Results 1 to 2 of 2
    Handlebar Mounting - Sram XX1 Shifter / Shimano XTR Race Brake / Rockshox Remote
    Looking for suggestions / tips on the best way to effectively mount a Shimano XTR Race Brake lever, Sram XX1 trigger shift pod and a Rockshox hydraulic remote lockout on the right side of my handlebar. My last drivetrain / brake combo was all Sram so I used their matchmaker system but this is no longer an option. I heard Problem Solvers had come out with a solution but I don't believe it works with the latest version of the XTR Race Brake lever. I'm a bit concerned on how to ergonomically get this set up in an efficient manner. Pictures / suggestions welcomed.
    You can still hang the shifter off the hydraulic lock out with a new-style matchmaker. The only question is whether to mount the remote clamp inboard or outboard of the brake lever. I am assuming you have the lock out mount that goes above the handlebar. The other option is to run the remote on the left side of the bar, since you are using XX1.
  1. Replies: 28
    Last Post: 12-12-2014, 04:12 AM
  2. Shimano brake SRAM shifter mount
    By Hophead1 in forum Giant
    Last Post: 05-25-2014, 03:13 PM
  3. Spec-ing a new build. Confused by Shimano and SRAM shifter/brake combo options
    By zanq in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-22-2013, 02:57 PM
  4. Replies: 4
    Last Post: 02-03-2013, 07:51 PM
  5. Shimano LX slm 580 shifter/ SRAM 9.0 Der. ?
    By earlpizumi in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2011, 04:48 PM
