Results 1 to 69 of 69
    Did Spesh Screw Me Over?: Warranty Rims
    Hi guys,
    2011 Stumpy 29'er Comp. Came with DT Swiss 450SL wheelset.
    I took it into a high end LBS for a tune-up and broken spoke repair. I get a call saying the nipples/rims are corroded and that they are going to warranty the wheelset no charge! So. I'm pretty stoked until I go pick up the bike and see these plain jane, no-name ugly black wheels. The only designation is the hub says "Stout". So I email them and they say that is what Spesh sent as a comparable replacement. I can't find much info on Spout wheels, and I don't know much about components; only that these new wheels look ugly and cheap.
    Specialized Bicycle Components
    I'd really appreciate some advice before I take this to the next level.
    Bob
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by steelgtr View Post
    Hi guys,
    Bob
    Stout is a Specialized house brand/model.
    No matter the level, they are better than wheels that are failing.
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    I appreciate that but I still need to know if the Stouts are cheaper components than the DT Swiss, meaning weight, bearing quality, etc. I don't see Stout wheelsets on the new Stumpy Comps! In fact, I don't see them on any new Bike!
    This was a 2K bike and I don't think these "Stouts" help the resale value!
    thx
    bob
    The Roval Traverse are 650 a set and have Dt 350 ratchet rear hub internals with 24mm rim internal width and Dt SuperComp spokes. I'd look into paying the difference for an upgrade. See if you can get a deal. Stout SL appear to be only worth 225 a set. 425 for a set with star ratchets is still a good value.
    Oct 2012
    Although the rims and skewer say DT Swiss,the hubs were famously weak and horrid, so you probably have better wheels now. Plus the DT 450 rims, while light, were maybe a bit weak for a Stumpy.
    So for no charge you did pretty well, I'd say. And stout is a dark and strong beer. I like dark and strong for wheels.
    Dec 1998
    thx
    bob
    Nothing helps the resale value of a 3 year old mtb.
    mtbtires.com
    Reputation: shenny88's Avatar
    Even though/if the new wheels are comparable to the old DTs, i agree with you on the resale value part. I'd at least go in and talk to the shop about some possible options.
    Take a pic of these wheels and post them up. I am wondering if you got some of the lower priced Roval's. If you did, they might not be light, but they have wider rims than your 450's (21mm internal vs. 19mm) and are pretty easy to set up tubeless as well.
    Do they have the DT 9mm thru skewer on the front wheel?
    **I just clicked on the link in your first post, they aren't Rovals, but they 'appear' to have wider rims and low sidewall height. If so, these are definitely an improvement on what you had. Put some good sized volume tires on those things, run them tubeless, and realize that flashy doesn't equal good. DT stuff is awesome, but the lower pricepoint stuff that's stocked on bikes is just nothing special... with a good name.
    So they replace a 3 year old wheelset that is well past the warranty and you're worried you got ripped off?
    Here's my advice, you want the old wheels, pay the shop to re-lace them.
    Stout hubs are Specialized inhouse hubs just like your old wheels, only difference is really is the rim.
    OG Ripley v2
    Carver 420 TI
    Thanks for all the help guys. Here are some pics
    Attached Thumbnails Attached Thumbnails Did Spesh Screw Me Over?:  Warranty Rims-img_0543.jpg
    Did Spesh Screw Me Over?:  Warranty Rims-img_0544.jpg
    Did Spesh Screw Me Over?:  Warranty Rims-img_0545.jpg
    Did Spesh Screw Me Over?:  Warranty Rims-img_0546.jpg
    Did Spesh Screw Me Over?:  Warranty Rims-img_0547.jpg
    Quote Originally Posted by TwoTone View Post
    Yeah, I'm worried if I got a set of Hardrock wheels. I didn't ask for the warranty and wasn't given a chance to repair or upgrade. I appreciate the effort and just want to know what they put on there; same. better, or worse.
    bob
    Nov 2008
    Re: Did Spesh Screw Me Over?: Warranty Rims
    Stouts came on enduros model 05'-07'
    I still have a pair going strong with 6,000 miles between 3 bikes.
    You got a more than fair shake.
    Sent from my LG-P769 using Tapatalk 2
    <100%
    Reputation: JackJr's Avatar
    You got a new low end wheelset and gave up an old beat up out-of-warranty low end wheelset - for free. The shop probably swapped over your cassette, rims, rotors, tires for free? I'd say no, you did not get screwed. You got taken care of very well. Thank them....sincerely.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    I'm surprised they warrantied the wheels as well. Typically that wouldn't be a warranty item, 3 years out.
    On a different note, most (good) wheel builders won't re-use spokes and some wheel builders won't re-use rims. So re-lacing your old hubs would get expensive fast. Figure $50 per rim, $50 in labor per wheel and $50 in spokes/nipples. $300 to rebuild your wheels, and that's on the low end.
