Results 1 to 6 of 6
    Reputation: skikarl's Avatar
    Sep 2013
    Correct adapters
    So i recently won an ebay auction for a set of new take off giant p-xc2 rims.
    Giant P XC2 29er Wheelset w Nobby NIC'S | eBay
    they came with tiers and rotors. i think it was quite a steal. they came off an Anthem 29.
    However my bike (2013 Trek Wahoo) used 160mm rotors front and back and this has a 180mm in the front (or a 7 inch if you wish). and the front axle is 15qr rather than my bikes 9mm.
    So the Question is: what are some nice adapter that you have used for 160-180mm rotors and 9-15mm axle? there are so many that are different sizes and shaped and i would like to get some that are an "industry standard" if you would. something easy, strong, and reliable.
    Thanks in advanced!
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Mountain Bike 15mm thru Axle to Standard 5mm Quick Release Wheel Adapter | eBay
    Just swap the 160mm brake rotor to the wheel you want to use.
    Sep 2013
    i want to use the 180mm rotor though. my rotors are off of an entry level bike, and have some abuse on them already. the new ones are much better.
    AZ
    AZ is offline
    Quote Originally Posted by skikarl View Post
    Then you need to source the proper adapter to match your brake. Adapters are different from maker to maker. So, figure out hat brake you have and get a 180 front adapter, probably post mount. Your LBS would probably be the next stop just to ensure you get the proper part.
    ballbuster
    Reputation: pimpbot's Avatar
    Adapters are like $10 each, if you have the kind of calipers that would use a post mount on a post mount bike, and they are all pretty much interchangeable generic these days.
    Check the brake forum FAQs. This is not a 29er specific question.
    Sep 2013
    i have Tektro Novela mechanical discs. for a rear mount this should work right?
    Shimano Is Caliper Adapter Bracket Rear Frame Is Mount for Rear 180mm Rotor | eBay
  1. correct year
    By pjohn221 in forum General Discussion
    Last Post: 06-18-2013, 05:34 AM
  2. Need Help With BB Adapters
    By tapcon in forum Tooltime
    Last Post: 06-09-2013, 07:28 AM
  3. Are all IS adapters the same?
    By f3rg in forum Brake Time
    Last Post: 03-03-2013, 03:35 PM
  4. Correct PSI?
    By 2ts in forum General Discussion
    Last Post: 05-15-2011, 08:23 PM
  5. PBR 140 Correct Castle too?
    By jthurd in forum Cannondale
    Last Post: 05-13-2011, 08:37 AM
