Results 1 to 14 of 14
    Nov 2012
    gear ratio thoughts
    read today that due to wheel size a 29" in the 24x36 position (granny) is equivalent to a 26" in 24x28 (roughly 3rd from highest in back). the article also stated that the 29er in other equivalent gears is 15 % faster than a 26" at the same rpm. this would explain alot when it comes to my riding vs my friends on 26ers e.g. equal to slower on +15% grade climbs and much faster than most as the grade decreases.
    input?
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by LB412 View Post
    No they just push a higher gear & go the same speed.
    input?
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Oct 2012
    Nominally, it is a 12% difference in diameter. So a 36 tooth rear cog is the same relative diameter as a 32 on 26". I think somebody got screwed up between the area of the wheel and the diameter. Area is exponential but diameter is just a ratio.
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by bulerias View Post
    That's right but a 33t on the 26 wheel is actually the closest match to the the 29'ers 36t. A gear inch chart is the easiest way to compare gearing between different wheel sizes.
    Quote Originally Posted by muzzanic View Post
    I know what you mean but actually they push the exact same gear to go the same speed. One rider on a 26 wheel bike and another on a 29er riding side by side at identical speed and identical cadences will be using different cog/chainring combos but will be riding in the same gear because wheel size is one of the three factors in determining gearing.
    Oct 2012
    Quote Originally Posted by J.B. Weld View Post
    You don't see a lot of 33 tooth cassette cogs tho. Nominally it would be 32.3 teeth but a 29" wheel is really only about 28.5 which makes 32.85 so you're right. The point was that it was nowhere near 28 teeth.
    Carbon & Ti rule
    You are right but I was trying to make it easyer for the OP to understand.
    Because they ahe using a higher gear on the cassette.
    Professional Crastinator
    Reputation: Fleas's Avatar
    input?
    The power of the engine is what determines the speed.
    29ers are typically geared a little lower so that the gear inches fall into the same range as a 26er.
    If you ride a 29er with 26er gearing, though, you will either just get stronger or you will end up downshifting a lot.
    -F
    It's never easier - you just go faster.
    Nov 2012
    It's really only the Granny gear I question as it is the difference maker on the steepest of climbs (for this engine)... Sounds like you confirmed that it is more difficult but not to the level I first thought.... 24x33 vs. 24x28.
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    32x18 29er = 32x16 26er
    I ride with the best dogs.
    Nov 2012
    Quote Originally Posted by bsieb View Post
    Makes sense as the difference should flow through all gear combos.
    Nov 2012
    Sounds like Shimano feels there is a need:
    2014 Shimano: 29"er Friendly- 27.5"er Intros, New Deore Group
    Mar 2013
    22-36 27.5" is almost exactly 22-34 26" EWD. 22-36 on a 29er is still a full 1" bigger EWD than 22-34 26" so they're still ignoring 29er climbing capability.
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    gear ratio thoughts
    great link for easy gear ratio calcs:
    Mountain Bike Gear Ratio Calculator V4.0
    "I ride my bike to ride my bike"- Zen proverb
    Posted via iPhone
    Old enough to know better. And old enough not to care. Best age to be.
    dwt
    dwt is offline
    gear ratio thoughts
    I predict the crankset will be standard equipment on 29'ers sold in 2014, just as compact chainrings (50-34T)are now standard on road bikes. More bike consumers of average ability than hammerheads out there.
    Posted via iPhone
  1. Gear ratio: 40:18=38:20?
    By yosshaa in forum Singlespeed
    Last Post: 05-21-2012, 01:22 PM
  2. 26 -29 gear ratio ???
    By dartvader in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-25-2012, 09:24 AM
  3. Gear Ratio for SS
    By EDizzleVR6 in forum Urban/DJ/Park
    Last Post: 10-08-2011, 06:13 AM
  4. Gear ratio
    By Jwind in forum Colorado - Western Slope
    Last Post: 06-09-2011, 01:44 PM
  5. Gear ratio
    By Jwind in forum Utah
