• 01-08-2013
    TraxFactory
    +1 for the Odi Rogue Lock On Grips. I have an XL hand and don't like softer grips, they tend to moosh out with heat sweat to fast for my liking...
  • 01-09-2013
    bmw4l1f3
    Originally Posted by jpick915 View Post
    I am a big fan of the Ergon GP1 grips. Ergonomic and they lock-on.
    I love these grips!
  • 01-09-2013
    tartosuc
    odi rogue for me on all my bikes...the oury lock-on made by odi ahve the same diameter and feel similar to me.
  • 01-09-2013
    DrDon
    Oury lock ons for my FS, Bontrager thick grips lock on for my SS.
  • 01-09-2013
    1niceride
    Well, my of thinkin says I need to use bar tape to make my grips sense my 29er uses 700c rims..
  • 01-09-2013
    stoats
    Until recently I've been using Rogues and have been quite happy but they rough up your gloves pretty quick. I switched to the Chromag Palmskins and have been very pleased. They provide plenty of grip without a tapered bulge-the built in bar plugs are a nice touch as well.
  • 01-10-2013
    johnd663
    naked grips
    I run all my bars completely naked with no grips - gloves are enough - you have suspension right
    i find it increases my feel for the trail
    i now do the same for my seat and only wear a ball hunging g-strip to keep the tackle in place.............. a bit of cream on the ring and you are good to go. Nothing like leather (seat) against skin. I did try one of those furry SDG seats but it smelt like poo after a while - leather you just wash down.
  • 01-12-2013
    Rod
    Oury grips... nuff said
  • 01-12-2013
    grnd0
    What he said.... :thumbsup:
  • 01-13-2013
    Dambala
    Specialized has Ergon knockoff grips that are great, IMO. They use a softer material for the "wing" area which is also shaped/sized in such a way you can move your hands around on the grips a little more.
  • 01-20-2013
    AntiSocialClimber
    I got some Oury grips for a new bike.
    I mounted them using compressed air.
    I took the bike out today I while I thought the grips were on solid, one them started coming loose and it got progressively looser until, by the time I got home, the grip pulled right off.
    I had tried alcohol earlier but thought better of it and after cleaning and drying the grips and bar mounted them using compressed air.
    I was thinking about finding solvent-based hairspray. The safety wire technique looks interesting too.
    But I sure like to know what happened with my dry mounted grips failing.
    Ideas anyone
  • 01-20-2013
    Placibo
    I really like lizard skin peaty lock on. I used to have Oury lock on but with gel pad (palm) gloves on, i don't like how bulky they feel. The peaty is nice and thing and with a gel glove feels better in my hand.
  • 01-20-2013
    Dambala
    Ideas anyone
    Hairspray and safety wire kept my motorcycle grips on for years.
  • 01-20-2013
    AntiSocialClimber
    I'm gonna try one more mounting with compressed air. If that fails I'll try the hairspray and wire idea.
    I can get a decent set of safety wire pliers at harbor freight - $10.
    Do you use stainless steel wire?
  • 01-20-2013
    patineto
    You don't really need the pliers, you can twist the strands by hand (half the time I do it that way anyway) but they are a neat toy to have if you do it a lot..
    Stainless wire will break in no time when you are twist in it, sadly you need special wire and only comes in big rolls (about $25 a roll) but maybe you can go to your plane/moto/race car shop and ask them for some..
  • 01-20-2013
    SS Hack
    I used the zip tie mounting method and they went on easy enough but very slowly tuned around and around (4 rides per turn).
  • 01-20-2013
    Hoban
    I really like the ESI Chunky grips. I have them on both of my bikes. Neato colors too. :)
  • 01-20-2013
    agu
    +1 on the ESI Chunkies. If you need more Cush, they've got Extra Chunkies too.
  • 01-20-2013
    Hoban
    Oooh. I didn't know they had extra chunkies. They chunky all around, or even thicker in the palm?
  • 01-21-2013
    Nrs1Rider
    I think the Esi Extra Chunky's are just an extra 2 mm thicker around the palm. I've been thinking about getting some for the rigid single speed. I've been using Esi's on all my bikes for the last few years.
  • 01-21-2013
    DirtyHank
    I don't understand why anyone would not use lock-on-grips on a MTB they take seriously.
    Hank :)
  • 01-21-2013
    SS Hack
    Hank :)
    Oury's are more comfortable, lighter and cheaper ... if you can get them not spin.
  • 01-21-2013
    pimpbot
    Hank :)
    Because Lock-On grips have a hard plastic core, making them less cushy than unclamped grips, plus the rings themselves stick up above the grips. This made hot spots on my hands for long rides when I changed my hand position around.
    Now, if I ride in the rain... and I do a lot of riding in the rain... and don't have issues with my grips spinning, why would I need Lock-On grips?
    I used regular non-lockon Ourys for years and they never got loose and turned on me. It's all about making things silicon chip room clean before you install them. I use a small dab of 91% isopropyl Alcohol and air pressure to help slip them on. Works perfectly every time.
    That said, I switched to Ergon grips, and they have a clamp. They have that nice cushy paddle to spread the load out on my hand, so the hardness over the bar isn't an issue.
    Pardon the crappy tape job....
    <a href="https://picasaweb.google.com/lh/photo/MInqsD9wyfmfF1RQztIExdMTjNZETYmyPJy0liipFm0?feat=e mbedwebsite"><img src="https://lh5.googleusercontent.com/-W1-tF3ATMsg/TioEecNpwZI/AAAAAAAAVwk/PlNYJCGxJ4g/s800/IMG_1104.JPG" height="600" width="800" /></a>
    ... and one more, because I'm a pichwhore...
    <a href="https://picasaweb.google.com/lh/photo/dY2cIoXGl61HxzZEj1gdQ9MTjNZETYmyPJy0liipFm0?feat=e mbedwebsite"><img src="https://lh3.googleusercontent.com/-ULUjXbhrAiM/TuapTPLofyI/AAAAAAAAZh8/pkugffmLCqA/s800/IMG_1934.JPG" height="600" width="800" /></a>
  • 01-21-2013
    Nrs1Rider
    Hank :)
    Because they feel harder and the end caps are annoying. First thing I change on new bikes.
  • 01-21-2013
    patineto
    Hank :)
    Because you only get half the rubber and the other part of the grip is just a plastic tube, for sure they are not the same..
