Results 1 to 23 of 23
    Forks wanted, 15mm, Tapered. 29er obviously.
    Any ideas on a decent yet reasonably priced fork fitting the above criteria lads ?
    Looking at 100-120 travel.
    I've got a few on watch list from Ebay in the US, but always up for more ideas...
    bt
    bt is offline
    Nov 2007
    what are you on?
    Reputation: Ronnie's Avatar
    Manitou Tower Pro, but then I'm biased I've got two of them. I'd definitely buy one again. There have been lots of good reviews about this fork. It has a very easy to remove and install QR15 hex axle which is very stiff. Absolute+ damping works well and the fork can be locked out. Just do a forum search. I've posted the picture before but to wet you appetite....
    Attached Thumbnails Attached Thumbnails Forks wanted, 15mm, Tapered. 29er obviously.-img_1579.jpg
    The trouble with having an open mind is that people will insist on trying to put things in it.
    15qr fork
    I'll second Ronnie, The Manitou Tower Pro 2012 is a great fork. You have the ability to change the spring to your preference and body weight. In addition you can get the spring curve customized through your dealer or an after market kit that Manitou sells.
    Chassis stiffness is excellent and the hex axle is super easy to use. Finally the MSRP is less then other brands with similar specs.
    Reputation: bdundee's Avatar
    I'll have to disagree, I thought the axle on the Tower was a total pain in the arse to install. A friend of mine is selling his fork for this reason.
    B/O is my friend!
    Quote Originally Posted by bdundee View Post
    Well I guess that some people are technically challenged or didn't read the instructions. It's as simple as: Hold the wheel with one hand, insert the axle with the other with the lettering facing up, rotate the QR through ¼ turn and close the QR. Done!
    Marzocchi 44 micro ti. Those went cheap a while back on chainlove, and I see some move periodically on ebay and the classified ads here.
    Quote Originally Posted by Ronnie View Post
    Wow someone a little touchy about their pos Tower fork?
    B/O is my friend!
    Quote Originally Posted by bt View Post
    what are you on?
    I'm confused, everyone else seems to understand ?
    Shall i write it in crayons ?
    usually cranky
    Reputation: b-kul's Avatar
    Quote Originally Posted by weeksy950 View Post
    he meant what bike is this fork going to go on.
    Quote Originally Posted by b-kul View Post
    Oh... lol... i look like a muppet then
    It's an Alma 29 H70 - Orbea
    Obrea Alma H70. Currently running some garbage spring things that are supposed to be forks.
    The Manitou towers come in at £340 which is about $550 which for new forks, it's not bad at all.
    Also a pair of RS from over the pond
    Rock Shox Sram XX Reba Fork 29er with remote lockout | eBay
    and a pair of Bomber Ti's
    Marzocchi Bomber 44 Micro Ti 29er Fork Tapered Steer tube 15mm 100mm Travel | eBay
    I couldn't care less what you think of me or the Tower fork but when you post blatantly false information that the axle is difficult to install/remove, for people that have had no experience with it, your statement needs correction. It simply takes a few seconds to do.
    Reputation: Pau11y's Avatar
    Quote Originally Posted by amadkins View Post
    Just keep in mind the 44 will be discon't after this year - per Mike Gold from Marzocchi.
    ╭∩╮( º.º )╭∩╮
    usually cranky
    Quote Originally Posted by Pau11y View Post
    just the 29ers or the whole 44 range? wouldnt that create a big hole in the marz line up?
    My discussion (email) w/ Mike was specific to the 29er. They'll let the Corsa take over the 29er duties...and the carbon steerer version will be on deck for 2013. I can't elaborate more if the 26er 44 will also be discontinued. Sorry
    ╭∩╮( º.º )╭∩╮
    All I said is I didn't like the axle, it is not false for myself and 3 other people we thought it sucked. With all my other forks you drop the fork over the wheel it lines up and you slide the axle through and tighten. With the Tower one of the problems at least with the AC hub is the lowers and the hub wouldn't line up very easily which isn't that big if deal untill you are trying to line it up with a fork up on top of a SUV. Hey can I put your bike on the rack for you? Sure thanks the directions for the axle are in the glove compartment, thanks! Over engineered!
    B/O is my friend!
    Mar 2012
    You're talking about the added difficulty of lining up the hex faces?
    Quote Originally Posted by Top_Cat View Post
    Yeah lining that up was a issue and we got better at but I still think something wasn't exactly right with this fork. The hex and the spline on the other side didn't seem to mesh properly. The other thing I didn't like was when you set the fork over the wheel the stops on the fork legs would let the hub go past and it would be a 1/4 to a 1/2 of hole off from lining up. Which isn't a big deal in a situation where you have an extra hand or not in a hurry or trying to balance it on top of a car to get the axle in. I am not a brand specific person I use what works and we tried this one and it didn't work so on to the next. On a brighter note we really like the performance of this fork it was just a little noisy.
    B/O is my friend!
    I have been on the Manitou Tower Pro 15mm Tapered I have it on my Salsa Spearfish 1 I have three races on it a 10 hour where I had it set to stiff 110 psi,but it was all good I then did a 100 miler I had it set at 100 psi (I'm 172 in gear) I just did a 24 hour solo and I had it set at 90 psi on a rooty & rocky course and that was fine but then I went down hard and hurt my R/hand I went down on the psi to 70 and the bike handled like a dream.
    Oct 2010
    Marz Corsa Super Legera Carbon Crown
    PM me. Mine is for sale. Fork is excellent, super light and nearly new (maybe 1 month). Only reason for sale is I need longer travel. Smokin value. Seriously.
    LordOnOne
    Reputation: EGF168's Avatar
    Had a Tower Pro for a few weeks and it seems good to me. Easy to set up, stiff, very active over small bumps, uses all of its travel without feeling under controlled or like it’s blowing through and the price is very good.
    The axle seems to be slightly more fiddly than a Maxle but the design works just fine. It would be a shame if every design was the same and any company being copied would have something to say about it if they were.
    Sorted now with a set of MArzocchi 44ti's.
    Thanks all.
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    does anyone know if the rockshox reba xx came in tapered and 15mm?
    All I seem to find are non tapered + 15mm, or tapered + 20mm.
Hot Deals
Contests
Latest Mountain Bike Articles
