Results 1 to 3 of 3
    profite de la vie !
    Fox float 32 convert 120 TO 100
    bonsoir, i ve search here without success the appropriate parts for convert my fox float 32 on my lynskey 29er to 100MM travel : i am in big pain with the original 120mm on climbing. i ve heard that a conversion is possible, so, if any technician know where i can find the right parts for do the job any advise will be welcome !
    sorry if this case has already been discussed I have not found it.
    merci beaucoup
    Reputation: MTBmoose's Avatar
    See this link:
    2002-2012 & 2013 80 - 120 FLOAT/F-Series Travel Adjust
    Simple hard rubber spacer available from Fox or your local shop can special order.
    Regards,
    MTBmoose
    profite de la vie !
    ouch ! ultrafast reply !
    thanks MTBmoose for details : now i can research the parts and work.
    many thanks
