Results 1 to 60 of 60
    Dec 2013
    Fat 29" tires ~2.4-2.5"
    Hi guys. Im looking for som fat tires for my trek superfly 100, and i have the conti MK 2.4 on my superfly hardtail. I really like these alot, but want a bit thicker to be able to lower pressure and the extra damping. Been thinking of Conti TrailKing 2.4, Maxxis Minions 2.5 and Schwalbe Hans Dampf 2.35. Any input?
    The use is singletrack in the western norway, in other words, wet roots and rocks, and some mud.
    Fra iPhone
    Is dang happy!
    Reputation: Mr. Doom's Avatar
    I have tried the Dampf, Racing Ralph, 2.4 Ardent and some others but like the OnOne Chunky Monkeys the best. Some of the Conti tires I have used in the past have run a tad small, not sure about the TrailKings. My ChunkyMonkey was 25g less than a Hans Dampf I had BTW.
    The wheel is a extension of the foot
    unrooted
    Reputation: unrooted's Avatar
    I have the Ardents in 2.4, front and rear. The front one is doing great but the rear seems to be getting torn up fast.
    For me the front tire can be pretty light, but the rear needs to be a lot stiffer. I was running the specialized Purgatory 2.3 UST, which held up really well and has very stiff sidewalls, but weight over 1000 grams!
    I would like to find something that is tougher than the Ardent, but also not terribly heavy. From what I've read the Conti tires don't measure at the stated size and tend to be a little wimpy, but they are certainly lighter. . .
    195 lbs-6'4" Banshee Prime XL
    Ride Mammoth, Tahoe & Vegas
    PLEASE GIVE ME NEGATIVE REP!
    Dec 2013
    How's the wet traction?
    Fra iPhone
    Moderator Moderator
    Reputation: Harryman's Avatar
    I haven't had the Monkeys in hand, so I can't comment, but the 2.5 Minions have beefier sidewalls than most. Great tread pattern too, it's hard to go wrong with them unless you're in sticky mud.
    Is dang happy!
    Soft compound on the CM is great on the wet roots, It is not a mud specific tire so if you ride in the gumbo I would try something else.
    It has the same as casing a the Maxxis Ardent EXO which is not a DH tire but relatively strong. At $30 shipped it is a great deal IMO.
    Reputation: octavius's Avatar
    geax gato - 2.3 but bigger than and ardent 2.4.
    fantastic in the scottish mud - 10/10.
    Dec 2013
    And on wet roots and rocks?
    Fra iPhone
    i ride in all weather in mostly open moorland/gravel/spaghetti bolognese. the gatos have been great on everything ive encountered. not many sections are root or rocks laden but ive never been happier with a tyre. (i found ardents to be lethal). faceplant a-go-go.
    im on a rigid with p35/blunts. even at low 19/21 they are quick and clear instantly. even nippy on odd bits of road to get to the good stuff.
    worth a try i'd suggest, i got a wire pair to try out a few years back for 18 (charlie bikemonger) each and havent looked back. run a knard up front just now whilst i wait for the dirt wizard just because im seeing the benefit of bigger and bigger volume. the gato does seem to be just about a perfect balance between float/grip and zip though...
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    When the dirt wizard 2.75 is released give it a go.
    ready to ride
    Reputation: mattnmtns's Avatar
    The Chunky Monkey's are a beast. I only have a few rides on it as a front but those rides were in pretty harsh conditions. On day was lots of ice, granite slick rock, loose over hard pack, roots, mud, and sand. All I can say is wow. Grip and traction is an understatement. Not excellent at shedding clayey mud but not bad either. Loamy mud should shed well. It too is my understanding that they are built on the Ardent 2.4 EXO casing. They are a true 2.4 on a narrow rim.
    I like both the Conti MKII 2.4 and the TrailKings 2.4 but they are both a bit shy of 2.4. Which is a shame because the trailking 26x2.4 are some seriously beefy tires. Still great tires IMO but probably not the volume you want.