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    this exact thing just happened to a buddy. same bike (expert i think), same stout wheel.
    He had the rovals though.
    He took it back and said, not a chance (stout was way heavier than his stock roval) and they apologized and exchanged it for a roval.
    I initially was going to say "yes" simply based on your thread title, as it is Specialized, but after examination, I think this is fair for a 3 year old bike.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    The DT Swiss wheels that came on your stumpy comp are heavy and nothing special. The new ones they gave you might not look as cool, but at least they work and are probably around the same weight.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    FWIW Getting anything for a 3 year old set of wheels is in your favor.
    2 Years is the normal warranty period IIRC.
    Myself I would be happy I can ride again and start saving up for a new set of wheels I want these should keep you rolling.
    I think Specialized went the extra mile for you I would be Great full.
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Thanks again, All
    I was a little freaked out when I picked up the Bike but y'all have made me feel better
    bob
    Missouri sucks...
    I'm half surprised they would replace a wheel, period. After 100 miles of riding they could be messed up due to abuse. I always thought a wheel was a wear item when it came to warranty claims? I'd say they hooked you up big time since the wheels were 2+ years old and you didn't pay a penny! If you came in to my shop complaining about the free wheel swap, I'd pull them off your bike and tell you to get lost
    Did they give you your old wheels back or are they on the bike shop mechanics bike now?
    Do you know how the weights compare?
    Get some cool stickers for your new wheels to make them look more expensive
    Lesson: Fix your own sh1t. A broken spoke leads to a complete 2 wheel replacement? Something doesn't sound right about that.
    No, they said they had to turn them in.
    I'd like to know the weight difference but can't seem to find the specs.
    I agree, I thought maybe they had a bad batch that were corroded for some reason. I was surprised when they called and said they had already ordered them at no charge 3 years later. If I had to do it again, I would have just fixed it but the consensus here is that I made out
    Reputation: SlowPokePete's Avatar
    Mar 2006
    OP got lucky.
    SPP
    Rigid.
    Aug 2010
    I had the DT Swiss 450SL wheelset on my 2011 Epic 29er. I had problems with several nipples breaking, and the HiBlo freehub failed, so I rebuilt the wheelset with an XT 142 rear hub and new spokes/nipples. While rebuilding them I weighed the rims and they actually weigh 490g! The hubs were about the same weight as XT hubs.
    Normally broken spokes are considered "wear and tear" and not covered under warranty. I would continue buying bikes from that shop!
    Quote Originally Posted by WillTheGreat View Post
    Thanks, Will
    Is 490g considered light or heavy? That's the info I was looking for.
    Again, the shop said there was heavy corrosion throughout the rim/spokes.
    bob
    Reputation: ReXTless's Avatar
    Feb 2007
    You came out fine. Your original wheelset had low-end "custom" DT Swiss 450 rims and Specialized brand "Hi-Lo" hubs. The Stout hub is another Specialized model. You never had DT Swiss hubs...
    Only thing i would check is if the stout rims are tubeless ready. I also had a stumpy 11 fsr 29, but the rims i got were 520SL and they were tubeless ready. maybe that is a feature you can ask them if the new rims don't have this feature. otherwise i think they it was a pretty good replacement, they use the stout for the single speed carve so they must be pretty tough wheels.
    Guys,
    Would the Roval Control 29 be a huge upgrade from the DT Swiss or Stouts?
    Also, is the 490 gram/rim considered light or heavy for the DT Swiss/
    thx
    bob
    Here are some rim weights for comparison. You can look at the 29er or 700C (which are the same size).
    Weight Weenies - Rims
    Thanks, Steve
    Any thoughts on these as far as an upgrade (weight wise)?
    Spesh has offered to upgrade me to the Rovals for $250.00
    Should I take the deal?
    Thanks for all the help and apologies for coming off so harsh!
    bob
    I know you were asking Steve, but I'll chime in. You'll be happy with those wheels. The weight's not bad, and you have wider rim width and easy tubeless set up. In my experience, Stan's rims, Roval rims, and Specialized tires are some of the easiest, least fussy rims/tires to set up tubeless. I consistently mount tires tubeless with just a floor pump. And they seal very easily too.
    I'd go for those if you like them. You'll feel a difference.
    **I just saw your next post after I posted mine...jump at that deal...
    That's a tuff one. You can usually buy take offs for a little more. For example, I just sold my stock TBc wheels, DT Swiss 350 hubs WTB I19 Rims for $350, which I think are a better wheelset.
    You're spending $250 to go from a low end wheelset to a middle of the road set.
    I'd personally save up and get a better wheelset. The wheels are one of the best upgrades you can make and you might as well do it right vs. 1/2 way. As long as you get convertible hubs, those wheels can move to any new bike you get.
