Results 1 to 39 of 39
    Jul 2013
    Expensive Racing Tires with Thin Sidewalls?
    About a month ago I posted a problem I was having with a dented Synchros (DT) rim and tubeless tires not holding their bead. Now I've been dealing with two different LBS mechanics telling me that I shouldn't have purchased a Schwable Rocket Ron Racing Tire because their sidewalls are too thin and won't hold a tubeless bead very well in berms. The tire was $90 and is tubeless ready. I've given up on tubeless and simply placed a tube in there. No problems now, but what's up with bike store mechanics and/or tire companies selling expensive tires that have weak sidewalls? I'm ready to go back to my cheap 2007 Fisher 26'er.
    Moderator Moderator
    Reputation: driver bob's Avatar
    They're race tires and therefore weight (or lack of) is everything. There are plenty of tubeless non-race spec tires with good sidewalls that will weigh in at a respectable 700-ish grams.
    If you want super light tubeless there has to be a sacrifice somewhere.
    Jul 2013
    Quote Originally Posted by driver bob View Post
    Thanks. Somehow the bike store mechanic mistook me for a racer. I really just need durability. Weight just doesn't matter to me. I was ignorant to say the least. Live and learn.
    Mar 2012
    Rocket Ron's do have an extremely thin sidewall. I had a pair and had a sidewall cut within a month of riding. I purchased some Racing Ralphs and the sidewall was noticeably thicker and I haven't had an issue (knock on wood). Don't give up on tubeless just yet. Get the right tires for your conditions and you will love tubeless.
    Reputation: masterofnone's Avatar
    Once you've put a dent on that rim sidewall it won't hold air ever again. I'm ready to replace the rear rim on my dh bike for the same reason. Well, actually I beat the crap out of it and it has multiple dents I'm hoping it holds out until the lifts close this season before it self destructs. I'm not a believer in lightweight components and bikes, I'm a little tougher on stuff than a lycra clad racer.
    To appreciate the flowers you must also walk among s**t to know the difference
    Jul 2013
    Quote Originally Posted by Tim2103 View Post
    Appreciate your post. I do like tubeless tires and have run them on a Fisher Cobia for 2 years before getting my Scott Scale 930. Never had a problem with the Fisher other than a cracked frame that was covered under warranty. Nothing but trouble with the Scott's rear tire and rim. I guess I should invest in a new rim as stated in other posts. For now I'm going back to a tube on the rear.
    Jul 2013
    Quote Originally Posted by masterofnone View Post
    I'm learning the same lesson quite fast. I had no idea that higher end carbon mtn bikes were so high maintenance and actually less durable. I don't get the idea that people buy these to race. How do they hold up? I'm a casual rider at best. Local trails, 8 mph on average, no features, 57 years old. Maybe I need a 1990 all steel frame bike with no front shock.
    two wheel whore
    Reputation: Shmoo's Avatar
    FYI - rocks have cut two of my Racing Ralphs this season. 32 psi, 220 lbs. At least I got them on sale for 50 a piece.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Quote Originally Posted by Shmoo View Post
    Are you using the snakeskin version of the RaRa's? If not, you shouldn't be surprised that you are having problems with the sidewalls.
    SPP
    Rigid.
    Jul 2013
    Quote Originally Posted by SlowPokePete View Post
    SPP
    Do the snakeskin versions make that much difference?
    two wheel whore
    SPP, I should have mentioned that - these are not the snakeskin version. On the flip side, my Hans Dampf are snakeskin, and my Chunky Monkeys are EXO. No issues with either tire.
    Quote Originally Posted by rmoore View Post
    This might sound harsh, but...
    What is up is that consumers have too little clue what they buy. Check the Schwalbe site: Rocket Ron HS 406 | Schwalbe North America
    Notice the warning signs and the text next to it? Schwalbe is pretty honest about what use their tires are for. I am not saying you should not have any faith in shop mechanics, but it saves you a lot of pain if you read product specs and do a little search for user experience, f.e. on this forum.
    What the mechanics say about the tire's capability to stay on a rim is part outdated and part highly dependant on rim choice and tolerances. The older Schwalbes did blow off Notubes rims, because they were extra tight and the bead locks of the rims are extra high to aid tubeless installation. The net result of these combination was that tire beads could not take the strain. Even older Schwalbes blew off, because they had weak beads and fit very loose.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Quote Originally Posted by JeroenK View Post
    Excellent points- especially doing your own research.
    I've got a couple of older sets of Stan's rims (that seem to be more forgiving when mounting newer Schwalbe tires) and run a mix of EVO and snakeskin Racing Ralph's on 5 bikes. I mount all my tires by hand and suspect that beads get stressed more often when tire levers are used to mount them. Some Stan's rims back ~2011 or so were much more of a challenge to get a Schwalbe tire on. Not sure if it was Stan's or Schwalbe's issue. I bought a set of Crest's early this year and had no trouble getting tires on them.
