Results 1 to 2 of 2
Thread: Fox 34 question
    Fox 34 question
    So I want to reshim my 34 down to 120mm. I can't find the post that had the instructions to do it. Can anyone help me out? Also, do you need any special tools?
    OG Ripley v2
    Carver 420 TI
    Reputation: kreater's Avatar
    this would be the same for the float 34, just need a 20mm spacer. no special tools just disassemble like an oil change, remove the air from the float air chamber, take a socket and remove the air side, insert the spacer. add fresh oil and reassemble.
    2002-2012 & 2013 80 - 120 FLOAT/F-Series Travel Adjust
    Product designer @RSDBikes.com
    "Live dangerously and you live right."
    Johann Wolfgang von Goethe
