    Aug 2013
    Fox Float RL or Rockshox Reba RLC
    I'm in the process of building up a Niner One 9 scandium that will mostly be setup with a rigid fork, but will swap occasionally with a suspension fork (primarily for the Snake Creek series this winter). I have pulled together a random collection of parts over the past few years and have a couple of options as far as suspension forks for the build. Which is a "better" all around fork between the following:
    -Fox Float RL (G2 off a Trek/GF Rig)
    -Rockshox Reba RLT (dual air)
    I'm torn between the two, but based on the decision I will be selling one as part of another build. As background I primarily ride rigid and haven't used a suspension fork in over a year.
    MTB B'dos
    Reputation: LyNx's Avatar
    Are they brand new, never ridden forks? If not, then I say build the bike and give both forks a try and see which you prefer For me I prefer the dampening of the Reba, but the Fox has greater arch clearance in case of mud or wanting to run big rubber.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    I rode a Float RL on an '09 Rig I had for a year or so. Locked out real nice. I own a Reba Team and a Reba SL w/ remote; both are also fine.
    My only concern would be running a G2 fork on a non-G2 frame. Some people do it with no apparent issues but I'd be more inclined go with the RLT.
    Other manufacturers like Ibis are speccing 51mm offset forks so I wouldn't worry about the G2. But I would pick the dual air Rebamaybe with new Enduro seals.
  1. RockShox Reba RLT 29
    By yabodie in forum Shocks and Suspension
    Last Post: 05-14-2014, 06:35 PM
  2. RockShox Reba RL vs. RockShox Recon Silver TK
    By jkrispies in forum Shocks and Suspension
    Last Post: 10-05-2012, 06:57 PM
  3. RockShox Reba 29 RL VS Fox 32 F29 RL-100
    By Sharky1528 in forum 29er Bikes
    Last Post: 11-29-2011, 04:12 PM
  4. Rockshox Reba Help
    By keznancehdy in forum Shocks and Suspension
    Last Post: 11-19-2011, 12:51 AM
  5. Rockshox Reba or Fox 32 F29
    By mtnfiend in forum 29er Bikes
    Last Post: 04-27-2011, 05:00 PM
