Results 1 to 6 of 6
    Apr 2016
    Front shifter Re-purposed as Remote Lockout?
    Anyone do this ?
    I have a fox 3 position and want to use an xtr 3 gear front shifter.
    Is the pull length the same ?
    The Wisconsin Waterfall
    Yes. I've been running a 3sp left shimano shifter with a fox fit4 lockout for two seasons. It works. There is a bit more cable pull on the shifter and it's tough on the cable ends but you can adjust the tension so it works in all 3 positions. I absolutely love how quick I can "shift" between fork settings. I live in WISCO with lots of short hills and i switch the fork between the 3 settings dozens of times for each ride. I was actually just searching for an alternate shifter option tonight because the cable end freyed and broke off in the crappy old SLX for the second time in two years and I'm hoping a better shifter will be nicer to the cable under the extra tension. It's worth the hassle, the over the bar lockouts suck. Unless your running a dropper and need the space under the bar, I'd recommend the 3sp shifter hack.
    Not my video. But works the same..https://www.youtube.com/watch?v=rCpX...&feature=share
    Apr 2016
    Cool thanks bro.
    Gonna give it a shot.
    I hate the OTB Shifter. I miss a couple times a ride and it's impossible to get in the middle setting when your flying.
    Reputation: RajunCajun44's Avatar
    wow never thought of this.... but it makes sense..
    Dec 2009
    my friend do this...looks work fine
    https://www.youtube.com/watch?v=wfdmxMLDqcw
  1. Deore front shifter modded/re-purposed as dropper shifter.
    By noose in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-09-2016, 03:33 PM
  2. Fox F32 remote lockout & RP2 "lockout"
    By SoftballGuy in forum Shocks and Suspension
    Last Post: 01-06-2014, 05:06 PM
  3. Replies: 3
    Last Post: 01-04-2013, 09:34 AM
  4. Replies: 32
    Last Post: 12-18-2012, 09:51 AM
  5. DT M210 remote lockout, lockout doesn't work
    By Danne in forum Shocks and Suspension
    Last Post: 10-03-2011, 12:43 AM
Members who have read this thread: 38
