Results 1 to 13 of 13
    WNC Native
    Reputation: nitrousjunky's Avatar
    Which has the larger volume - 2.5 DHF, 2.4 Goma, or 2.4 Trail Boss
    Which of these 3 tires has the largest volume- 2.5 DHF, 2.4 Goma, or 2.4 Trail Boss?
    Currently running a NN 2.6 on my custom hardtail. I'm good on the 2.6 knob width, but I need a tire with more narrow casing width than the 2.6 NN.
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Live Free & Ride
    Reputation: NH Mtbiker's Avatar
    Magic Mary comes to mind. The 2.35 size is beefy at around 2.42 inches on i30 rims, 20 psi all you need. Casing should be a tad more narrow than the 2.6 NN you have now. Great tire for all conditions, especially wet mud or gravel - check it out!
    17 Moto Ti cross
    14 GT Zaskar 9r
    15 Moto Night Train
    08 BMC Trailfox
    08 Bad Boy Ultra
    06 Cannondale Rush
    99 GT XCR
    Reputation: MSU Alum's Avatar
    Quote Originally Posted by nitrousjunky View Post
    You want LESS volume than the 2.6, but of these three tires, you want the one with the MOST volume? The one with the least volume will likely have the narrowest casing, if that's what you're looking for....I'm a bit confused. Do you just want a tire that is wider at the knobs than at the casing?
    Rocks belong
    The Goma is a monster. It's a balloon.
    I'd say: Goma highest volume and then tie for DHF/Trail Boss
    I like 'em long, low, slack and playful
    WNC Native
    Quote Originally Posted by 06HokieMTB View Post
    Exactly what I was looking for thanks! I picked up a 2.5WT DHF to swap to, but may grab a Goma too later.
    Reputation: socal_jack's Avatar
    Dec 2008
    Have a set of Gomas on my SS ROS9, friend rode up thought they were plus at first. Very comfy riding casing too. Only bigger I've had on it was WTB Dissent 2.5s, rough ride though but hookup for days.
    ROS9+ SS
    ROS9 SS
    GT Peace 9R SS
    Reputation: Lone Rager's Avatar
    Dec 2013
    Uhhh, tire carcasses are circular in cross section so a wider tire will have more volume and vice versa. IMO, it's kinda silly to talk about volume.
    Do the math.
    WNC Native
    Quote Originally Posted by MSU Alum View Post
    Thought I made it pretty clear, wanting the tire with the biggest volume (widest casing/ Bead to bead) out of these three mentioned tires. I like the volume of the 2.6 NN, however it's rubbing ever so slightly.
    Quote Originally Posted by Lone Rager View Post
    How's that, when the whole post is about the largest volume tire under the NN 2.6............
    It's not clear because the highest volume tire in that group may be wider than the Nobby Nic in question. Especially the Goma.
    But you're right, I think, to concentrate on bead to bead. Measure the NoNi B2B and then pick the tire in your group that has the greatest without exceeding the B2B of the NoNi.
    WNC Native
    Highly doubt that, given that even on my 30mm internal width rim at 18psi, this NN casing is over 2.6" wide.
    My NoNi on a 35 id is 2.5915".... I would check the sizes before buying.
    My goma is 64 mm at casing and 63.5 at tread on i36 rims.
    WNC Native
    Quote Originally Posted by telejefe View Post
    Thanks for the numbers! My DHF 2.5 WT is 61.5mm (2.420") at casing and 64.5mm (2.540") at knobs on i30, after one full day of sitting tubeless at 30 psi.
  1. Replies: 9
    Last Post: 02-13-2018, 02:06 PM
  2. DHF 2.5 WT vs DHF 2.6 WT
    By SonomaBiker in forum Wheels and Tires
    Last Post: 11-09-2017, 06:59 AM
  3. Dhf ust or standard dhf 2 ply for tubeless
    By trap121 in forum Downhill - Freeride
    Last Post: 06-04-2013, 10:08 PM
  4. Volume! Volume! Volume! (BCOS on bad behavior)
    By GRAVELBIKE in forum Colorado - Front Range
    Last Post: 12-04-2011, 09:24 PM
  5. Which is higher volume: AVA or new RP2 (high volume canister)?
    By kapusta in forum Shocks and Suspension
    Last Post: 05-31-2011, 02:56 PM
Members who have read this thread: 13
