hope pro 2 evo?
hello all i am fairly new to the forums. i don't really post often but find alot of good info here. but long story short i wrecked my trek wahoo on Friday, bent my rear wheel pretty bad and figured this is is the perfect time to upgrade. im a little confused with the specs on this hub. i know that the wahoo is a standard 135qr setup but when i read the specs on this hub its making me believe that it is not compatible. Hope Pro 2 EVO 135mm QR Rear Disc Hub from BikeBling.com
any help will be much appreciated.
Even if it's not compatible when you buy it, the Hope Pro 2 Evo's have a million and one conversion kits, which replace end caps and the axle, so that you can get it to fit ANY bike you so desire.
Also, search around, I just bought an entire set of wheels, Hope Pro 2 Evo's laced to Stans Flow EX rims for less than $400, if you're spending $225 on the hub alone, I can only advise that you're about to make a regrettable purchase.
Wiggle | Hope Pro 2 Evo MTB Rear Wheel Axle Conversion Kit | Hub Spares - That should help my first point.
Wiggle | Hope Hoops Pro2 Evo MTB Wheelset | Performance Wheels - That covers the second
Only draw back is you can't choose colours. But black goes with everything, and I don't have the money to be making colour choices on a hub that costs the same as an entire wheel.
thanks for the heads up. i was actually looking at the stans flow rims, but i want to run the sun ringle mtx 33's. all the reviews that i read say they are really sturdy so thats why im goin that route.
Flows are plenty sturdy also. You'll be fine.
hope pro 2 evo?
Good hub if you get it cheap from Wiggle UK all laced up to Stan's. It is pretty loud.
 Originally Posted by SS Hack
It is pretty loud.
I was hoping the V.2 model was quieter. While I like the quality of the build, the sound of the original hubs were annoyingly loud (for me).
OPEN Cycles One+ in stealthy black
Ive had these for about a year now riding lots of DH laps and trail and have been fine. I have a mavic 721 rear. I am about to swap it out for a Flow EX. You will be more than fine for a Flow EX. Downhill racers use them. Once again, for $40 extra, it would be silly not to get them off wiggle.
wiggle.com | Hope Hoops Pro2 Evo MTB Rear Wheel | MTB Wheels
It is pretty loud.
It's like the Stuka siren of the bike world.
For $245 including shipping you can get just the rear from Merlincycles and they are in stock so you won't have to wait a month. Last week I bought a Easton Haven handlebar and XT Trail pedals on Wednesday and had them on Friday, to california, which doesn't seem possible. I ordered a set of Arches on the 4th of july and still haven't heard from Wiggle, but I did recieve the cassette that I ordered at the same time.
Unfortunately Merlin doesn't have the hope & flow front in stock, but the rear is!
Hope Hoops - Rear - Pro2 Evo - 29er | Factory Mountain Bike Wheels | Merlin Cycles
Open them up and put some medium weight grease like Pedros in it.....will be quiet all season. I've used it summer & winter no ill effects.
yup.. don't need much.. little it on the pawls and springs and a dab or 2 on the outer ratchet teeth and it'll be much quieter..
Re: hope pro 2 evo?
What's the difference between the flow and the crest?
The Flow is wider and stronger than the Crest.
i got the hope 2 15 for now. and will eventually get the rear. thanks for all you guys help.
By dcurtis in forum Singlespeed
Last Post: 05-20-2013, 12:34 AM
By 007 in forum Brake Time
Last Post: 03-27-2013, 07:10 PM
By jncarpenter in forum Brake Time
Last Post: 01-12-2013, 08:59 PM
By Deer_Dodger in forum Brake Time
Last Post: 05-16-2012, 05:34 PM
By ESN in forum Wheels and Tires
Last Post: 03-13-2011, 10:54 PM
- You may not post replies
- You may not edit your posts
Forum Rules