    Sent via my heady vibes from the heart of Pisgahstan
    Dec 2013
    Quote Originally Posted by nvphatty View Post
    It says it'll require 36mm rims... My bontrager wheels are 19mm inner (24mm outer)
    Will i have problems with for instance the chunky monkey on these? Is it worth it for me to buy some wider rims for better cornering?
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    2.4 isn't all that fat...
    Quote Originally Posted by mykle View Post
    If your fork can accommodate... Surly Knard 3.0 is awesome (this one is mounted on a Bontrager Duster rim (28mm outer) and comes out to 2.71" mounted on there). I run it at 10-12 PSI on bumpy stuff and snow (195 lb. rider). It took me ~20 minutes to get it setup tubeless with a Bonty symmetric rim strip using an air compressor (all other tires in my herd were setup with a floor pump and no major battles). The front rim looks like a roadie wheel now with all that rubber volume around it.
    I've got a RaRa 2.4 on the rear (and had one on the front as well).
    Dec 2013
    ok, but arent you worried about the bead grip when using so narrow rims? sure looks beefy.
    Dec 2013
    This is my winter setup. Nokian extreme 2.1" with 300 spikes.
    Fra iPhone
    I can't imagine you having trouble with the Chunky Monkey on your rims. Yes, a lot of folks prefer wider rims for a variety of reasons, tire support/stability amongst those reasons. One thing to note, the Chunky is not rated as tubeless specific. I've been running mine tubeless with great results on Flow rims. If tubeless systems are important to you, I believe there is a tubeless version of the Gato.
    Otherwise, I've been promoting the Chunky Monkey for going on a year now. I've been riding mine in wet PNW conditions, tubeless, and have nothing but great things to say about them.
    Reputation: fixgeardan's Avatar
    Lovin Chunky Monkeys here in Arizona for awhile now. Big Comfy durable. I way prefer
    the CM on a flow over my Knard on 50mm rim.
    Dan
    gone walk about
    Mar 2012
    skinny rims need not apply for the new dw 2.75. 35mm & up for proper fitment. The more i read the more rim width is increasing so yes it would seem a good idea.
    Dec 2013
    I have to check my clearance when I get home, but what will be a good choice for 2.4" ish tires on my bike (2012 Trek Superfly 100 AL pro). Complete wheels are damn expensive, but it seems like a pain in the ass to change the rims too...
    The only relevant I can find at the moment is the Velocity Blunt 35...
    gone walk about
    Mar 2012
    Your stock rims will be ok for 2.4 tires. If your inclined to use something bigger then yes 25mm rims or wider would be the way. As slow danger mentions people are using wider rims for improved support most recently so it gives you something to think about.
    if clearance is a close call then going to a wider rim may push you over the limit. i have Ardent 2.4's mounted on P35's. a friend has the same tire on a more traditional width rim (i don't know exactly what rim). We put our bikes nose to nose last week to compare tire profiles and they didn't even look like the same tire. mine looked big, fat and meaty and his just looked like a tire.
    I realize i'm lacking important details but all i'm saying is be careful about going to wide rim AND a big casing if you think clearance may be an issue on your existing rim.
    Dec 2013
    Any tips on how to build the cheapest P35 wheels with 15mm front and 142x12mm 10 speed rear?
    Is dang happy!
    A 600 gram rim is not what I would choose for a XC bike.
    Have you looked at the light-bicycle wide (30mm) and extrawide (35mm) wheels?
    They would probably drop more than a lb from what you are on and be much stiffer/wider too.
    *edit.* Bontrager Race lights are fairly light wheels, you would only drop 1/2 of a lb. according to bonty specs...
    Dec 2013
    CFRP rims are a bit out of my price range unfortunately :/ Not doing any competitions or anything, so the extra 500g will only make me in better shape
    Is dang happy!
    Since you are on a budget I will add that you will notice the extra width on the front much more than the rear.
    Is dang happy!
    Quote Originally Posted by Mr. Doom View Post
    Edit again OEM rear wheel weighs 1042g , front 900. so you would loose about a LB.
