Results 1 to 13 of 13
    Enve XC/AM Mix - Which on the rear?
    ive got 2x Enve 29er Rims, 1 is a XC Rim, one is an AM rim
    which should i run on the rear?
    the xc with a narrower tyre?
    or the AM with matching front and rear tyres?
    going on a Tallboy C
    thoughts welcome,
    Reputation: SlowPokePete's Avatar
    Mar 2006
    I would put the AM rim on the rear and the XC rim on the front, if that's what you're asking.
    I think the rear wheel is subjected to more abuse, so I would want what's the heavier duty rim in the back.
    SPP
    Rigid.
    Dec 2005
    Tough call! I would want the stronger rim in the rear and wider rim in the front. Since the stronger one is also the wider one, that is not possible. That said, the Enve XC is most likely strong enough for the rear, I would stick the AM on front for a better tire profile with less rollover in hard cornering.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    There's not going to be any durability difference between those rims. If you break one, you're going to be in the hospital anyways, and it will be the least of your concerns.
    I'd put the wider (AM) rim in the front, and the narrower (XC) rim in the rear.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Wider in the front! Strength is not a issue. 2.25 or larger typical front needs wider rim, 2.25 and below use narrower rim.
    Transition Scout Carbon
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Strong and wide in the back. I am picky about having squirmy tires on the backs. Plus the rear wheel carries the weight and gets abused much more.
    or, sell the AM and get another XC.
    Raised in a Chicken-Coop by Chickens
    Reputation: Rock dude's Avatar
    Definitely, AM in the front and XC in the rear. I have Enve AM rims and my front takes more abuse than the rear.
    Oct 2012
    Sounds like you gotta decide if you are dropping into stuff more than you are running into stuff.
    I'd put the AM with a .1 wider tire in the front for what that is worth.
    Irregardless, Le Duke makes a good point that you are worrying unnecessarily.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    With what you have I would put the AM on the front, But I would see if you could swap 0ne of them.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    wider also means MOAR traction.
    losing traction in the front is usually very bad anytime. losing traction in the back is either in climbing slip or can most times be fixed by taking a foot off the pedal during turns.
    i vote for AM in front
    cheers all, AM on the front it is
    Sup
    Reputation: Burnt-Orange's Avatar
    Dec 2008
    I think I can say for all of us that I wish I had your problems
    Sj
    I am slow therefore I am
