Results 1 to 13 of 13
    Jul 2013
    Heavy duty fork for heavy and aggressive riders?
    I'm building a bike and have some concerns about using a front shock due to my weight (280lbs). Any suggestions for a shock that can take my weight as well as an aggressive riding style?
    The new Pike?
    Reputation: millertm's Avatar
    I have a couple pounds on you and my bike came with the Recon Silver single air, I pump it to 300psi and it works great. Look at a single or double air. Also I have the 32mm tubes, stay clear of the 29mm. This silver has the Steel head tube and is heavy but it is quite stiff and you can get them cheap.
    Mark
    2012 XXL Carve Expert
    Reputation: Mr. 68 Hundred's Avatar
    How much travel do you want? White Brothers Groove and Manitou Dorado are options if you want a lot. I'm not heavy but ride aggressive and am not particularly happy with my Fox 32 CDT Talus (120 mm on hardtail). The best other options I've seen are the Fox 34 and as Pau1 stated, the Pike. No lockout on the Pike that I'm aware of though.
    20 mm, 35< mm 140 mm, with lockout would be ideal.
    Proponent for an Evidence Driven Life.
    Occupation: Disposable gene transfer machine
    Current HTFU status: 4/10; increasing
    Reputation: duggus's Avatar
    I'm 225 geared up and my White Brothers Loop 120 has been bulletproof and has awesome adjustments to fine tune it to your weight/style. I'm sure one of the new X-Fusion Trace forks would be good for you as well since they have 34mm stanchions.
    ...Be careful what you're looking at because it might be looking back...
    Quote Originally Posted by millertm View Post
    I hope you are mistaken and mean 200psi?
    Rock Shox Air Spring Chart: MAX PSI: 225 psi
    Quote Originally Posted by duggus View Post
    No, I pumped up it up to 300psi. But I just checked and you are right, I was told 1 psi per pound. I should have checked but I got lucky. Seals are still intact and it was a great ride.
    Mark
    Jul 2013
    A lot of good info. But boy, there is SO much manufacturer technical info on the web it's mind boggling. I'm beginning to think a solid fork may be the way to go.
ID:	819459No, I pumped up it up to 300psi.
    What pump pumps to 300 psi, or even 175+?
    I got a road bike floor pump and it only goes to 160 I think. I never put more than about 110psi in my road tires.
    WillWorkForTrail
    Jun 2012
    Quote Originally Posted by TomBrooklyn View Post
    Any decent shock pump.
    https://www.amazon.com/Shock-Pump-Ga...ock+pump&psc=1
    Sep 2014
    How much do you want to spend? Fox 36 or RS Pike, Yari or Lyric should work.
    I'd say at least 34mm legs at your weight.
    Sep 2014
    Mark
    Sounds like you got lucky.
    Sep 2014
    Just noticed the original post was from 2013....doh!
  1. Heavy duty wheels?
    By askibum02 in forum Wheels and Tires
    Last Post: 04-05-2013, 08:14 AM
  2. Paid Spam...heavy duty SS frame and fork
    By Bike Whisperer in forum Clydesdales/Tall Riders
    Last Post: 09-16-2012, 08:37 PM
  3. Heavy Duty Rotor
    By johnnyelohssa in forum Brake Time
    Last Post: 03-28-2012, 08:10 AM
  4. the most heavy duty free hub
    By Lollygagger in forum Clydesdales/Tall Riders
    Last Post: 01-28-2012, 09:52 AM
  5. Heavy duty tubes???
    By denno in forum Wheels and Tires
    Last Post: 11-15-2011, 08:51 AM
Members who have read this thread: 57