    Dec 2013
    As far as I can see, the widest they provide is 21mm inner. 3mm increase isnt worth the money for me. I would like to have noticeable difference if I first pay up In the area of 30mm internal.
    Is dang happy!
    The new carbon rims are 30mm internal 35 external. I was looking up the wheels on your superfly.
    I am in the process of upgrading the heavy (600 g/ 28mm) rim on the front of my ride and think the new 35mm carbon rims might be worth the investment. Wider/lighter and much stiffer than alloy.
    Dec 2013
    Ok, my bad. As I study mechanical engineering with composites as one of my specialities, I know that the CFRP rims would beat the P35s, but light weight isnt that important for me at the moment. With the heavy rims I will be able to trim off a kilo of side fat, which is much more healthy than shaving it of the wheels
    (btw, your reply will be post # 1k )
    I see P35 wheels built with Shimano XT hubs being sold on Ebay all the time for super cheap. Like under $300.
    If you want the best rim/hub combo for cheap, you can get the Stans Flow EX with Hope hubs for around $400. Those rims are 30mm outside width. Not as wide, but certainly work great with the tires being talked about here. That's the best bang for buck.
    Dec 2013
    Thanks. I will check out the stans. The p35s on ebay isnt in my axel config, but i have a dialogue with the seller atm.
    Fra iPhone
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    I have 2 sets of p-35's and a set of flows w/hope hubs. Hands down the flow is better. The hubs are convertible to different axle standards (on the front, not sure about rear) and the new ones come w/40 poe.
    gone walk about
    Mar 2012
    Quote Originally Posted by ElwoodT View Post
    any particular reason/s??
    B.Ike
    Mar 2011
    complaints w/p-35 and xt hubs: 1 they like to burp. all the tires i've mounted, regardless of psi. annoying more than anything. 2, the paint chips off way too easily, and 3, xt hubs require more maintenance.
    flow/hub are lighter and so accelerate faster, have sealed bearings, and the hubs are convertible.
    Dec 2013
    I have found a seller who has wtb freq i23 with sram x9 hubs in 15/ 142x12mm and p35 with xt 9/10mm qr. I might persuade him to change the hubs for me.
    Btw, what do you mean by burp?
    Fra iPhone
    gone walk about
    Mar 2012
    the term burp is the oozing of a liquid sealant used inside a tubeless setup.
    Reputation: shiggy's Avatar
    Dec 1998
    Fra iPhone
    A burp is a brief, but noticeable, release of air from between the tire and rim, usually without the tire deflating completely.
    Sealant need not be involved.
    mtbtires.com
    gone walk about
    Mar 2012
    Quote Originally Posted by shiggy View Post
    but it is
    Dec 1998
    Rims can also be too wide. Handling becomes sluggish, steering becomes heavy, tires feel dead.
    In the 17-23mm range, a 3mm change can be very noticeable.
    mtbtires.com
    Dec 1998
    but it is
    I have burped UST tires on UST rims run without sealant.
    And in no way shape or form is "oozing" a burp.
    A tire burp is just like a human burp. A brief abrupt release of gas.
    Oozing sealant is a runny nose or drooling.
    mtbtires.com
    gone walk about
    Mar 2012
    slice n dice how you wish but my oozing stands and is what happens. The vast majority of burpage involves a liquid sealant oozing out.
    Dec 1998
    You are confused, sir, and confusing the issue for others.
    Yes, oozing happens, but it is not burping, and it can happen without burping. If you burp a tire that has sealant in it, of course it is going to spew sealant along with the air.
    I will guaranty that ElwoodT is not referring to sealant leakage alone when he mentions burping.
    mtbtires.com
    Quote Originally Posted by fixgeardan View Post
    Dan
    That's interesting, but would you mind clarifying you comment with a little more about why? That would be cool to hear. Thanks!
    B.Ike
    Mar 2011
    spew is right. no oozing.
