Results 1 to 34 of 34
    Click Click Click
    Reputation: dirtbyte's Avatar
    Handlebars: Titanium, Carbon or Aluminum?
    I am building up a new 29er from the ground up and I am having a hard time deciding on what handlebars to get. Leaning towards the Thomson Carbon flat bar, or the Ti Bar (but having a hard time swallowing the price of that bad boy). Basically, I am not a weight weenie, but I am watching the weight of the components because the bike that this build is replacing is a total tank and one of the main reasons I am building a new bike is to get the weight down a bit. I ride mainly XC trails with perhaps just a tad bit of AM mixed in (the occasional 12-18 inch drops taken at fairly slow speed).
    I am also fairly light (140 pounds), so I figure I can get away with a pretty light bar. Also I do have some stubby bar ends that I like to run (I know 90's but I really like them when climbing, especially long grunts). I am worried about putting bar ends on a carbon bar.
    Just looking for some suggestions for a good flatbar, between 640 and 700mm, that is fairly light (say around 200grams), that is good for XC riding...
    Your profile says you are in the desert southwest--the reason I bring that up is--I use carbon bars to keep the cold temperature transmission down--I am in Alaska--so, not a problem for you, but, is there an equivalent heat transmission issue? If so, something less thermally conductive like carbon may be nice. Otherwise, save money and get a decent Al bar--the weight difference is not that much when you look at it (50 grams? at most). Width, rise, and sweep are going to be the key factors (combined with the correct stem) for riding comfort.
    Click Click Click
    Heat/Cold transfer is not really an issue. Thanks for the feedback. Yeah, my current bike has a riser bar, and I am looking to go with a wider flat bar for a more aggressive riding position. So I am sure I will want to experiment with different widths and sweep, so I probably should start with a al bar
    Thanks again!
    May 2005
    I'm a big fan of the Salsa Pro Moto handlebar with 11 degrees of sweep. I run the aluminum version, but there does appear to be a quite significant difference in weight if you go carbon - 145g for the 11 degree carbon Pro Moto 1 vs 260g for the Pro Moto 2 aluminum. Can't use your bar ends on carbon though.
    Oct 2011
    The Carver Ti bar is 215G I believe at 730mm. Good price too(about $100). I have one on my rigid SS and like it
    ballbuster
    Reputation: pimpbot's Avatar
    Quote Originally Posted by mtbdennis View Post
    I say go carbon. These days, carbon bars are super tough, don't fatigue, and even the reasonably cheap ones are of good quality. I liked the shock absorbing qualities.
    ... that is, unless you like wonky shaped bars, like me. Then, there aren't many choices for carbon.
    Oct 2013
    Buy whichever one fits your riding style and what you want to spend. Carbon will be more comfortable than the AL or Ti. Think about a tennis racquet from 30 years ago when they were metal or a golf club shaft.
    I did a little research and wrote an article on "bolt on" upgrades and building a bike up... In many cases the really nice AL parts(stem, bars, post) are still quite a bit less than quality carbon pieces and are literally only 2-3 oz. heavier. So add up those 3 pieces and you have a total weight savings of maybe 6 oz? Yet you spent $100's more. But like I said, there are some other advantages to carbon vs. AL...
    Bike Doctor
    Quote Originally Posted by Kawigreen99 View Post
    That seems like a great deal.
    Reputation: RS VR6's Avatar
    Using the 710mm Niner RDO carbon bar. Coming from an Easton EA70 alu bar...the carbon made a difference. I'm 142lbs.
    I like turtles
    Reputation: TiGeo's Avatar
    I like my S-Works Carbon Prowess...720mm..$125. Great damping and weighs ~180 or so I believe.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Feb 2012
    I switched to a ti bar and ti seatpost on my fatbike, both were FSA carbon before. I liked the carbon, but now am switching all my seatposts to ti due to the buttery smooth feel. If I could get a ti road bar in the shape of my FSA K-Wing I would do it in a heartbeat. The carbon did a great job dissipating high-frequency vibrations, but I find the ti at both ends to be smoother overall.
    P.S. I have 3 FSA SL-K 27.2 0-setback posts for sale...guess I better hit the classifieds and pay for that spam.
    Oct 2013
    Might be a stupid question but I've never owned any but can you cut carbon bars yo desired length! I found a set for a good price but their too wide.
