Results 1 to 3 of 3
    Reputation: ms6073's Avatar
    DT Swiss 240s rear hub - advice on removing NDS end cap?
    Got a set of Enve Twenty9 XC 29er clinchers built with DT Swiss 240 Cl hubs and I have end caps to convert the rear hub from 12x142 to 10x135. The drive side cap was a no brainer - simply used a QR inserted from the nds and a quick tap and out it came but the non-drive side cap is not as straight forward. Did a search of the forums and while I found a bunch of threads going from 10x135 to 12x142, none seem to have the level of detail I need. With the axle after removed and clamped in an axle vice, I no way to remove the cap other than with vice grips - so what am I missing?
    Reputation: Colin+M's Avatar
    First off, they simply pop on and off. They do not thread on. I have found that I have the best luck with removing the axle, grabbing the end cap with a pair of pliers(padded if you don't want to scuff the end caps) and simply wiggle the end cap in an up and down motion while gently pulling the end cap away from the hub. It can take some effort to get them off, so don't freak about it.
    AB
    Feb 2005
    "so don't freak about it." best advice! Just grabbed my locking pliers, locked them straight out from the hub solidly onto the cap straight, gave it a "don't freak out" big time jiggle, and off they pop'd! Thank you! - AB
  1. DT Swiss 240s rear standard QR to 10mm
    By framed in forum Wheels and Tires
    Last Post: 10-28-2012, 09:26 PM
  2. Replies: 1
    Last Post: 10-06-2012, 08:14 PM
  3. DT Swiss 240s Rear hub 142 x 12 Conversion kit?
    By A-Ray in forum Wheels and Tires
    Last Post: 03-08-2012, 04:12 PM
  4. Dt Swiss 240s hub conversion help
    By backcountry1pr in forum Wheels and Tires
    Last Post: 01-25-2012, 02:03 PM
  5. Removing end cap DT Swiss 240s hub
    By dragonsnack in forum Wheels and Tires
    Last Post: 08-01-2011, 07:58 AM
Members who have read this thread: 51