    Fra iPhone
    The I23 is the nicer rim, but I believe the x9 rear hub only has 12 poe which is a deal breaker for me. They sound like factory built wheels and I'd be surprised if the seller will change that out for you.
    gone walk about
    Mar 2012
    frankly no i'm not confusing others, i was confused once in the 70's but found to only be mistaken.
    Semantics here since we are all speaking the same language with the same outcome ggeeeeeez, you say air i say liquid sealant and for the sake of others they both happen simultaneously so nick name it what you will, oooze, purge, burp, leaky.
    Dec 2013
    Ok, thats good info. Thanks.
    No rush for me as I run spikes in the winter, so I will need to have em done in a couple of months... Will keep an eye out for whats out there. Its just if I want to have everything done when the ice melts.
    I think burping refers to a tubeless tire, sealant or not.
    Dec 1998
    You still do not understand difference between burp/spew and ooze/leaky.
    mtbtires.com
    gone walk about
    Mar 2012
    well i'm not alone then.
    I think you are.
    gone walk about
    Mar 2012
    Quote Originally Posted by GTR-33 View Post
    I think you are.
    i'm good with it.
    Dec 1998
    i'm good with it.
    Enjoy your ignorance.
    mtbtires.com
    Dec 2013
    Maybe we should open a new thread about ouzing and burping?
    Fra iPhone
    Just to return to the subject for a moment
    As Octavius said The Geax Gato is a grippy, cushy tyre. It's also a good roller. However I do find it doesn't get on with wet roots.
    The CM is a good all round tyre that finds grip everywhere but in return feels heavier and slower.
    EX-RoadLice
    Reputation: Trailice's Avatar
    Gato like the cat... on a hardwood floor.
    I agree with the wet roots and add rocks and maybe any dirt.
    I could not stand the Gato as it has very little "grip" at all.
    I tried very hard to like this tire, but up front it was straight up dangerous.
    On the rear it was passable if it was reversed and dry conditions, otherwise similar to the front.
    It would not grip well on much.
    I was using the 880 gram steel bead version for training and had to put the rampages back on for safety.
    Rampages have been astounding for me, tough, grippy and everlasting!
    The CM looks promising, and will be giving them a go.
    Sticky rubber for $30 delivered sounds good too.
    Anyone try the maxxis minion DHF 29"X2.5"
    Single and DH casings!
    Maxxis says 1015 grams for both, 925 for the 29"X2.3"
    The dirt wizard looks very good, Just need a frame that fits 2.75" tires.
    The Michelin wild rock'r 2 is high on my wish list as well, though 1172 grams and it is 2.35"
    Ahh choices are improving!
    Good info on the gato with wet root guys. Were i ride, there is not so many so its not a factor.
    I was looking to try the CM as well.
    Im glad that the choices for bigger tyres is improving though, its definately the way foward as far as im concerned.
    change is good
    Sep 2004
    I have the TNT and non TNT versions of the Gato. Traction is far superior with the TNT version because of the stupid low pressure I can run tubeless. It's also extremely tough. I actually prefer it on the front compared to the Hans Dampf because of its less square profile. There many posts regarding how well the TNT version performs.
    Is dang happy!
    If you like the Rampage you will love the ChunkyMonkey, it rolls quite a bit smoother on the pave and has more grip on the trail.
    Dec 2013
    Will try out the CM when the ice melts here in norway.
    Dec 2013
    Just got a great deal on som german made 2.4" trail kings. Couldnt resist...
  1. Light "click" or "snap" or "clunk" when pressing down hard on pedals
    By VFXterra in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 07:37 AM
  2. Replies: 39
    Last Post: 05-14-2013, 01:58 PM
  3. Replies: 1
    Last Post: 04-11-2013, 09:43 AM
  4. "Semi Fat": 47mm/50mm rims with 2.5"-3" tires
    By juansevo in forum Fat bikes
    Last Post: 10-08-2012, 09:41 AM
  5. Replies: 10
    Last Post: 12-02-2011, 06:44 PM
