Results 1 to 18 of 18
    Reputation: crossracer's Avatar
    Dt Swiss 240 cassette body question
    Quick question, I have a rear cassette body that is chewed to heck from the guy . It's an aluminum body and I was wondering if anyone knows if they make something more robust. He is running a 2/9 system, shimano cassette
    Thanks bill
    Banned
    Re: Dt Swiss 240 cassette body question
    Contact DT. I broke the freehub body on my 240s. Filed off the splines entirely on my highest four gears. It would be cool if they offered stronger f hubs, but they don't.
    Sent from my Desire HD using Tapatalk 2
    DT makes a steel freehub body. Here's a link to one place that sells it.
    Banned
    I feel silly, thanks man.
    Perfect, thanks tons.
    Bill
    Jun 2012
    Links dead, and I can't seem to find them on wheelbuilder.com anywhere. Did they stop making them? I want to use DT swiss 240, but i'm ~210, and I know I'd prob tear up an aluminum freehub in a hearbeat. They still make a steel one to convert to?
    Mar 2014
    I think you're stuck with the aluminum freehub body. What cassette are you using? I've had several 240s hubs and never had a problem when using nicer ~xt-level cassettes with the wide alloy cog carriers for the bigger cogs. The few small loose cogs dig in a little, but still slide off easy enough. Might be different if you weigh 250lbs though
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by fullCircling View Post
    They aren't *that* fragile, I weighed that back then when I used one and I had no problems. Granted, these were the days of 22t grannies and 34t max rear cassettes, most just went with a 32 anyways. Now we need ultra-cheater gears, so this could reverse this issue to some extent. The original soft-cheese Chris King cassette bodies have gotten better with better alloys and better cassettes. The combos infamous for "locked on" cassettes were old pinned cassettes, low end shimanos and most SRAMs, coupled with CK or any other "superlight" hub, in other words alloy cassette carrier.
    As said before, this was one of the ways these guys tried to sell their products as "better" than shimano, as it was much lighter, and shimano, through their testing and R&D, knew better than to sacrifice here, although they did eventually go to titanium with the XTR, which is again better than aluminum alloy, but they usually do their homework.
    I had a little scoring with the alloy DT cassette carrier, not a big deal, nowhere near like the old CK stuff and pinned cassettes. Better alloys and cassettes have made this mostly a non-issue. I was able to get the cassette off without any special fuss every time.
    This, and I blew the freewheel mechanism on the DT twice. I was a mega-gear turner, even though I had a granny, I never used it, I just powered away up the steepest hills in the middle ring. I've never met a hub I couldn't blow up. Luckily, the DT is one of the strongest designs with it's full-contact interface, so it's about as good as it gets. Luckily too, the mechanism is dead-simple, relatively inexpensive, and easy to replace, no tools required.
    ^^^ This is what I have experienced with an XT cassette and my star ratchet hubs. You would destroy the cassette riveting first(none for me) before you have any problems with the cassette hub interface.
    Reputation: 4slomo's Avatar
    It says it is only for Shimano free hubs.
    Quote Originally Posted by Walt Disney's Frozen Head View Post
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
    Mar 2014
    Quote Originally Posted by 4slomo View Post
    I'd guess that is referring to shimano vs campy style freehubs, this being shimano style. Whether or not it will fit in a 240s with your particular cassette is another matter. But again, if you are running a top of the line hub like a 240s, then just don't cheap out on the cassette and you should be fine. 10-speed xt cassettes can be had for ~$45 online now.
    From the web page:
    "American Classic 10 Speed Clip Kit is designed to help relieve the gouging of a cassette into an aluminum freehub body. The kit works with Shimano 10 speed cassettes only (105, Ultegra, Dura-Ace).
    Note: Dura-Ace 7900 / Ultegra 6700 / 105 5700 cassettes are not compatible with this product."
    Quote Originally Posted by GT87 View Post
    Trail Ninja
    Reputation: Varaxis's Avatar
    Looked up how the clip kit works:
    Don't see any 10 speed MTB cassettes having gaps like that in the loose cogs.
    Mar 2014
    You're right, I don't see that fitting in the gaps of any mtb cassettes either. But... my point stands- it isn't needed with a high quality mtb cassette anyway. With the wide aluminum spider of xt and xtr, pg990, etc, you shouldn't experience any significant gouging of the 240 cassette body unless you're doing something wrong.
    Bikeman DT Swiss 340/540 Steel Mountain Freehub Body
    Universal Cycles -- DT Swiss Freehub Bodies (Non Onyx)
    DT star ratchet style steel body
    pretty easily found with the help of google ;-)
    Jan 2009
    Quote Originally Posted by OrenPerets View Post
    The two steel freehubs in this link will not fit the 240. DT Swiss no longer makes a steel freehub that fits the 240. They used to make one and it came on the DT Hugi FR hubs like these,
    DT Swiss Hugi 240 Fr MTB Disc Brake Hub Set 6 Bolt New | eBay
    Ebay is your best bet for finding a freehub or even a used hub that has this freehub on it.
    Good luck.
    Update / PSA
    Apparently, DT Swiss has resumed making these (or at least, they are now available after a period of unavailability)...
    It's pretty pricey, but I was happy to find it:
    DT Swiss Steel Mountain Freehub Body > Components > Wheel Parts > Freehub Bodies | Jenson USA
  1. XX1 on a 142+ rear hub - which cassette body?
    By Green Giant in forum Specialized
    Last Post: 02-09-2013, 06:29 AM
  2. Cleaning and lubing a cassette body
    By Dr.Mushy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-06-2012, 08:42 AM
  3. Replies: 3
    Last Post: 12-04-2011, 06:12 AM
  4. HOW NOT TO: Winterize your cassette freehub body
    By fishcreek in forum Singlespeed
    Last Post: 11-14-2011, 06:09 AM
  5. DT Swiss 350 / 340 freehub body question.
    By Luke_2010 in forum Wheels and Tires
    Last Post: 10-04-2011, 02:36 PM
Members who have read this thread: 9
