Results 1 to 38 of 38
Thread: Enve 29 xc
    May 2010
    Enve 29 xc
    I've finally gotten enough miles on the ENVE 29XCs (with DT 240 hubs and DT Aerolite bladed spokes) that I feel comfortable giving an initial review.
    They're awesome.
    With my incredibly burdensome 150 pounds weighing them down (), they're incredibly stiff and responsive. 36T upgrade in the rear hub means a maximum of 10 degrees of rotation before engagement. They spin up faster and easier than any mountain wheels I've ever ridden. Spoke tension has remained about perfectly even (to the extent it is possible to determine the same by feel). No issues of any kind as of yet. Sealed up tubeless easily with a set of Maxxis Ikon EXOs and the ENVE branded tubeless tape (which just seems like heavier duty Stans).
    Full details on ye old blog.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Thanks.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Thanks. Looks like a high quality spearfish 1 build. Full pics and weight would be appreciated too.
    May 2010
    Quote Originally Posted by chestercospinner View Post
    Around 25 pounds.
    Full build details.
    The Missing
    [QUOTE=lawfarm;9592645]I've finally gotten enough miles on the ENVE 29XCs (with DT 240 hubs and DT Aerolite bladed spokes) that I feel comfortable giving an initial review.
    They're awesome.
    Nice review in regards to the wheels "stiffness" did you notice any improvement in handling ?
    May 2010
    Quote Originally Posted by pernfilman View Post
    These are the wheels that the Superfish was built up with. So I'm comparing the Superfish, with a 15MM maxle up front and a 12x142 rear end with a Rumblefish with a 15mm maxle and Trek's ABP specific skewer setup in rear...and a series of earlier MTBs with traditional skewers.
    I've had a host of wheels, including a bunch of Bontragers and, most recently, a set of Easton Havens.
    To be honest...the biggest difference in handling comes from weight reduction. They are snappier in every regard because they are so light--there is an amazing reduction in their...momentum? Turning, hucking, whatever...super easy.
    The rigidity of the wheels is also apparent when cornering hard. To be fair, I'm not a heavy rider, so I'm not coming close to challenging these. But when I ride hard, there is no palpable deflection in the wheels. They're just there. Bomber.
    Sweet! I just put in an order at Enve for a set of these wheels. I can't wait to get them.
    bt
    bt is offline
    Nov 2007
    meh
    bt
    bt is offline
    Nov 2007
    wow
    Reputation: fixgeardan's Avatar
    Thats funny I have the same bike and the same wheels ,but the whels are on a different bike. There n my Stump single speed and yes they are just that amazing.
    The stock Spearfish isnt lacking at all its a great bike!
    Quote Originally Posted by bt View Post
    meh
    wow
    All your posts this informative?
    OG Ripley v2
    Carver 420 TI
    bt
    bt is offline
    Nov 2007
    Quote Originally Posted by TwoTone View Post
    the "meh" was my thoughts on the overpriced wheels.
    my "wow" was for the neg rep the op gave me for the "meh" opinion.
    sensitive wheel owner.
    May 2010
    Whoa...OP did not give out any rep--negative or positive. You're completely entitled to your opinion...I didn't even see you had posted Meh until TwoTone posted.
    May 2010
    Seriously...not a sensitive wheel owner. I'm not sure who neg-repped you (or if you can tell), but it seriously wasn't me.
    bt
    bt is offline
    Nov 2007
    no worries lawfarm.
    my apologies for assuming it was you.
    Reputation: mnyquist's Avatar
    Great review! Thanks for sharing. I like the hub upgrade.
    Jan 2009
    28 or 32 hole?
    What spoke pattern front & back?
    My wife has been riding a set of the Enve XC 29ers all season and also loves them. More importantly, she hasn't been able to destroy them, yet
    She's notoriously hard on wheels, last year she toasted two Crests (26") and early this year she tacoed a Specialized 29er Roval SL, yes... actually tacoed it. Admittedly there was a flaw in the rim and it was replaced under warranty... but still, she has a history
    I've been riding the Rovals the whole season with no issues, and I weight a LOT more than she does. But, the other day I was trying to track down a strange creak on my bike and decided to swap her Enve wheels over. I can tell you that the Enves are like night and day different than the Rovals in the stiffness department (the Even set is 28 hole to King hubs). I thought the Rovals were pretty good (coming off of Crests) until that moment.
