    Like this for example:
    BlueSkyCycling.com - Kalloy Uno AS-007 Stem
    Ive seen some road stem. So i'm assuming thats for road bikes. This one having an oversized handlebar area, is that safe to assume its for mountain bikes?
    Also how does the weight compare to other stems?
    Im new to all this.
    Thanks in advance!
    May 2013
    There is this one also. Being it says XC then I think Im good with this one being a yes for MB.
    BlueSkyCycling.com - Race Face Evolve XC Stem
    A Baker St. Muse
    Reputation: michael573114's Avatar
    As far as I can tell, a stem is a stem, provided it fits your steerer and bars. I'm sure some of them are built differently (stronger for mountain biking), but I've swapped my Bontrager stems between bikes when I was playing with cockpit sizing, no problems.
    West Chester, PA
    Some executive from FSA says in a recent issue of MBA that if a stem is "certified" as a road stem it's more than adequate for mountain use because stems see much higher loads on road bikes. Kinda makes sense, considering how hard I lean on my bars while I'm bonking on my road bike sometimes.
    I'm good as long as the bar clamp has 4 bolts and the steerer clamp has 2. Don't feel comfy with the ones that only have 2 bolts for the bars or one for the steerer.
    May 2013
    Quote Originally Posted by 92gli View Post
    Hmm interesting. thanks for your input.
  1. Spiderless cranks and intended use
    By tuvok in forum Singlespeed
    Last Post: 05-19-2013, 06:25 PM
  2. Replies: 9
    Last Post: 08-24-2012, 09:06 PM
  3. Slash em'! (pun intended)
    By Keninshiro in forum Trek
    Last Post: 06-20-2012, 09:10 PM
  4. Replies: 20
    Last Post: 04-19-2012, 12:52 PM
  5. Replies: 1
    Last Post: 04-05-2011, 08:18 AM
