Results 1 to 33 of 33
    Full SRAM X9 or full Shimano XT ???
    Hi there!
    I'm riding a Rumblefish, full X7 and like it a lot.
    I'm planning to sell the RF for a more agressive 29er, and upgrade the drivetrain to a full X9 or full XT.
    As I mentioned, I like the X7 so I thought about upgrading to X9, but also heard and read good reviews about the XT.
    Which drivetrain would you get?
    Which SRAM drivetrain is Shimano XT equivalent? X9 or X0?
    Posted this thread on drivetrain forum too.
    Thanks, Mo.
    XT has the only brakes I would use, although SLX is the same if I was buying individual components. Clutch rear derailleurs are a big improvement. The Shadow Plus rear derailleur doesn't have a clicking problem showing up on some Type 2 Sram derailleurs. Again SLX is the same as XT. I would choose XT shifters over SLX, but an SLX crank.
    Shimano chain in 10sp over Sram for longevity. XT cluster over SLX for the larger carrier.
    Check pricing at bikecomponents.de Tires too.
    Reputation: JoshM's Avatar
    For what it's worth I am super impressed with the X9 shifter and rear derailleur on my bike. Very solid shifting, and super easy to setup.
    I really don't think you could go wrong with either XT or X9.
    I hate to say it but this thread is a waste of time. It's personal preference. I rode Avid/Sram and like the Shimano XT much better.
    The one thing that I think a lot of people will agree on is avoid Avid brakes. There are some that love them, but a large group that doesn't. Search the Specialized forum, after having them on my FSR, I'll never own another set of Avid brakes.
    With that said about the breaks, if you want to use the single clamp systems for either of them you have to have the same brand shifters and brakes. So that to me makes it an easy decision, Shimano with ISpec shifter levers.
    It's nice to clean up the bars and have a single clamp.
    Eventually if you want to use a dropper post, having a single clamp also helps getting the dropper level in a better position.
    OG Ripley v2
    Carver 420 TI
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    It will cost a little more to do but what I am doing for 1 of my friends is using his X9 cranks & fitting a 28 Wolf tooth chain ring, X9 type 2 Rear derailieur & X9 shifter, X01 10-42 cassette but just using the 1st 10 gears 11-42
    I have tried this with the XX1 cassette & it works fine.
    I use & like my Avid XX brakes, But every set of the cheaper Avid brakes I have ridden have been shit, I use XT's on my wifes bike's & they are the best bang for your buck anywhere IMO.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    live long and huck
    Reputation: Optimus's Avatar
    My .02, X9 shifters and derailleurs, XT crankset and brakes. But, as mentioned by several above, it really is personal preference. I don't worry too much about single clamp setups, I single finger brake and don't want my brake lever position tied to my shifter location, up and down or in and out. Use a KS dropper and ODI grips, and your dropper lever is not an issue either. As far as "cleaning up clutter on your handlebars", can't say as I much give a sh!t.
    Quote Originally Posted by Optimus View Post
    You should give them a try on someone else's bike if you get a chance. I've had Matchmakers and ISpec, and single finger brake and never had a problem getting the lever in the right place.
    OG Ripley v2
    Carver 420 TI
    I usually ride SRAM, but I will likely switch to Shimano SLX/XT on my next bike.
    live long and huck
    Quote Originally Posted by TwoTone View Post
    It really is a non-issue as far as I'm concerned, I couldn't care any less if I have 1 clamp, or 2 on my bars.
    Never trust a fart
    Reputation: frdfandc's Avatar
    I've ridden both as I work for a LBS. It's personal preference IME. My preference is Sram over Shimano for MTB stuff.
    But I will agree as far as brakes go. Shimano SLX's or XT's
    Reputation: albertdc's Avatar
    Re: Full SRAM X9 or full Shimano XT ???
    My bike I built up last year was full XT. Upgraded bikes again this year and went SRAM XX1... but with XTR brakes.
