Results 1 to 37 of 37
    I Ride Bikes
    Reputation: Mazukea's Avatar
    Help me upgrade. $500 budget
    Alright guys I want to start upgrading some parts on my stock 2012 spec Camber Comp Carbon. I have a $500 budget to work with. I want to lighten my bike and get better components. This is what I have in mind
    -longer stem
    -carbon handlebar
    -new saddle
    -carbon seatpost
    Or
    -carbon crankset
    -lighter chainring
    Sounds like a good plan?
    Any suggestions?
    Reputation: Mojo Troll's Avatar
    Option one does'nt sound to bad. Get the bike dialed in where your comfy.
    If you bash your pedals and cranks on rocks. You might want to reconsider carbon cranks.
    I Ride Bikes
    I just bought me the Syntace P6 HiFlex carbon seatpost last night. I found it online for only $147 shipped.
    Yeah you have me rethinking the carbon cranks. I do hit my pedals/cranks on rocks every now and then. Thanks.
    I would upgrade the wheels. The rear hub is especially upgradable. A Joi-Tech 2 pawl.
    Drivetrain is a high wear item/s...I would upgrade the cockpit first & drivetrain last. Last as in everything else, wheels, tires, brakes, fork, etc. before drivetrain.
    For $500 I would get new wheels. ZTR/Hope.
    I Ride Bikes
    These are very good ideas and suggestions. Thanks.
    Quote Originally Posted by Call_me_Tom View Post
    I'll second this. But, when the time comes, you can save ~140g by going from the 1030 cassette to the 1070.
    With that said, that's a pretty light bike to start with. I'd just start saving for a good wheelset and think about what tires you'd like next. Both of those items will be far more noticeable than the amount of weight you can shave from the bar/stem/seat area.
    Enjoy the new ride. That's a nice bike. If you're really itching to spend money to increase speed, I'd recommend a Garmin with a heart rate monitor. That combined with lots of reading in the XC/Training forum has netted me some great improvements.
    Keep this in mind, there are only 3 points of contact between you & the bike, your hands, feet & butt. The cockpit eg grips, saddle & pedals will make a world of difference in the comfort of your ride. If you're uncomfortable you won't ride no matter what other upgrades you throw cash at.
    Reputation: rob1035's Avatar
    Quote Originally Posted by Jay Uno View Post
    Absolutely. A wheelset is an upgrade that will make a huge difference, vs saving a handful of grams. New appropriate tires for your riding, preferably tubeless can increase the improvement...
    After that, like was stated earlier, saddle and grips are good upgrades if you aren't happy with what you have.
    I Ride Bikes
    Quote Originally Posted by rob1035 View Post
    I currently have the Roval Control Trail wheelset on my bike. It supposedly weighs 1800 grams. I know it ain't light, but it seems like a decent wheel. Are there any wheelsets for $500 that are better than the one I currently have?
    Reputation: Trail_Blazer's Avatar
    May 2012
    I jsut upgraded every component on my bike, the frame is all that remains stock. lol
    The biggest weight savers and performance increase came from the lighter crankset and lighter front fork.
    This made my front and back end much lighter and more balanced.
    The other item I upgraded that also made the largest weight change was carbon handle bars.
    My stock handle bars were very heavy.
    The next most significant upgrade was a new wheel-set.
    I will say that every part I changes was 50-200 grams lighter than the stock parts, and adding them all together really paid off.
    I shopped around to get the best deals possible on each part, usually 50% off.
    I still spend about $1K in upgrade parts though, not including the wheel-set.
    May 2012
    To get a nice wheel set for the cheapest is to build it.
    Stans has the ZTR flow wheels on sale for only $50 each!
    You can get any light shimano hub cheaply or pony up for a more expensive hub, but take care as the price of spokes can add up.
    I Ride Bikes
    Okay so far I picked up a carbon seatpost and carbon handlebar. There went $300. I got $200 left to play with. Right now I'm looking for a new 90mm stem. My current stem is 60mm and I've always felt it was too short.
