Results 1 to 6 of 6
    Jun 2013
    Fork, spacer removal?
    How difficult or how easy is it to remove the spacer/s from a Marzocchi fork? It's 100mm factory and I want to have it at 120mm. This can be achived in this particular model by this means/.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Which Marzocchi fork?
    I have a 44 TST2 and watched the guys at Marz do it and even though I will do most mechanical things, and have serviced several forks myself, I don't think I would want to remove the spacer on that fork myself unless I had a step-by-step video or tutorial and a pretty good selection of tools.
    The Rock Shox Travel Adjust forks are considerably easier to do this with than the Marzocchi fork I have (I have installed/removed spacers on those).
    JMHO
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    see the 3rd post on this
    Marzocchi 44 Travel Change?
    hope this helps
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Jun 2013
    Thank you Zoke2 . Very helpful info.
    jeffj, I have a 2012 Corsa SL RC 29er fork with 100mms of travel and want to have it at 120mms of travel. I think it will add to the ride and allow me to hit some nicer trails on my CX 29er ( which I'm putting together ). I think I'll be taking it to Marz in Long Beach, Ca ...lol. I don't think I want to mess with this one either!
    R.I.P. DogFriend
    Quote Originally Posted by Luis M. View Post
    If you're close by, then what they charge to do it (and they'll likely put new fluid(s) in as well), it's worth it.
    Jun 2013
    Well it's a brand new fork, and they said they'd do it for $40.00. Hell I thought they should do it for free....jajajaja !!
  1. 2012 Fox Float 29 // Spacer Removal?
    By Chicote in forum Specialized
    Last Post: 08-14-2012, 12:46 PM
  2. 10 speed cog removal spacer
    By DirtDad in forum Fat bikes
    Last Post: 04-28-2012, 09:34 AM
  3. Removing spacer from fork questions Marz 44
    By fatcat in forum Shocks and Suspension
    Last Post: 03-08-2012, 06:57 PM
  4. where to get 20mm spacer for Fox fork?
    By Dan0930 in forum Shocks and Suspension
    Last Post: 09-13-2011, 08:29 AM
  5. Top of fork spacer overlap
    By craigsale in forum Beginner's Corner
    Last Post: 01-10-2011, 11:49 PM