    One thing that was nice about the XT rear shifter is that you can either push the small lever with your thumb or pull it with your index finger to shift to a harder gear. SRAM is push only. I found myself shifting either with my thumb or index finger when I had the XT shifter depending on the situation. Kind of nice to have that. I have missed it a few times with the SRAM shifters.
    Other than that, and other than the XT brakes being AWESOME, I don't think you can go wrong either way.
    Oh, and SRAM trends to be a little lighter, I think, if that matters to you.
    Sent from my SCH-I535 using Tapatalk 2
    Reputation: eclipse24's Avatar
    Shimano. I've used both but the deciding factor for me is as alberdc mentioned above, being able to use my index finger to shift the small lever. For me, it makes shifting easier and quicker.
    2013 SC Tallboy C
    2011 Niner EMD9
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by mo6500 View Post
    Hi there!Which drivetrain would you get?
    Coke or Pepsi?
    mtbtires.com
    Reputation: Svard75's Avatar
    I'm surprised no one mentioned "it all boils down to looks." That's what it's really all about IMO. I've used avids for 5 years now and as long as you use metallic or semi metallic pads and bleed them properly they work great with zero brake fade. Mind you I'm a xc racer and never ridden dh or am.
    Mar 2013
    Go for XT you worth regret it, The shadow+ rear mech is awesome. Mine I went mix of Shimano XT and XTR.
    MTB B'dos
    Reputation: LyNx's Avatar
    Absolute personal preference, except as said when it comes to the brakes, then for sure Shimano. I prefer shimano, I and my thumbs prefer Shimano Rapid Rise, hence I stick to 9spd, all personal preference.
    Reputation: joe_bloe's Avatar
    Here's another wrinkle: I *love* SRAM gripshift. I run XT on my trail bike, but X9 with Gripshift on my 1x9 hardtail.
    Reputation: duggus's Avatar
    I've used both SRAM and Shimano... I went to SRAM because I liked how the triggers work better. Now I went to an XO 10spd gripshift and 1x10... and friggin love it. Using an X9 medium cage clutch derailleur in back. No dropped chains, no sound... smooooooth.
    SRAM X9 would be equivalent to Shimano XT... SRAM XO & XX (xx usually only carbon) would be equivalent to Shimano XTR
    ...Be careful what you're looking at because it might be looking back...
    Aug 2010
    Problem Solvers MisMatch adapters allow mounting SRAM shifters and Shimano brakes to the same clamp. Of course you could just use separate clamps. Either way brake selection doesn't affect your drivetrain choice.
    I prefer the SRAM trigger shifters, but it is personal preference. They both work great. Try both and see which you like better.
    Thanks for the replies guys.
    I think I'll enjoy them both: gonna run X9 drivetrain (rear der & shifters) and XT brakes.
    Mo.
    Mar 2013
    In my experience sram component doesn't last compared to shimano. I've upgraded from X0 to XT/XTR, because the carbon crank arm of X0 lasted only for 6 months after bashing it on rocks and few crashes. X0 shifter lasted only 1 month. SRAM cassette only lasted for 4 months. The only thing that I like with their SRAM is the Type Rear mech, which makes removal of wheel a little bit easier.
    The good thing about XT,its built quality is superb and very durable. I never had issues with XTR shadow+ rear mech, XT crank & Shifters & breaks after nasty crash. It work almost new.
    Jun 2012
    I used all X9 but not the brakes, I used Hope for my braking system. On my FS I have SLX shifters and brakes with XT front and rear derailluers.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    Making the jump from X7 to X9 will barely be noticeable. Performance with both are great and if you are not racing or counting grams it shouldn't make a huge difference.
    XT will be different but not necessarily better. I have rode X9, X0, XT and XTR components and they are all great. My wifes bike has X5 stuff on it and it works perfectly.
    It all comes down to which type of shifters you want, how much you are willing to spend, your weight goals, and how important bling factor is to you.
    Jun 2013
    Like many have stated. Strictly a personal choice as we all ride in very different ways. I started with Shimano after much reading, but can't comment against Sram, as I've never tried it. I'm sure it's comparable. There's just a ton of bikes out there with their product on them. I do see Shimano builds (XT/XTR) seem pricier. JMHO and I'm no expert...lol.