    I Ride Bikes
    Quote Originally Posted by schristie11 View Post
    Thanks. This was a pretty useful post.
    Reputation: monty797's Avatar
    When ever I look at upgrading a bike I look at two spots before anything.
    1. Wheelset - This is where you'll see the biggest performance gain. You have to overcome the mass of the wheels to get rolling, any changes here are significant. Even a small bit can feel like a big deal, especially on mile 5 of a 10 mile climb!
    2. The next part I'd upgrade is the cockpit of a bike. Stem, Bars, Grips, Post and Seat are all usually pretty heavy on stock parts. Big gains in weight can be had here. As well as comfort. The more comfortable you are the better you perform.
    Look at those points first and slowly work your way out.
    A cheap way to "upgrade" or lighten a wheelset is to look at the tires on it. Quite often a stock bike will have heavy tires on it. You can save a few hundred grams by going to a better quality tire. You may spend around $120+ to accomplish this, but do that plus your cockpit and you'll save quite a bit of weight and gain a ton of performance.
    May 2012
    Duplicate post
    May 2012
    I almosy forgot;
    Stan's tubless kit with $100 of rubber is the first and foremost upgrade for any bike.
    I recommend budgeting the tubeless tire conversion with your stem.
    Quote Originally Posted by Mazukea View Post
    Also, your stem length, 60 is pretty short and I tried a 55 also 100, but found that 70-80 is where I need to be for joint comfort.
    Don't spend too much on the stem because you may not like it long term.
    I Ride Bikes
    thanks for all the advice and suggestions guys. Everyone gets a positive rep!
    I'm looking for a 75mm up to a 90mm. yeah I don't plan on getting an expensive stem cause I feel I could use the money elsewhere. I just found a used 75mm stem on ebay. The auction ends tomorrow, actually in several hours. You guys better not outbid me!
    I almosy forgot;
    Some quick googling gave me mixed answers, but his rims may be tubless ready as is.
    Did your bike come with a set of tubeless stems in an accesory bag? I'd try checking in the Specialized forum for a more definitive answer.
    Try this site to help find the proper measurements for fit.
    http://competitivecyclist.com/fit-calculator/
    Reputation: slideways666's Avatar
    dropper post and new stem if your current stem isnt long enough.. I had a reverb and now a ks lev.. A dropper post is one of the biggest impact add-ons i have gotten so far(youll be amazed how much you use it).. Your wheels @ 1800gm are fine... If your stem is to short-- then your cockpit is cramped- and that is no good.. I went from a 50mm to a 70mm and it made a world of difference.. You can get both those items for less then 500 and your riding experience will be a much better one..
    Get both the dropper and stem from competitive.. They offer a no questions asked return policy.. So if the stem is to short-- you just send it back and they will give you the one you want and or refund.. Makes it a no risk purchase.. Also-- as said above-- tubless is cheap and has a good impact on ride quality..
    reverb=275
    thomspon 70mm stem=80
    stans tubless kit= 60
    ergon sm3 seat=100
    total 515 and some big changes for that money..
    Also another thing to look at is some shimano brakes.. i had avid xo's and finally had enough-- put on xt's and was a instant improvement.. Though now id go slx666's
    could go
    reverb 275
    thompson 80
    slx brakes f/r 170
    total 525
    My free racing tv guide-- www.racingtvguide.com
    Reputation: Brig's Avatar
    Fit is key, but................Just my .02c, I kind of want to call Stan's and thank them for the new bike that came with the ZTR Arch EX wheelset I just threw on mine. Best $500 I've spent....stem and bar are next for me.
    Not sure if your current rims are tubeless ready. If not you should really consider either you doing it yourself or have a LBS do it. I'll never go back to tubes. The comfort, traction and far less flats is well worth it.
    ESI silicone grips are the best bang for buck going.