    Chainlove had RaRa 2.4 EVO's on sale for less than $40 months back. I reluctantly bought 4, hoping they weren't going to be a pain to mount and was pleasantly surprised
    Riding technique may also be a factor. Choosing lines with less sidewall gushe potential require taking obstacles head on as opposed to trying to slither between them.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    They are not the Medium-Paced Ralph, or the Moving-Like-Pond-Water Ron.
    Perhaps, just maybe, there is something about the actual name of the tire that might give away its intended purpose?
    Death from Below.
    Pixie Dust Addict
    I'm curious about what the shop guys asked you that convinced them that the Rocket Ron was the best option for you. As a part-time bike shop mechanic/floor guy, there's no way I would suggest those tires to anyone but a racer looking for that last little bit of speed with the tradeoffs of durability and traction. Part of what you are paying for when you go into a shop is the "expertise" of the folks working there.
    Jul 2013
    Quote Originally Posted by 2TurnersNotEnough View Post
    Well, that's the whole point of all of this. I specifically went in and told them I was NOT a racer, just a casual rider, wanted a tire with good traction with a sidewall that wouldn't tear as easily as my last one. I realize now that I was ignorant and stupid for not doing my research on this. Like I said earlier, live and learn. To the bike store's credit, they have since called and made an offer to let me return the tire for a different one. Not sure at what cost though.
    Moderator Moderator
    Disclaimer: I work with a Trek dealer so my recommendation is not without bias:
    Have a look at the Bontrager XR-3 (previously 29-3). I just fitted the team issue version and run it tubeless at 22psiF and 19psiR ((I'm about 160lbs and ride rigid XC). I've been super happy with them and all Bontrager products come with a 30 day satisfaction guarantee. You dont like it, you take it back...simple !!
    Jul 2013
    Thanks. I've had two Trek mtn bikes without any of the problems I've described here. Also have a Lemond road bike with Bontrager tires. Just hit 2,000 miles on them. Seem ok.
    I do not think you were ignorant and stupid. It's just the first time shop advice let you down.
    +1 for Bontrager tires, and I do not work at a Trek store or any bike store ;-). Pretty underrated tire brand! Lots of other good options too, besides Bontrager. I guess finding the right amount of protection and tire tread for your riding (probably an allround tread) is key.
    Mar 2006
    Yes.
    SPP
    Rigid.
    Chalk it up to a lesson learned. I have always had SWorks version of Specialized tires, so when I bought my forst 29er and first time going tubeless-that's what I bought.
    First ride sliced a rear tire. Luckily Specialized has a 90day no questions asked and returned both for the non SWorks versions. No issues in the year since.
    OG Ripley v2
    Carver 420 TI
    Jul 2013
    One of the posts above implied I didn't do my research on this issue. I trusted the lbs mechanic on the Rocket Ron tire being "the best" for me. The lbs owner was the one who called to tell me his employee led me down the wrong path and wanted to make it right. Still going to be an expensive fix though. New rim, new wheel build up, new tire. Around $250. Plus I still have the $90 Rocket Ron racing tire that I don't need. Just going to stick a $10 tube in the rear tire, ride it, and hope for the best. I'll know better next time. All around tread and Bontrager sounds like the way to go. Thanks!
    Jul 2013
    Quote Originally Posted by TwoTone View Post
    What brand of tires? Size? Rims?
    Well, it depends but yes the high end race bikes aren't that reliable. Though a race car isn't as reliable as sedan for daily driving either...
    The problem with carbon bikes is most of them are designed with some form of racing or accommodating racers. Also bike companies use their warranty and customers for R&D so they can make something new every year. Most people that are buying 5K carbon bikes replace them within 5 years tops.
    Ignorant and stupid? Na, hardly. With all the tire choices, advertising hype, and mtbr forum members spouting jibberish it wouldn't be hard to pick a bike or component that doesn't quite fit what you want. Maybe the shop employee was new or didn't himself understand what you wanted. The trail is forever paved with "I should have picked that one instead". Now you know.
    Reputation: squareback's Avatar
    I would phrase it this way:
    "The back corner of the garage is littered with 'I should have picked that one instead' ".
    Reputation: toot334455's Avatar
    Apr 2013
    I am noticing small leaks along the side walls of my ra ra's.
    They were not there before and I think they are starting to get torn up from the rocks.
    Did you notice some leaking sealant around the sidewalls after a month or so?
    Moderator Moderator
    Quote Originally Posted by toot334455 View Post
    When I had a ra ra mounted up I noticed this, and it seemed to happen a bit in the summer when my garage got really hot. Tire always stayed inflated though.
