Meat Clever
Front Tire with Cornering Traction!
I need a light-weight, relatively high-volume front tire with good cornering grip. Tubeless on a FS 29er. I currently have a Nevegal and love the cornering grip, but it is a pig and rolls like a tank tread. Other tires I have used and liked, but that don't hold in the corners well enough included:
Ardent 2.25 and 2.4 (love the feel of the 2.4 and perceived/real low rolling resistance)
Nobby Nic 2.25 (nice and light, but need just a bit more cornering traction)
Bontrager 2.3FR (hated it - routinely washed out in the corners)
So, what do you recommend?
TIA
 Originally Posted by VanillaEps
A little bit of pee just trickled out of my pipi when I saw that.
Hans Dampf is the obvious choice based on that info. Great tire.
TIA
How light-weight do you consider light-weight for a high-volume front 29"er tire - in grams that is? The Nic 2.35 outperforms the 2.25 on the front (as does the Ardent 2.4 over the 2.25).
Have you tried one of the new Racing Ralph 2.35's up front? It's supposed to be around 620g and with a nice low psi - should/could provide light-weight, fast, reasonable grip for your needs (works for me, but I'm XCing it in fairly buff conditions most of the time). Otherwise, you are going to have to probably go up into the 700+ grams category - Nic, Ardent, Hans Dampf, Rampage, etc... until some other tires are released.
Meat Clever
Ideally, it would be around 700-750 grams max. The Hans Dampf is 850g, so not much improvement over the Nev, at least in terms of weight. Perhaps I'll try a 2.35 Nobby Nic. I liked the 2.25, but need better traction. While I haven't tried one, it seems the tread pattern of the RR would not provide sufficient traction?
What pressure where you running in the NN? When i dropped from 25 down to 20, it really came to life.
Meat Clever
18 to 22
Specialized control for front, grips like a fat kids hand on a twinki.
Giant XTC 2 29er
KHS Flagstaff 29er FS
Neon Bow Trials Bike
Norco Fluid 9.2 29er FS
Norco BIGFOOT FATTY
Specialized Purgatory Control 2.3 @755g.
OG Ripley v2
Carver 420 TI
Picked up a Bontrager 29-4 on sale at my local Trek shop and it's a pretty great front tire so far...around 800 grams for top o' the line model.
Bontrager: 29-4 (Model #09477)
+ 1 on the Purgatory. I am currently running a Nevegal on the front and love it as well. Best cornering tire I have used to date...
2011 C-Dale Flash 1 650b
2013 Scott Genius 930
2015 Charge Cooker Maxi
2 words
Hans Dampf
great on both the volume and traction fronts, the extra confidence to tackle turns faster and ability to soak up bumps will make you faster even though it's a heavier tire.
Meat Clever
This might be the ticket...
I've tried the Nobby Nic up front and didn't like it. At the end of the season I was running a Racing Ralph up front and a Race King in the back both at 22 Lbs.
Purgatory S-Works 2.3 is even lighter at 730g...it is closer to a 2.2 than a 2.3 in size but does corner well.
I wound up with a Specialized Ground Control 2.1 as a front tire. I was skeptical at first but it has turned out to be a great front tire. I'm not sure if they make it any bigger. I'm running it tubeless. I might move it to the back and try a Purgatory up front.
This! Purg 2.3 up front seems to excel in all conditions including snow.
The leg bone's connected to the Cash Bone!
+1 on the Purgatory 2.3 as a front tire....I am running the S works version tubless....excellent choice for all around traction and control. I am running a Captain control 2.0 on the rear....The S works version side wall is to thin to run as a rear tire in my area.
I also like the Schwalbe Nobby Nic, as a second choice.
Well about the Sworks, For the 20 grams I don't think it's worth it.
I ran Sworks tires for years on my 2000 SWorks FSR, so when I got my Tallboy I asked about them and most of the responses were positive with a few that are exactly what I'm about to say-- sidewalls way too thin and cut too easy.
I didn't make 3 miles on my first ride before I had a cut in the side wall that was too large for the sealant to seal.
Used the warranty to swap them out for non Sworks. Months on the same trails and not a problem.
Take it for what it's worth.
OG Ripley v2
Carver 420 TI
Rep'n the 905
Good to know, thanks.
NoNi 2.25 at low pressures has always felt confident for me. The only times ive had the front let loose what due to me being over confident or rider error. If you want higher volume, the 2.35 version would probably be a good choice. It's much larger then the 2.25.
Anything more you'll have to give up the chase for lightweight. I used to run the high roller with great luck. Ardent is good too. And even an ignitor never gave me problems.
We all have different opinions...so you might have the best luck buy using the tire swap thread. Should be able to trade for other options till you find the perfect grip.
They also have a 2.3, both in 60 & 120 TPI. I am using the 2.1 60 TPI as well and I love it.
Mark
The new Ikon 2.35 has much better bite than the Ralph and the side lugs engage a bit sooner than the Nobby Nic in the corners. I couldn't mention it before, but now that it is up on the Maxxis website I can mention it. The non sidewall protection version is 665-685g, and with the EXO sidewall protection it is about 75-80g more. I've been loving it on the front of my JET 9 (prototype test tire that is) for 3 months.
When will it be shipping is the other question as it just went up on the website - so I don't know when it will be available.
This tire is great front and back, I have ridden most of the tires you mentioned in the orginal post and prefer these over all others.
TIOGA USA
Meat Clever
Just read the thread re: Maxxis 2013 tires and the 2.35 Ikon - intriguing
Meat Clever
TIOGA USA
It's a bit portly at ~800 g claimed weight and it does not seem to have any enhanced sidewall protection. I should have mentioned at the outset that I've torn too many conventional tire sidewalls to not use tires with strong casings (snakeskin, EXO, TLR, etc).
I very recently installed a Specialized Ground Control S Works on the front of my bike. I don't know what it weighs but it's lighter than what I had before.
Tons of grip.
Yea, they are a bit heavy, because they have an excellent sidewall casing incorporating unique rubberTexture on the sidewalls for added strength and cut resistance while retaining its suppleness. Plus, you can find them on-line for about $35.00.
Swimming thru the Smog
Purgatory are great. I run them on my trail/ freeride rig and love them.
Also cornering technique is very important. be sure to keep weight on your outside foot, will prevent slide outs.
Check out panaracer rampage @2.35 and good side control.
My Tioga Psycho weighs over 150 grams less than my Hans and 100 less than my Bronson. My knife edge Nevada rocks have yet to make an impact on the Psycho and it bounces less so I track straighter on the hard washboard surfaces.
Meat Clever
Sounds like a great tire - i will check it out.
The Psycho Genius? It's one of my favorites.
- You may not post replies
- You may not edit your posts
Forum Rules