    OP mentioned possibly a new saddle. If your @$$ and saddle are'nt in love. Consider getting a new one.
    I Ride Bikes
    More great suggestions. You guys are really making me want to go tubeless. I've watched some videos on how to do it. It doesn't look to hard. I just gotta check if they are tubeless ready. Is 2Bliss the same as tubeless ready? My tires (Purgatory and Ground Control) also are 2bliss ready. I'm guessing thats how Specialized calls there tubeless ready tires/rims.
    I Ride Bikes
    nah, my Henge Comp saddle isn't that bad. I would get a new one just to save weight. So it's not a big deal. I can live with my current saddle.
    Somebody did outbid me on ebay for that 75mm stem. So I'm still in search for a 75-80....maybe 90mm stem.
    Go to PricePoint, Performance etc... and purchase a couple of cheap $10 stems in different lengths/rises. Experiment with them untill you get the desired set up. Once you get it dialed. You can purchase a blinger stem. Toss the two cheap stems in the toolbox for future set ups. You can also ask around and see if a riding buddy has a stem or two you can borrow to experiment with.
    Theres a neat stem comparison calculator tool somewhere on here. I can't find it at the moment. Maybe someone will be kind enough to post it.
    May 2012
    For $500 budget, you can update all these things: handlebar, stem, seatpost, saddle... all in Carbon fiber material to lighter your bike... and have balance.
    I Ride Bikes
    Quote Originally Posted by Jason.MT View Post
    point me to right place, cause I've been looking all over the internet and I can't find deals like that.
    I would like to bought the bike parts from China, cheap but good quality,
    I found that there have one Chinese supplier that have sell the bike parts, good quality things but competitive price and also nice service:www。shop-yishunbike。com
    I Ride Bikes
    Well my stem, handlebars, and seatpost all came in. I'm just waiting for my new saddle now.
    Syntace P6 Hiflex carbon seatpost
    Ritchey WCS Rizer carbon handlebar
    Ritchey WCS-260 stem 80mm
    Specialized Henge Pro 143mm saddle
    Specialized BG Contour Locking Grips
    carbon handlebars made such a huge difference for me. Made turning that much quicker. Making anything that moves, lighter, is going to give you better results than a static component...wheels,bars,fork,cranks, etc. I would've stayed away from a carbon seatpost though.. just make sure you don't overtighten
    2013 Ibis Mojo HD Special Blend with dropper post, hope/stans wheelset and hope x2/m4 brakes
    I Ride Bikes
    ^^thanks for the tip. yeah I read about carbon seatposts breaking due to over tightening of the collar, but I just thought the deal was too good to pass up.
    Singletrack Snob
    Reputation: Vitamin G's Avatar
    Other stuff to think about spending some of that money on:
    Shoes, shorts, jersey, gloves, wind vest, etc... clothing is worth spending money on. Knee and arm warmers are very appreciated when the temps get cooler.
    And a nice bike rack if you do not have one already. The ability to take your bike on trips is worth a lot. I've taken my bike on vacations with me and ridden places that I otherwise would not get to ride.
    A bell is good getting the attention of earbud wearing hikers.
    Riding at night with lights opens up a whole new world... $100 goes a long ways towards getting a good enough light for night riding (or early morning riding).
    Entry fee for your first race. That's another experience.
    "I've got a card in my spokes, I'm practicing my jokes. I'm learning!"
    Sep 2012
    im wanting to go single up front but i dont know what i should go with
    Reputation: beer_coffee_water's Avatar
    Mar 2011
    Quote Originally Posted by Mojo Troll View Post
    Stem Comparison Tool | yojimg.net , there is a stem calculator among other things. Put in your current one and put in the one you are after. Don't forget to put your actual head angle also.
    Reputation: kragu's Avatar
    Sweet pics dude. If you have $ leftover, I'd grab a decent pair of riding shorts, too.
    ba-Zing!