    Yes you can cut them with a hack saw.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Been happy with Niner Flat Top Carbons at 710mm on both bikes.
    SPP
    Rigid.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Get the Easton EC-70 XC Wide 685mm and be done with it. It's 155g and tough as nails...
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Feb 2013
    Those Eastons are relatively cheap too, I'm shopping too and I like the price/weight/reviews of the Easton ECs.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by orind View Post
    When I was in arizona riding in -5 degrees I definitely would have liked the lack of heat transmission with carbon bars, the only problem is I wasn't using pogies to trap heat anyway, so it wouldn't have mattered. I rode all the time in AZ below freezing, if only I had the gear I have now though...
    There are a few reasons to get carbon bars, mostly it's weight. On my AM bike it's strength and weight, as it's not the lightest carbon bar ever, but it's likely one of the strongest given the thickness and I didn't want it failing while doing gaps and jumps obviously.
    On my other bikes I've went with carbon bars due to the weight and stiffness. Aluminium is just not that rigid at those wall thicknesses and sizes, but carbon can get way out there. You might consider a nice wider carbon bar (740-760mm), which spreads your hands out nice and negates having to run bar-ends to a large extent, plus it gives you more leverage while standing and pedaling. It's an old myth that your handlebars should be as "wide as your shoulders".
    I've found no real advantages to carbon or ti in terms of "frequency absorption".
    Reputation: ghettocop's Avatar
    I thought there was a big difference in the chatter absorbing abilities of carbon bars. Going from an EA-70 to Ritchey WCS Carbon smoothed out the ride for me considerably. I ride a flat bar on a hardtail in old fashioned race-type position and it really was noticeable for me at least.
    I like turtles
    Quote Originally Posted by smilinsteve View Post
    Correct; however you are supposed to use painters masking tape to tape that area to cut to prevent splintering and use a v. fine blade (can't remember the type) - Niner's website has info on this if you look at the instruction sheet for the carbon bar.
    Went from Easton EA70 alu bar to a Niner RDO carbon bar. I was actually able to tell a difference in my hands.
    Recently switched my GF's bars on her Niner to the Easton EC70.
    Never used a Ti bar.
    650b me
    Reputation: golden boy's Avatar
    I have to agree with some others here...I can feel a difference between carbon and alu. Carbon is superior at damping vibration. I've owned a few Easton carbon bars and found them to my liking. Currently running the EC 70. For me, it's wide enough, very light and plenty strong.
    I just put a Carver ti bar on my other bike, but I only have one ride on it so I really can't compare to carbon yet.
    650b me
    Oh wait...this is the 29'er forum. Please disregard my previous post. Those bars are on a 26" and 650b, respectively.
    Jun 2013
    Basically, I am not a weight weenie, but I am watching the weight of the components because the bike that this build is replacing is a total tank and one of the main reasons I am building a new bike is to get the weight down a bit...
    As somebody else pointed out, you're only going to save 2-3oz going carbon instead of aluminum.
    Do this: figure out what saving gram or an ounce is worth to you. Is a gram worth a dollar? Is 100g worth $100? Is a kg worth $1,000? Is an ounce worth $25? Or $50? Then start shopping.
    Also I do have some stubby bar ends that I like to run (I know 90's but I really like them when climbing, especially long grunts)...
    Me, too. I don't know how people ride without them.
    I still have the 680mm "C3" bar that my Cannondale came with (I replaced it with a 760mm Origin8). It's just gathering dust here. If you're interested, just let me know.
    Never trust a fart
    Reputation: frdfandc's Avatar
    I've ridden all 3 types.
    Aluminum - budget friendly, avail in multitudes of widths, sweeps and rises, fairly light depending on the model.
    Least favorite
    Carbon - Cost is much higher that aluminum. Expect a minimum of $130 but can rise to over $200 easily. Has vibration dampening characteristics. Avail in very similar widths, sweep and rise as aluminum. Usually the lightest of the bunch.
    Loved my Easton EC90 SL bars - 135 grams, but very narrow at 635mm. Loved the stiffness when climbing.
    I have ridden Easton, Forte' (nice bar for the money), Enve (long demo ride) and Truvativ bars (friends bike).