    OG Ripley v2
    Carver 420 TI
    Thanks,
    What would be the next jump up without breaking the bank?
    bob
    turtles make me hot
    Reputation: NYrr496's Avatar
    Thanks,
    bob
    Hope Pro 2's with Stan's Arch EX's
    I like turtles
    1*14*29*2.1 & 1*1*29*2.4
    490 is light for an AM rim, and not surprising for an xc rim. my crests were 400 but they are considered on the light XC side. My old VXC's were 540 I think. Eyelets usually add a bit of weight but are possibly worth it.
    Quote Originally Posted by finch2 View Post
    If the Rovals are as light, I would probably do the deal. The reason I was upset was mainly about weight. I know important rotational weight is. Hard to find that spec for the Rovals.
    Get the wheels and RIDE them, Bob. Spec is offering you wheels at BELOW cost. Or keep pressing Specialized...maybe they'll just give you some Carbon Controls...
    Whether or not the Rovals Spec is offering you are a few grams lighter or heavier, they are better wheels and they are going to change how your bike feels, how your tires feel, and you can very easily go tubeless is if you so desire.
    If you are concerned about rotational weight, run your tires tubeless.
    Quote Originally Posted by jochribs View Post
    Ordered! I was running tubeless, BTW Renegades.
    bob
    Aug 2010
    Thanks, Will
    bob
    490g is definitely heavy for an XC rim. It is low-end for DT Swiss, and not as good as their aftermarket rims. I use them for training and they have proven durable, but they are heavy for XC rims. They are basically AM weight in an XC width.
    Thanks, Will
    Going for the Roval upgrade
    bob
    Jul 2013
    Just read your post. Consider yourself lucky that the bike shop replaced your wheel. I have an 8 month old $3K bike and the rear rim was damaged during a very casual ride. Took it back to my LBS. No replacement. Not even a break on the repair. It was tubeless and the LBS just put a tube in it. BTW, it was a DT Swiss rim and wheel set. Talked to the bike rep and he said there was no warranty.
    Quote Originally Posted by rmoore View Post
    Your situation is different, you damaged the wheel riding. If you read the OP he was getting a spoke replaced, not sure if he was paying or not, but when the shop saw all the nipples were corroded they replaced the wheels.
    I'm sure the shop saw that as a defective, not the same as user damage.
    OG Ripley v2
    Carver 420 TI
    Jul 2013
    That's exactly what the bike shop guys told me. They also told me my $3k bike came with cheap wheels and wheel sets. This was 8 months after I bought the bike from them. No mention of this before I laid out the cash. All of which is clearly my fault for not doing my homework. But, some bike manufacturers will stand by their products better than others, no matter the cause. Trek replaced one of my rims two years after I bought the bike without question. They didn't use "rider damage" as an excuse. Not so with my latest bike purchase. Obviously not a Trek.
    I do feel lucky and apologize again to the group for coming off bratty.
    bob
    Jul 2013
    [QUOTE=steelgtr;10660093]I do feel lucky and apologize again to the group for coming off bratty.
    No need to apologize. I was just trying to let you know it could have been much worse. I've had it with local bike shops not standing by what they sell to ignorant customers like me. I'm sure others will post replies that I am indeed ignorant. But if I can't trust the owner of a LBS, who can I trust ?
    Excuse? really, just consider yourself lucky when you get taken care off and don't ***** when a shop doesn't because it was your fault.
    Your Trek probably came with their inhouse wheels, depending on what bike you have now, the wheels might not be theirs. I had a hub go bad on my Felt, it was a Shimano wheel so not Felts problem. I contact Shimano and they took care of it.
    I doubt your wheels are cheap, but it's a 3k bike, it isn't going to come a $800 wheelset.
    I have a $5500 bike and still upgraded to a better wheelset.
    OG Ripley v2
    Carver 420 TI
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    bob
    No worries, you're probably one of the only people in the free world that the big ess didn't screw over.
    You throw down $3k on a bike without looking into what kind of components it has? Sorry, can't blame that one on the bike shop or company. Clearly states on their site AND you can actually see it first hand.
    Quote Originally Posted by Dirty $anchez View Post
    I have issues with the business tactics of the soul-less company that is Spec, but when it comes to customer service, it has always been top notch in my experience.
    turtles make me hot
    I was going to stay out of this aspect of the conversation, but I do have this to say...
    When I bought my 08 Stumpjumper, I was all impressed with the DT Swiss rims and hubs. Turns out, they were junk. The rims were these skinny, flyweight things that were useless under my clydeness. The rear hub said DT Swiss all over it. It turned out to be an Onyx. Total trash. I do, however like the stout front hub with it's 9mm thru axle.
    I built new wheels for the bike and have thoroughly enjoyed riding it.
    Now, when I cracked the frame, Spesh wasted no time in sending me a replacement. No complaints with their customer service.