    Reputation: Just J's Avatar
    Feb 2005
    I used to have hellish issues with my RoRo's on my 26" Nickel, I liked them as a rear tyre though so persevered. I experienced cut sidewalls and the tyres blowing off my Crest rims, I must have wasted around 150 on them in the course of a year.
    However when building my SB95c up I saw that they are now available with Snake skin so I thought I'd give another one a go as a rear tyre matched up to a Nobby Nic on the front. Within a couple of weeks I had a cut (not all the way through yet though) so as you can imagine I wasn't the happiest of people, although I do admit I've been pushing my luck with these tyres and should have chosen something different to start with!
    So in short, in as far as the Rocket Ron in concerned the snakeskin makes little difference in my opinion.
    Today was the last day of the season for the RoRo, I'll be putting my NoNi on the back with a Hans Dampf on the front to see how I fair.
    Jul 2013
    Absolutely! On every ride when I rode through any dip, rock, or rough terrain the tire would burp and leak. I'd have to stop and add air. When I got home I'd have to reapply Stans. Finally I learned that my new bike had old rims that were not set up for tubeless. Add the thin walled Rocket Ron Evo's and it spelled problems on every single ride. Problem solved when I switched to Stan's Arch EX rims and Maxxis Ardent and Ignitor tires.
    Apr 2013
    Its been cool here the past 3 weeks so I cant say the heat is the reason for this.
    The spots leaking have been circular in nature and they are not sealant globs, its just liquid like the antifreeze is leaking through...
    And yes mine always stay inflated
    They are the snakeskin version of the tire as well...
    Feb 2005
    It get this seeping on the RoRo too
    Fix foot pain, gain skills you forgot you had and have more fun whilst doing it!
    http://www.mcssl.com/app/?af=1681397
    Mtn Biker
    I have to say, I run 2 Rocket Rons, as do most of the guys I ride with. We run them tubeless and I personally believe they are one of the fastest tires out there. They definitely lose a small amount of air between rides, but I rode 5 hours yesterday with no problem. I also believe they are a solid year round tire for riding here in Michigan
    Apr 2013
    Quote Originally Posted by Ebig View Post
    Oh hey ! Im from MI too, what trails do you ride?
    Your Best Friend
    Reputation: Silentfoe's Avatar
    I've been riding so long and I work at a shop part time so I've had the opportunity to try just about any tire I'd like to. With that said, I LOVE Rocket Rons. I know they have thin sidewalls but I don't care. I may tear one once a year and it is just about always small enough to patch. I always run them tubeless and they set up easily on my Giant carbon wheels. I love how light they are, how fast they roll and the grip they have. I haven't ridden anything else that compares.
    I'm a mountain bike guide in southwest Utah
    Mtn Biker
    Treefarm, Island Lake, Murray Lake, Mayberry, Pontiac Lake, Poto. Starting to try Addison Oaks, Bald Mountain, Stony Creek
    I like turtles
    Reputation: TiGeo's Avatar
    Get some control casing Specy tires. Great, easy to set up tubeless, light without being too light.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    I Ride Bikes
    Reputation: Mazukea's Avatar
    ^ I also would reccommend Specialized tires. The S-works are their lightweight tires. I've used them a couple of times, but with the type of terrain here I decided I needed a beefier sidewall tire. They held up great, tubeless was easy to set-up, but I would only use them again for flowy singletrack stuff.
    The "Control" line of their tires is what I use now. They are beefy, still pretty light, and I can set-up the tubeless in a few minutes.
    I've also used their Grid UST and Armadillo casings. Very beefy, not lightweight at all, but I know they can take a beating. If you ever have to do a long ride, then this is the tire for the job.
    I also don't think of of these tires are too pricy. They can be had for $40-65 each, with the S-Works at the top of the budget.
    I like to hug trees at FULL SPEED!
    INSTAGRAM -> hawaii808MTB
    FACEBOOK -> Big Island Mountain Biking
    Apr 2013
    Yup those are my stomping grounds, I dont hit the east side trails so much though
  1. 29er XC race tires with tougher sidewalls
    By dthomp325 in forum Colorado - Front Range
    Last Post: 01-29-2014, 03:46 PM
  2. Tires: Love Spec tread, hate the sidewalls
    By airdonut41 in forum 29er Bikes
    Last Post: 01-05-2013, 11:27 AM
  3. Shoo Goo for sealing sidewalls on non tubeless tires
    By Andy13 in forum Wheels and Tires
    Last Post: 03-27-2012, 06:13 AM
  4. how thin can commuting tires go on a MTB?
    By gingermullet in forum Commuting
    Last Post: 03-23-2012, 05:48 PM
  5. Why....are Maxxis tires so expensive
    By fatcat in forum All Mountain
    Last Post: 03-20-2012, 03:30 PM