    Needless to say, next year I'll be buying some Enve! I only wish the rims were a bit wider.
    The Missing
    As we reduce spoke count are wheel builders using "stronger" spokes to accommodate the fewer count spoke count? I like the idea of a lighter wheel build and using less spoke count but not at the sacrifice of stiffness. Or is the rigidity of the carbon so great that higher spoke count is not needed ?
    Dec 2011
    I have a set of 29 XC with 28 spokes on order. They will be coming in two weeks. Can't wait!!
    They should look good on my new Epic whenever the hell it gets here...
    Where did you order the rims?
    Dec 2011
    From ENVE directly. I actually was the runner up in their contest they just had...so I shouldn't say I ordered them...they are being sent to me
    Custom Wheelbuilder
    Reputation: Zen Cyclery's Avatar
    Exactly this. These days, I think it is becoming possible to build wheels to be too stiff. The rims that Enve is manufacturing are literally no flex which means that a 28 hole (even with a lighter spoke) is still extremely rigid. If you were to up that to a 36 or higher spoke count, I think you would start to inhibit the ride quality of the system.
    Check out www.zencyclery.com for fully customizable, handbuilt wheels.
    www.facebook.com/zencyclerywheels
    Dirty South Underdog
    Reputation: Andrea138's Avatar
    I'm highly impressed with my Enve wheels as well (29" 32h XC on DT240s). Race-weight wheels are a dime a dozen these days. These are actually really f*cking strong and stiff. I got mine in March this year, and I've beat the hell out of them in both racing and training. I just finished up the Breck Epic, and they still don't need to be trued. I'm hooked.
    Brickhouse Blog (most known unknown)
    Just Riding Along- best internet radio show on Mountain Bike Radio
    I too thought the width was a little too narrow at only 18mm on the inside....I bought the AMs instead. They are still real light at only 440 a rim.
    Quote Originally Posted by briscoelab View Post
    Reputation: grouan's Avatar
    Has anyone ridden these and the Rovals?
    After riding crests for the last few years, I went with the AM ENVE 29er because I was worried the XC version would be narrow. After a few months of riding I couldn't be happier.
    Given they cost over 2x and weigh not much less than the Mavic 29 Crossmax, the question is are they really worth it? If you were saving a few hundred grams, maybe, but that doesn't seem to be the case.
    Dec 2011
    They are bomb proof and fast as hell. They are well worth it. Mavic hubs blow.
    The Missing
    Quote Originally Posted by aaronpass View Post
    Mavic hubs blow.
    DING I will the second the "blow" factor on Mavic hubs.
    Reputation: awai04's Avatar
    Pernfilman -read your Pro 29er Rasta Build & enjoyed it. Thanks!
    The Missing
    Quote Originally Posted by awai04 View Post
    Thank you
    06z
    06z is offline
    Is there a weight limit on the xc's?
    Carbon & Ti rule
    Quote Originally Posted by 06z View Post
    Yes you need to take your wallet out of your pocket before you ride
    Reputation: skiahh's Avatar
    Quote Originally Posted by muzzanic View Post
    No, after you buy them, your wallet's weight will have no effect on your geared up riding weight! lol
    Ninja Master Powers
    Reputation: DWill's Avatar
    Aug 2010
    I've been trying to get set of 26 AM's for my Nomad Carbon since late Feb. No luck, Enve told me they would have stock in late May but hat didn't happen.
    In June they told me they would have stock in late August; we'll see.
    I hope so because I REALLY want a set.
    06z
    06z is offline
    Lol
    Custom Wheelbuilder
    Quote Originally Posted by DWill View Post
    Turnaround time for us on that rim right now is about 3 weeks.
    And to answer a previous post, there is no weight limit on any of their rims. The 5 year warranty is also a plus.