    I like turtles
    Jul 2013
    Quote Originally Posted by phsycle View Post
    Yep. I think that's what I said in my post.
    Jul 2013
    I hear you. But I don't get spending that kind of money on a bike and having to immediately upgrade to better wheels. Maybe I should keep riding my 2007 Gary Fisher which cost me $500 and has caused me no problems. More $$$ seems to cause more problems.
    You admitted you were a clyde and some equipment is made to accommodate heavy riders. Expensive XC stuff isn't. Some people think just because you dropped a lot of money on an expensive xc hardtail means that it was meant to hold a 300lb guy. Not really the case. Nearly all bikes have some kind on weight limit, usually 300lbs.
    Jul 2013
    Quote Originally Posted by GTR-33 View Post
    Yes, the LBS made it clear to me that I was too heavy to ride tubeless. I'm 5'11" and weigh 185 lbs. I should be riding a 1989 steel Jamis.
    The definition of Clyde has changed I guess.
    Jul 2013
    Quote Originally Posted by smilinsteve View Post
    I don't even know what being a "Clyde" means. I think I'd better stick to road biking. At least I understand what people are talking about.
    Guys,
    Since the cost is the same, should I go for the Control 29 or the Trail 29?
    I weigh 145 and don't ride that hard (I'm 64)
    bob
    Jul 2013
    Quote Originally Posted by Stripes View Post
    I call BS. I've been riding tubeless for almost 10 years now (and back then I was 215lb, now 185lbs) and I've only broken spokes recently because I'm riding more aggressively (and the spokes are bladed). Never had a problem riding tubeless (the spokes would have broke anyway on the rocky terrain), and the only rim I had a problem with was the Stans Flows (not EX) from a few years ago. Many people who are heavier than me or you ride tubeless with zero issues.
    You're right. Since switching to Stan's Arch Ex and Maxxis tires I've had no problems riding tubeless. Live and learn.
    Guys,
    bob
    Personally if you're buying wheels I wouldn't go Specialized. The OP was getting offered a big discount as an upgrade for warranty.
    For that kind of money you can get a Hope Pro Evo2 hubs, DT swiss spokes/nipples and some Stans rims, which I'd considered a better wheel than those Specialized.
    OG Ripley v2
    Carver 420 TI
    turtles make me hot
    I ride tubeless at 255 pounds. Who told you you were too big at less than 200?
    I like turtles
    Jul 2013
    Quote Originally Posted by NYrr496 View Post
    I bought a Scott carbon 29'er last December and when I started having trouble with rear flats the bike store mechanics said I was "too heavy" to ride tubeless. I'm 5'11" and weigh 185 lbs. I've since learned that the mechanics and owner were incorrect. LBS was trying to keep from admitting they sold me an expensive bike with non-tubeless rims and tires (Rocket Ron's) that have lightweight, flexible sidewalls. REI solved my problem with Stan's rims and Maxxis tires. Everything is fine now.
    I am the OP and can pay the $250 to upgrade to the Roval s. The trail and control are the same price so which is better for me?
    Jun 2013
    I agree with TwoTone Get the Stan's check out Wiggle they were having a sale on rim's I have Roval's On my 2012 Stump Jumper i have no complaints other than the Hub's DT Swiss 18 pt. engagaement I'm upgrading to Industry Nine Torch soon.
    SRAM XX1
    Sorry getting mixed up. Well I've already said what I thought, I'd just save up more for a better wheelset.
    If you set on this upgrade the controls are lighter by a little bit.
    OG Ripley v2
    Carver 420 TI
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Let's see if I can work clean on this one. . . . . . . If the guy that told you that (185 lbs was too heavy for tubeless) was given an enema, he would completely disappear.
  67. #67
    Reputation: Bigb2000's Avatar
    May 2013
    What? I'm too fat for tubeless? At 240 lb please don't tell the wheels I've been riding forever tubeless with zero issues that. I went to tubeless because of the pinch flats I was getting. Not a single flat since being tubeless.
  68. #68
    turtles make me hot
    Gotcha.
    I like turtles
  1. Spesh SJ to Niner A9 RDO
    By VanillaEps in forum Niner Bikes
    Last Post: 06-28-2013, 04:49 PM
  2. Replies: 2
    Last Post: 02-02-2013, 10:03 PM
  3. FNG, looking at a couple Spesh bikes
    By spectre04 in forum Clydesdales/Tall Riders
    Last Post: 02-02-2013, 01:57 AM
  4. Upgrading Rims on my Spesh comp carbon evoR
    By everything motorcycl in forum 29er Bikes
    Last Post: 01-30-2013, 10:00 AM
  5. Spesh Fast Traks...
    By roaringboy in forum Wheels and Tires
    Last Post: 08-04-2012, 03:01 PM
