Results 1 to 21 of 21
    Aug 2013
    good 120mm shock options
    Hey new to the forum, and thought I could get some help. Looking for some good 120mm shock options beyond the Fox and Rock Shox. Not opposed to them but curious as to what else is out there. I'm upgrading on my Superlight and thought this would be the best place to find whats out there.
    Reputation: joe_bloe's Avatar
    By "shock," do you mean fork?
    Aug 2013
    Yea, sorry I sort of jumbled my words.... looking into 120mm forks
    Reputation: Dr Wankel's Avatar
    Oct 2007
    The White Brothers Loop is available in 120mm. X Fushion also has a couple, the Trace and Slide I believe.
    26 or 29 inch?
    Sent from my SPH-L900 using Tapatalk 4
    Hi There!
    Reputation: TheGweed's Avatar
    Quote Originally Posted by Dr Wankel View Post
    +1 on checking out the White Brothers Loop.
    NTFTC
    Aug 2013
    29"
    Quote Originally Posted by only T View Post
    29"
    Manitou Tower Expert.
    Sent from my CrystalQuadCore using Tapatalk 4
    Manitou Tower Pro and the new Marvel and Minute are offered in 120.
    Reputation: molopoko's Avatar
    Jul 2013
    Quote Originally Posted by eb1888 View Post
    Which one of those would you recommend?
    Reputation: speedintc's Avatar
    Feb 2013
    i have the tower pro in 120 and i love it. i still need to order my xx firm spring, but the firm spring is doin the job for now. im 215-220 lbs and bomb over alot of stuff and it has held its own.
    Quote Originally Posted by molopoko View Post
    I have a Tower Pro although not 120mm. The Marvel lacks the small coil spring, so it would be less plush. But I need some info on the Minute 120 to see how it is different from the Tower Pro 120. I haven't seem any reviews yet.
    Tower is the 29" version of the Minute. They don't offer the marvel in a 29". I ride a 120 Tower Pro and it, it is a great fork. Highly tunable and easy to maintain yourself.
    The Tower Expert is a little easier to tune, if you want to sacrifice some ride quality and weight for simplicity. I haven't ridden one but I hear good things.
    Reputation: duggus's Avatar
    Quote Originally Posted by thegweed View Post
    +3 on the White Brothers Loop. I had a RS Reba and Sid... The Loop is the ticket.
    ...Be careful what you're looking at because it might be looking back...
    Quote Originally Posted by swildnm View Post
    Manitou is expanding their 29 offerings for the 2014 season. These include Marvel Pro in a 80, 100 and 120 and Minute in 120 and 140.
    These should be available now or soon.
    SOC13: Manitou Marvel, Minute Suspension Forks Redesigned
    Good info! Thanks!
    If the Marvel is available in 29" does this mean they will be discontinuing the Tower Pro?
    Quote Originally Posted by jnroyal View Post
    No. It's a different fork action.
    The new Marvel doesn't have the small coil spring the Tower Pro and Minute use for sag and the very beginning of the fork travel. It has a compressible rubber bumper. This probably gives you much less small bump compliance.
    Mar 2012
    @ only t, I also ride a superlight29 2012 came with the rockshox reba 100mm.
    I have also been thinking of upgrading to a 120 but its a pricey upgrade. I always use up all the travel, but at the same time I wonder if 120mm will do that much of a difference. Might just wait and buy a new bike with more travel in the future. maybe at the end of 2014?
    anyhow Im interested in hearing what you get and how it worked out.
    I have a 120 mm Fox F29 TALAS RLC Factory fork with 1 year of use on it. I just posted it on Craigslist. It has the 51 mm offset which would keep the handling sharp with the longer axle to crown of your stock fork. The TALAS drops it to 95 mm for climbing or tight trails. $500. Retails for over $1000 new. I am parting out my bike and likely getting a 140 mm FS in the spring to better offset the hardtail I already own.
    edit - ad is in the classifieds section
    Quote Originally Posted by kdiddy View Post
    Take out an add
    OG Ripley v2
    Carver 420 TI
  1. 29er 120mm fork options/recommendations
    By field_c in forum 29er Components
    Last Post: 09-26-2013, 05:35 AM
  2. 80/120mm Fork Options?
    By jamatt in forum Shocks and Suspension
    Last Post: 11-15-2012, 01:10 PM
  3. Replies: 17
    Last Post: 09-04-2012, 06:36 AM
  4. Limited 650b 120mm fork options for Blur XCc?
    By danK in forum Santa Cruz
    Last Post: 08-29-2012, 11:07 AM
  5. 100-120mm suspension corrected forks options
    By j.w.1 in forum 29er Bikes
    Last Post: 06-07-2011, 11:29 AM
