Results 1 to 28 of 28
    Dec 2012
    Flat tubeless tires. Whats next?
    I got a flat on my tubeless tires today and I cannot get them to reseal. So what do I do next. I'm assuming I'm going to have to buy a new tire but is it as easy as putting the tire on and re inflating or like I think is it a little more difficult.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Why'd it flat? When was the last time you added sealant?
    When I mount new tires, if I have time, I mount them up with a tube and let them stretch out a little and then make them tubeless. So easy, I do it with a floor pump.
    I like turtles
    Dec 2012
    There flat because I got a rather large whole in the tire. I ripped it open on something just not sure what. I bought this bike about a month ago and the rocky terrain where I ride tends to destroy tires. This was my first tubeless setup so I had high expectations that it would be better which it was as I got no more pinch flats but I ripped through the tire. I have tubes so I can put them in but want to keep the bike tubeless
    Mar 2012
    These videos are how I learned to install tubeless tires. The critical factor for me was to get the beads of the tire wet with soapy water. Without that I could not get the tires to seal.
    https://www.youtube.com/watch?v=xT1JToqWmsY
    https://www.youtube.com/watch?v=1J06pe7LwaQ
    I Ride Bikes
    Reputation: Mazukea's Avatar
    have you tried patching the rather large hole? Then setting up the tubeless?
    I like to hug trees at FULL SPEED!
    INSTAGRAM -> hawaii808MTB
    FACEBOOK -> Big Island Mountain Biking
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Quote Originally Posted by Mazukea View Post
    Huh?
    OP needs a new tire.
    SPP
    Rigid.
    Reputation: duggus's Avatar
    Yeah... tubeless isn't going to stop large holes. Depending on the size though you may be able to patch it... or yeah, get a new tire.
    ...Be careful what you're looking at because it might be looking back...
    some people have had success with using dental floss or other thin but tough material to sew a tear closed using a baseball stitch. Then use a tire boot over it.
    I have never tried it.
    Dirty South Underdog
    Reputation: Andrea138's Avatar
    You can usually patch them depending on the location and size of the hole.
    1. Remove the tire and clean off all old sealant, dirt, etc. from the hole and area around the hole
    2. Let it dry. It needs to be super dry. If it's not, your patch is going to fail. You can use a hairdryer or torch if you're impatient, but this is probably the most important step.
    2. Scuff, vulcanize, and stick a rubber patch onto the inside of the tire per patch kit manufacturer instructions.
    3. Clamp the patch area with vice grips and something larger & flat- like an old set of brake pads. Let it sit that way for a few hours or overnight.
    4. Put that b1tch back on your wheel and ride. Don't do it the night before a race, because if the patch fails, it'll suck more than usual. As long as you get through a couple of good rides on the patched tire, you can probably bank on it being OK for the remaining life of the tire.
    I'm gonna make this a topic on JRA tonight if any of you listen to Mountain Bike Radio.
    Brickhouse Blog (most known unknown)
    Just Riding Along- best internet radio show on Mountain Bike Radio
    Dec 2012
    Quote Originally Posted by Andrea138 View Post
    I shall try this and see what happens. Thank you for the advice and I'll report back if it works
    Mar 2013
    It can't hurt to try and patch it, but if the hole has cut through too much of the casing cords, it's done. Sounds like you need a sturdier tire. Something like Specialized control casing or Schwalbe snake skin, continental protection, Maxxis EXO. Most tire manufacturers make something. Real XC race tires tend to be way too thin and fragile for rocky terrain.
    1*14*29*2.1 & 1*1*29*2.4
    tyre patch stitched to the inside...not pretty but works. the sealant eventually seals the needle holes. By the time I start doing this the tyre is normally pretty worn out but it may be good for a new tyre to keep it going for a bit.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by djyoung4 View Post
    What rim and tire are you running?
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    It's my old VXC....running ghetto here with Crossmark. It's seen some hard times and I am just about to rebuild front and rear with Arches. Just waiting on delivery.
    Oops just saw you were refering to another post...
    Dec 2012
    Bontrager Duster 29er with Bontrager XR3 Expert tires. Just waiting until I feel like I wore the tires out enough until I can justify to myself buying some Maxxis Ardents or Highrollers. I think the patch is working well now. I'm just struggling to get the tire to set without an air compressor
    Dec 1998
    Do you have the Bonty TLR rim strips and valves installed? Using the TLR version of the tire? Once the hole is repaired it will easily inflate and seat with a floor pump.
    mtbtires.com
    Dec 2012
    yeah I have them installed. I went to the LBS and got a quick shot from an air compressor and all good. Thank you everybody for the help
    Mar 2013
    Buy tubeless tires from Maxxis, make sure its has EXO, these tires are very reliable and durable.
    Jul 2013
    Quote Originally Posted by rave81 View Post
    Agree. Arch EX rims and Maxxis tires solved my tubeless flats problems!
    Mar 2013
    Quote Originally Posted by rmoore View Post
    What is the widest tire you can fit on arch ex?
    Jul 2013
    Not sure, but I have a Maxxis Ardent 2.25 on the front and a Maxxis Ignitor 2.1 on the rear. They're doing great. All conditions. Tough sidewalls. My Rocket Ron's would roll off the rims in a hard turn. Not these!
    May 2005
    Quote Originally Posted by finch2 View Post
    Wow, maybe I'm dumping my tires too soon
    Reputation: masterofnone's Avatar
    Holy crap, I'm amazed you did get that to seal. I've been a loud proponent of tubeless for many years but I personally wouldn't have even attempted that one. You sir have the skills and determination of a saint. And lol where the f*** are the knobs, is that a tire or a tube? I would've slid out the first ten pedal strokes and slammed into a tree on that tire.
    To appreciate the flowers you must also walk among s**t to know the difference
    Quote Originally Posted by masterofnone View Post
    lol your post made me laugh, probably because you are right on all counts...funnily I have another tyre like this but with about 5 of these repairs I took off because I think the tyre gets old and worn and slices really easily and I got tired of fixing it. Yeah, it's a bit sketchy but just for a rear I get by...will be replacing it soon though! Just secretly want to see how far I can push my gear
    Quote Originally Posted by goodmojo View Post
    I could see this in a pinch, but it's not a good solution beyond that one ride.
    Lead by my Lefty............... right down the trail, no brakes.
    Sep 2012
    Goes to tubeless to not get pinch flats.
    Gets a flat from a large puncture it seems, NOT a pinch flat.
    Is unhappy because regardless of having a tube or not in, would have likely flatted?
    LOL am I missing something?
    Sounds liked you need burlier tires.
    Mar 2013
    Yeah buy maxxis ardent, high rollers or even minion. Those tires can take the beating.
  1. Tubeless Coversion left me with a flat.
    By Awshucks in forum Wheels and Tires
    Last Post: 07-14-2013, 11:48 PM
  2. Replies: 22
    Last Post: 12-14-2012, 11:06 AM
  3. Tubeless left on the sun - went flat?
    By Goran_injo in forum Wheels and Tires
    Last Post: 04-29-2012, 10:27 AM
  4. UMA, Rolling D, flat top and tubeless setup
    By thickfog in forum Fat bikes
    Last Post: 12-19-2011, 09:05 AM
  5. Replies: 4
    Last Post: 10-07-2011, 05:04 PM