    Titanium bars - These are my absolute favorite. VERY, VERY EXPENSIVE. Currently running Thomson Ti 12 degree sweep flat bar, cut down from 730mm to 680mm. Smoothed out the ride. I don't feel as beat up on the longer 20+ mile rides like I did when I was using the carbon bars.
    These were 1/2 lb heavier than my Eastons, and around 100 grams heavier than alloy bars I have ridden in the past.
    I will take the weight penalty for comfort any day.
    To the OP, your criteria calls for a carbon bar regarding width and weight. I like the Enve, Truvativ and Eastons.
    What you buy comes down to budget.
    Cutting Aluminum - Any 18tpi or 24tpi hack saw blade will work. Use a file to smooth out the edges.
    As for cutting Carbon, use at minimum a 24tpi blade. If you can find a finer tooth count, like 32tpi or a diamond coated blade, then do so. Tape up the carbon with painters tape to minimize splintering, followed by a fine file to remove the rough edges.
    Cutting Ti - Use a cut off wheel. Seriously. I destroyed 2 18 tpi hacksaw blades cutting down my Ti bars. Then followed by a file.
    Reputation: Jams_805's Avatar
    Aug 2013
    I love my FSA carbon bars.. they feel good, look good, and do help with vibration IMO
    Rockhopper 29er
    -FSA Carbon handlebars, stem, & seatpost
    -2011 Rockshox Reba
    -Stan's Flow Wheelset
    -Ergon Grips
    West Chester, PA
    I'm currently running aluminum bars, for the first time in 6 years. Really missing the damping of carbon bars. Had no idea what a difference it made.
    Reputation: azjonboy's Avatar
    I've run aluminum, carbon and Ti. Aluminum are what they are - inexpensive and harsh.
    Carbon have great damping abilities and stiffness. Great material. Ti can be had in a myriad of shapes and offer great damping as well.
    For me, the Ti bars are more comfortable for the type of riding I do. Plus, I can get them made the way I want them.
    If you're lucky enough to be in the mountains,
    you're lucky enough.
    Sep 2013
    I love the difference in feel I got going from cheap 680mm aluminum to 710mm carbon.
    Sent from my Galaxy Nexus using Tapatalk
    Reputation: bwargula's Avatar
    What about "scandium"? Never really hear any news about them or anyone with them on their bikes. There was a smoking deal on a set a couple of weeks ago, was thinkin about it.
    Live to ride, ride to live
    Reputation: Uncle Knobby's Avatar
    Jan 2013
    Is the difference in between aluminum and titanium noticeable on a suspended front end? I'd like to get something with around 15˚ of sweep, and am wondering it's worth the price of admission to get a TiCycle Double S instead of a Salsa Bend 2.
    2013 El Mariachi Ti and a motor that needs an overhaul.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    I've been running the Enve Sweep 740 mm on My 2012 Stumpy Comp HT and really like them just wish they came in longer like 780 - 800 mm like their riser bars.
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Sep 2012
    I would like to try a Ti bar. I went from a nice Thomson seatpost to a Ti post and was a great change.
    As stated above EC70 bars can be found at nice prices and it was a noticeable difference in vibration from the Alu. bars I had been using.
    650b me
    Quote Originally Posted by MTB Dad View Post
    Recently I bought a Carver PryBar (ti). Both lighter and cheaper than Thomson's ti bar. Too good to be true? Time will tell...
    Reputation: CCSS's Avatar
    Quote Originally Posted by golden boy View Post
    I've been riding one since May on my Krampus. Lots of miles and lots of abuse. Just bought another for my "regular" rigid 29er. Love it.
  1. Titanium bullmoose handlebars
    By First Flight in forum Vintage, Retro, Classic
    Last Post: 06-26-2014, 03:51 AM
  2. Carbon or Aluminum handlebars?
    By KEITH21 in forum General Discussion
    Last Post: 02-15-2014, 06:19 AM
  3. Replies: 10
    Last Post: 04-19-2013, 08:02 AM
  4. Carbon vs Aluminum Handlebars - For Feel
    By mtnryder56 in forum Downhill - Freeride
    Last Post: 10-17-2012, 07:22 AM
  5. Replies: 12
    Last Post: 05-08-2012, 12:07 PM
Members who have read this thread: 9
