Results 1 to 5 of 5
    Which Fulcrum wheelset to pick?
    Hey, again im asking little help.
    So, i chose to upgrade my wheelset and selection is down to Fulcrum wheels.
    Fulcrum Red Power 29 Fulcrum Red Power 29er 6-Bolt Disc Wheelset 2012 | Buy Online | ChainReactionCycles.com
    Fulcrum Red Power XL 29 Fulcrum Red Power 29er XL 6-Bolt Disc Wheelset 2012 | Buy Online | ChainReactionCycles.com
    Does anyone know whats their difference besides 100+ grams weight?
    Are you able to order from CRC. If so, you can put together a better set. Easpecially since you have time also.
    I can order from CRC, but the fulcrum wheelset i can buy from my LBS thats why i chose Fulcrum at first place.
    And they are the wheelset i can afford
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    I don't see the weights listed anywhere. I have Fulcrum wheels on my road bike and they have been very good so far, but I am not comfortable recommending one of those wheels over the other. Good luck.
    There is not much choice between rotten apples.
    Looks like the inside dimension is 19.5mm and the inner rim wall is not reinforced like a ArchEX or a Frequency I23. More width lets you run a wider tire at lower pressure without it rolling over on curves.. The EX is 21 and the Frequency is 23. Here's the ArchEX. No reinforcement means no recommendation because of tacoing.
