Results 1 to 12 of 12
    Jun 2012
    Disc Rotor Rubbing 29" Fork
    So, I've had this bike for a while, and the only thing I did today was change the tires. Not a big deal, right?
    I put the wheel back on and all of a sudden, the disc rotor is scraping the fork noticeably.
    I remember some rubbing before, but I didn't remember it being this bad to align.
    Any one have any ideas? (Pics below).
    PROEDGEBIKER.COM
    Reputation: ProEdgeBiker's Avatar
    Damn! is that the hub your bike came with?
    Whoa, I hadn't looked at the pics before replying
    Common prob. If you are sure the wheel is centered, re-adjust the caliper. Maybe the wheel wasn't centered originally when the caliper was adjusted.
    So the rotor is rubbing the fork leg? No rubbing prior?
    Jun 2012
    Quote Originally Posted by ProEdgeBiker View Post
    Unfortunately. It was. Demo bike and ice had it for about a month. Who knows what was done to it...
    Quote Originally Posted by rjedoaks View Post
    Yup, it's centered, nothing changed. I had noticed something but not that it was killing the fork. Today, different story. All I did was remove the 9MM QR, replace tire, out back on. When I start to tighten the quick release the stanchions pull together, but that side seems to come in more/crooked. Another thing to note, on the hub, there's a knob sticking out that seems to push into the fork leg like its been ground out; instead of staying in place.
    If I have to replace the stanchions ill just move to 15/20QR since my hub is convertible. But that's a last chance solution I hope.
    OSCMTB
    Reputation: Berkley's Avatar
    Seems like you're missing an end cap or some critical piece. You shouldn't pull the stanchions together when you tighten the QR. And you have far too many threads exposed on the end of the skewer, which leads me to believe something is amiss.
    Can you take pictures of the hub off the bike?
    Hub's missing a part. That QR has way too many threads showing.
    MTB B'dos
    Reputation: LyNx's Avatar
    Caution;  Merge;  Workers Ahead! Important!
    Berkley NAIL IT. You've lost the end cap for the hub, until you get it, do not even try to ride the bike like that. In case you don't know what an end cap looks like, photo is below - study the photo and then look at your hub as is, you should understand.
    Quote Originally Posted by Berkley View Post
    MTB Barbados
    My MTB vids
    Yup, missing cap. +1 for Lynx's warning and reccomendations.
    In the 1st and 2nd pic, you can see very clearly that the fork is clamped directly onto the axle that protudes from the hub. Normally there is a cap there that slides onto the axle.
    I hope the axle end and the fork dropout are OK, because those are not designed to be clamped like that. The axle end has a much smaller clamping surface than the end cap that should have been on it. Better check for damage before putting on a new end cap and riding the bike.
    Jun 2012
    Thanks guys. I believe you're right - it's missing the en cap on the disc brake side. This is the wheelset: Black Flag Expert
    I didn't even see that. I'm not even sure those were there before to be honest. Thanks for catching that.
    I hope so too, but hey might be my excuse just to convert it to a 15QR.
    As requested, up close of the disc rotor side of the hub:
    Gallery
    Jun 2012
    I'm also guessing this is the piece I need?
    Sun Ringle Dirty Flea End Cap
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    Quote Originally Posted by chris.george View Post
    nope.. those are for the rear.. you need front...?
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Jun 2012
    Quote Originally Posted by thomllama View Post
    I thought it was the "non-drive side"?
    But I found these as well:
    Sun-Ringle-Dirty-Flea-Front
    I am waiting on Sun Ringle to call me back since they don't list the hub-type on their product page.
Hot Deals
Contests
Latest Mountain Bike Articles
