Results 1 to 9 of 9
    Geax Saguaro 29 rear mount direction
    I have always loved the Geax Gato on the front wheel. Excellent in the corners. But on the back I usually go with a Geax Mezcal. Unfortunately, the best deal was a Geax Saguaro. I noticed they can be mounted one way for speed and another for traction. How are some of you mounting these on the rear wheel? Speed or traction? I want them to roll fast, but still climb well.
    It ain't easy being Green
    Reputation: sdcadbiker's Avatar
    Quote Originally Posted by AdamSean View Post
    Speed! this tire works really well front or back; I run "speed" at both ends on my trail bike.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I ran it in Traction in the past and it repeatedly threw sticks into my rear derailleur and tore it off.
    I spun it around to speed and it happened much less.
    I noticed almost no difference in traction.
    I like turtles
    What's "social pace?"
    speed. run something else on the front because it sucks up there. i like a rampage.
    I have decided to mount the Saguaro in the speed direction on the rear and continue using the Gato up front. I have taken some tight corners at crazy speeds with the Gato on the front.
    I took it out today with the rear mounted for speed direction. The trail was a fast and flowing trail with only a couple of climbs through some loose gravel and rock. It did much better than I thought. This will work great until I can find me a Mezcal for the rear. I also found I can run these at real low pressures.
    I mounted my saguaro's for speed in ft and traction in the rear , I really like the rear but the ft could be better , I was going to turn the ft around and try it
    Speed front/speed rear on my Tallboy....my fav tires.
    I run the same combo on my YS, Gato front, Saguaro rear, in the speed direction. Has worked very well for the terrain we have here in New Mexico.
  1. Geax Saguaro, non TnT tubeless?
    By jasmap in forum Wheels and Tires
    Last Post: 04-01-2018, 07:00 PM
  2. Modifying Geax Saguaro
    By Fred Smedley in forum Wheels and Tires
    Last Post: 07-13-2013, 05:05 AM
  3. Geax Saguaro TNT 29...
    By Jdub in forum Wheels and Tires
    Last Post: 10-15-2012, 05:38 PM
  4. geax saguaro.
    By AZGroundPound3r in forum Arizona
    Last Post: 07-28-2012, 08:09 PM
  5. Geax saguaro TNT question
    By tjkm in forum Wheels and Tires
    Last Post: 04-20-2012, 01:43 PM