    Jan 2003
    I rode SRAM for the past 5 years, Loved it, My New Bikes this year are all Shimano XT.....I love that too.....I think it's a push really.
    However XT Brakes, are "THE" best brake I've ever used.
    Climbing Builds Character
    Reputation: brent701's Avatar
    Sep 2012
    I also have a Rumblefish. It has Shimano drivetrain. I upgraded the rear to a X9 type 2 and X9 shifter. Much smoother. less chain slap.
    I have no clue why 90% of the people on this forum bash Avid brakes. I have 4 bikes with them and have no had any problem. I have already had a problem with my XT brakes on the RF though..
    I guess to each his own in the brakes. Plus the Avid have the matchmaker for my reverb.
    I would pick Sram over the shimano drivetrain.
    Too Many .
    Jan 2003
    I don't think anyone is bashing Avid Brakes, or SRAM I mean really the difference is in the eye of the beholder, and for me is very very Minimal. I was just impressed with my XT Brakes, and how they stopped me now with what seems to me minimal input. I had Avid Elixr CR's for 5 years prior to these, and they were excellent too. Actually for replacement parts and stuff if you break one, AVID > Shimano. So again, personal preference, and ya know.....competition is what drives progress.
    Quote Originally Posted by brent701 View Post
    First did you compaer a clutch Shimano RD to the Type 2? Apples to Apples.
    Second, hop on over to the Specialized forum, I think it will give some insight into why Avid brakes get the rep they have, yes some people get lucky and get a set that work, rest rest don't.
    OG Ripley v2
    Carver 420 TI
    Sep 2012
    Funny you bring up Specialize cause 3 of those bikes are Specialize and have Avid. One we added avid.
    Even using elixier 1's we have not had a problem what so ever. my fish is setup with a XT front and SLX rear brake. soon will have Avid's.
    And no I have no compared a Shimano RD to my type 2. My fish didn't come with that.
    Too Many .
    Reputation: docter_zab's Avatar
    Jun 2013
    This is pretty much an apples/oranges/pepsi thread... but I went through a similar process when I upgraded my own rumblefish from x7 to XT. I immediately noticed improvement (obviously) from the XT over the x7. ESPECIALLY brakes...
    That being said,
    I recently got to demo the XX1 setup, and would probably change to that if I were to upgrade again (XO Trail brakes still suck).
    AND, with SRAM recently announcing they'll be releasing an "affordable" 1x11 setup, I would go X0 1x11 with Shimano brakes if I were about to do the upgrade that the OP mentioned.
    ​mountain biking is fun.
    OK. Gonna sell my Rumblefish and get Enduro 29 comp.
    So, I'm gonna swap the original Elixir's 5 with XT brakes, and the X7 shifters with X9.
    Looks like a pretty good setup for me, and it's not expensive too.
    Mo.
    I had avid brakes and it locked up a couple of times and also with one of my friends bike. I now have xtr brakes and never had problems since.
    Dec 2010
    Working at a shop, we see a TON more issues with the Avid brakes compared to Shimano. We probably bleed 5-10 Avid brakes a week...and probably 2-3 Shimano brakes a month. Needless to say, we are quite pleased to see more of the stock bikes on our floor moving to Shimano brakes...although it might mean less in labor revenue for us. Haha!
  1. GDMBR: Full Rigid or Full Suspension?
    By albeant in forum Bikepacking and Bike Expedition
    Last Post: 07-20-2012, 06:00 PM
  2. Full Shimano XT Dynasys 2x10 2012: Pregunta
    By Serengetijack in forum Mexico
    Last Post: 01-09-2012, 04:47 AM
  3. SRAM Twist XO with 2x10 Shimano or SRAM front derailleur
    By epiphreddy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-21-2011, 08:52 AM
  4. Paid Spam**SRAM XX Full Group or piece***
    By b00001 in forum 29er Bikes
    Last Post: 05-30-2011, 11:32 AM
Members who have read this thread: 10
